Question about Refrigerators
I have a top-freezer Kitchen Aid refrigerator, built in 1999. The icemaker works perfectly well as long as you leave it on. When you turn it off for a day or two, then turn it back on, it will not work - unless you unload the freezer and leave the door open until the icemaker "thaws out". Thanks, Charley E. charlyandmarsha@msn.com
  • charleyandma May 25, 2009
    Ref. the second suggestion: I've let it ALL thaw out several times. Then, later on when I turn the ice maker off, then back on, it will not work.
  • charleyandma May 26, 2009
    I never thought of just lowering the freezer temp a little - I guess you (I) just think of freezing as freezing. I'll do it.
    The model # is KTRP22KGWH01
    Thanks much,
    Charley
  • 15,935 Answers
Lowering the temperature will help with the freezing issue - also clean the door gasket well with soap and water - and I would also suggest putting a flashlight inside then shutting the freezer at night. If you can see light - your gasket needs replacing.
If the freezer keeps getting the humid air instead of recirculating the dry air inside - ice will build up as well.
Thanks for using FixYa!!
Posted on May 27, 2009
  • 6,784 Answers
Ok, the freezer temp is a bit to low and, this will continue to freeze the ice makers valve and lines. if you are having trouble keeping a consistent temp i the freezer or fridge, i suggest replacing the thermostat and raising the Temp a bit to prevent this freezing of the ice maker components.
Posted on May 25, 2009
  • Michael Masters
    Michael Masters May 25, 2009
    if you could give me your model number, that would be great. i would like to take a look at the schematics.
    Sergeant:
  • 296 Answers
Hi
Check your water line and make sure the unit itself hasn't worked loose from the power connector. If that doesn't do it, you can try emptying your freezer and letting it all thaw then seeing if that helps. Sometimes there can be an ice chunk keeping it from moving. Other than that, all you can do is u ve to replace it.
regards
    Brigadier General:
  • Refrigerators Master
  • 3,614 Answers
Check to see if something has caused ice to back up around the mechanism—this can cause the fill tube to freeze, blocking the mechanism. When ice cubes are small and seem to be getting smaller, it generally indicates a frozen fill tube.
Let me know
Kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Oct 13, 2009 | KitchenAid KSS48QM 48" Built-In...
Ice maker makes too much ice
In my Kitchen Aid bottom freezer there is a metal arm(?) that I lift up to stop the ice maker from making ice. When I start running low on ice, I push the metal arm(?) back down for it to make ice again. Hope this is the solution for your Kitchen Aid too.
Jul 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ksrs25ikss01 kitchen aid fridge portion not
1.check if the fan inside the freezer is running
2. if ref runs none stop, defrost timer is out.
3. or it could be the high limit that paired in series with the defrost heater
good luck!
Jun 25, 2009 | KitchenAid Superba Architect KSCS25INSS...
Icemaker not working
I adjusted the temperature control for the freezer form 0 to -1 and it started right up later I changed it back and it is still working so I suspect I have an electrical problem somewhere
Apr 14, 2009 | Refrigerators
Water stopped and freezer not cooling
you probably have a bad evap fan motor in the freezer compartment. when this motor goes bad it doesnt distribute the cold air around causin subfreezing temp in the bottom of the freezer it then migrates into the fresh food compartment. you can order the motor by the mod# of your refrig and it is fairly easy to change yourself. good luck peyton
Jan 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
No ice production
Chances are the fill valve at the bottom back of the refrigerator is clogged or failed. This valve opens to allow water to fill into the icemaker.
It could also be that the fill switch in the icemaker has failed, or depending on type of icemaker, the ice level bar is flipped up, or the mold heater sensor has failed.
Please provide the refrigerator P/N for more information.
Jan 15, 2009 | KitchenAid Refrigerators
Icemaker won't fill with water
If you would like a repair manual for your refrigerator, you can get one here. These are helpful to have in case you have other issues with the fridge.
Thanks
Sep 29, 2008 | Samsung RS2630WW Side by Side Refrigerator
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
