Question about GE WBSR3140DW Top Load Washer
Trying to drain and fill at same time wont switch off
Indesit washing machine keeps trying to drain and fill at the same time wont switch off only at plug
  • thegreysons May 25, 2009
    Just tried it, even took it out fully still keeps doing it. The extra rinse and easy iron keep flashing too.
  • 18 Answers
Pull the drain hose up out off the stand pipe until only a few inches of hose are into the drain. you are siphoning. happens all the time
Posted on May 25, 2009
My Indesit washer model no IWC61651 ECO fills with water but does not do the wash cycle will run for hrs keep filling water but programme never moving
Lynne,
The drain hose for the washing machine is pushed too far down the standpipe causing the water to siphon out of the machine. Look at the diagram below:
-make sure standpipe is at least 18-30inches high
-only push drain hose in 4-6inches
Aug 16, 2016 | Indesit Washing Machines
Washer machine front loader wont fill up and wont drain
it maybe that the pump winding is open circuit some machines use the pump winding as the neutral line for the water valves so if the pump fails they wont fill no point in it filling if it wont empty
Mar 09, 2014 | Indesit W 123 Front Load Washer
Indesit 657w
CHECK TO SEE IF THE DRAIN HOSE IS RAISED ABOVE THE REQUIRED HEIGHT. IF THE WATER IS OVER FLOWING THE TUB THEN IT IS USUALLY THE A BLOCKAGE IN THE PRESSURE SWITCH HOSE, OR SOME INABILITY OF THE WATER LEVEL SWITCH TO MEASURE THE AMOUNT OF WATER IN THE TUB.
Dec 23, 2013 | Washing Machines
Indesit WIA102 keeps draining, even when washing
Try lifting the drain outlet higher than it is, if it is too low the water will syphon out as it is filling, there by causing the problem you are experiencing, if that does not solve the prob, then it sounds like the pump is on all the time, this being the case, then it would appear that it has a faulty programmer.
Plz rate my solution.
Thanks.
Jan 22, 2009 | Indesit W 123 Front Load Washer
Indesit wd125 drum wont turn
check your pump it may not be working
Dec 18, 2008 | Indesit W 123 Front Load Washer
Washing machine
did you reset the machine after you checked the filter? if not put the selector switch to any of the stop positions the switch on wait till the on/off light flashes rapidly , then switch off and try again.
Aug 16, 2008 | Indesit W 123 Front Load Washer
Indesit evolution de73 dishwasher
01 = Acquastop operated due to leak / overfill - machine drains until empty + lmin.
A02 = Heater Relay open circuit/short circuit or Thermistor or Safety T/Stat o/c or s/c or Element machine fills to Level Switch & Wash Pump runs.
A03 = Thermistor open circuit /short circuit - machine drains until Level Switch resets +1minute
A04 = Unable to sense/reach temperature in 70mins. - machine drains until Level Switch resets + lminute
A05 = Level Switch not resetting in within 3' 20" of drain commencing - machine drains until Level Switch resets +1 minute
A06 = Not used see also H20 at end
A07 = Wash pump Triac closed/open circuit - check that Drain Pump is not disconnected or Aquastop operated
A08 = Auxiliary Wash Pump Triac closedlopen circuit - check Wash Motor operation- machine drains until Level switch resets+30"
A09 = Main Wash Pump Triac closed/open circuit - cheek Wash Motor operation- machine drains until Level Switch resets+30"
A10 = Fill Solenoid valve Triac closedlopen circuit - check valve/operation - machine drains until Level Switch resets+30"
A11 = 1/2 load Solenoid Valve Triac or alternating Wash Motor action - check Solenoid Valve operation & alternating Motor action, replace Module if required - machine drains until Level Switch resets +30"
A12 = Relay with open circuit - check Heater, replace Module if required - machine drains until Level Switch resets+30"
A 13 = Dispenser Triac incorrect operation closed/open circuit - Wash Cycle completes but with Dispenser Lid notfunctioning correctly
H20 = Static 'Fill Time exceeding 6 minutes - cheek for blockages/low pressure
Apr 07, 2008 | Indesit 24 in. DE73 Evolution...
Indesit W123s - Hates Us
first thing to do is to make sure the washing machine is not siphoning. sometimes if a washing machine is bringing in water its all so draining it ,known in the trade as siphoning. the drain hose must be higher than the tub?? Unplug your washing machine from the wall socket for a minute or two and plug it back in to reset its micro. to me it sounds like a main board fault. I think you might find that it still maybe under warranty. ring a Indesit service agent and get some advice.
Aug 17, 2007 | Indesit W 123 Front Load Washer
GE WBSR3140DW Top Load Washer Logo
155 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
