Question about Garden
Troy-Bilt 2550 20293 pressure washer not producing pressure. Worked when last used 2 months ago. Pump pistons are moving up and down when engine is pulled through. Inlet water is flowing through pump but no pressure when engine is started. I have the same problem. Water flows thru the pump when not running, but no flow or goes in by-pass mode when I start the pump. The pump being Troy Bilt Model 020296-01. I replaced unloader valve even. Anything else I can do?
  • 2,841 Answers
You replaced the unloaded valve. Are you positive you have the unloader screwed to pressure and not turned the opposite way? You will have no pressure if it is adjusted wrong. One other thing I have encountered is that the unloader has a ball bearing inside. If it is stuck you will have no pressure. Make sure that ball bearing is free.
Posted on Aug 09, 2010
    Brigadier General:
  • 3,614 Answers
Check the unloader valve. Sounds like it is sticking. The unloader is just not taking the pump out of bypass mode. It is usually a brass vlave screwed into the pump somewhere near the pressure line.
Let me know for further clarifications
Posted on May 25, 2009
    Top Expert:
  • Garden Master
  • 80,339 Answers
The usual cause of this problem is the pump is bypassing, u can get a pump rebuild kit from troy-bilt and do it youreself, did this many times on my friends pressure washer who is a house painter
Posted on Jun 03, 2009
  • 1 more comment
  • yadayada
    yadayada Jun 04, 2009
    Did you eve3n try any of these repair solutions before you rejuected them? U have a pump problem that much I am sure of.
  • yadayada
    yadayada Jul 15, 2009
    have u fixed this or not?
  • yadayada
    yadayada Nov 12, 2009
    the usual cause of this problem is the pump is bypassing, u can get a pump rebuild kit from troy-bilt and do it youreself, did this many times on my friends pressure washer who is a house painter
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Sorry.
Aug 11, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
How to remove calcium buildup from pressure washer pump
I have found t vinegar has many uses. Mix the water with vinegar
Jul 09, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Power washer wont pump
Call us when you can be at the washer so we can trouble shoot it with you over the phone.
http://www.ppe-pressure-washer-parts.com/troy-bilt-020416-1-pressure-washer-parts
Mar 20, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
How do I change oil in my Troy Bilt Model 020245 pressure washer
if its a vertical engine it;s underneath the base of motor look for a plug with a square slot in it i usually use a 3/8 " extension
Aug 21, 2013 | Troy-Bilt Troy - Bilt 020245 Pressure...
Change oil in Troy Bilt 020245 pressure washer pump
underneath base of motor look for a plug wuth a square slot,i normally use a 3/8" extension with ratchet.
Aug 20, 2013 | Troy-Bilt Troy - Bilt 020245 Pressure...
My Troy built 2700 power washer won't start. it's been 8-10 months since I used it last. I bought it 2 years ago.
99% of the time is the fuel that has unstabled in your carburetor you can try to clean it but replacing would be recommended.
Aug 05, 2013 | Briggs Stratton 198347gs Pump Assembly Kit...
Oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
May 17, 2009 | Briggs & Stratton Garden
Troy-Bilt 2550 20293 pressure washer not producing pressure. Worked when last used 2 months ago. Pump pistons are moving up and down when engine is pulled through. Inlet water is flowing through pump but...
ok I wasnt satisfied w/ the previous answer so I did some digging. I took off all the hose attachments and drained the line. I then checked for any clogging in ALL the screens. As usual the wand screen was clogged. this is an easy fix w/ a safety pin, but an easier fix is to replace it w/ stainless screen, or alum. The majority of the gunk is Rust. Anyway take the bottom piece off w/ a 6mm. allen key and remove the 5 bolts holding on the casting. (this will expose three pistons on the underside of the motor.) if it dont bust loose use any type of dead blow to knock the seal loose.(should come off easily). Once inside check the o-rings and make sure none were pinched during assembly. Now when I got to this point I started to think,"maybe I'm in over my head". Then I wanted to see if the pistons moved up and down. so I tug on the pull start and she was hydrolocked. so I popped off the spark plug pull a couple of times and notice all was well w/ the 3 pistons, which moved very freely. Then I proceded to put the cast piece back on using a tire tightning pattern. after all is put back together and tightned and turned on, check for pressure if nothing is better I'm sorry. but mine worked and now I'm washing my quad. peace in the middle east, randy
Mar 28, 2009 | Garden
Garden Logo
1,097 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
