Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424
Freezer problem i have kenmore freezer .my son put ice into the unit last night and the door didnt close all the way we noticed the problem around 11am this morning ,now the freezer doesnt seem to be getting cold.is there a thermostat or someway i can raise the temp there doesnt seem to be a dile inside.if not approx how long should it take to refreeze items that were in there thanks tom wanless
    Sniper:
  • 73 Answers
Dear it depends upon the temperature settled, but i think that the problem is with the gas leakage in your freezer, thats why it cooling is geting week, so , it is better to call a mechanic to check it properly.
Best regards
Posted on May 25, 2009
Door on new Kenmore freezer hard to open ... could this be a leveling problem? I wouldn't think it is an ice build-up problem since the freezer was only installed last Friday (9/24) and the ice maker is...
Check thoroughly for any obstructions, shipping tape, remaining pieces of plastic, in and around the doors, door frame, cabinet frame that the door contacts when closed, and around the upper and lower hinges. Do you hear any noises when opening or closing the door? Do you see the door rubbing on the inside liner as you open or close the door? Were the doors removed and replaced in moving? This last one, if it is the case, check the alignment at the upper hinges, loosen but dont remove the screws, and adjust the door away from center.
Sep 30, 2010 | Freezers
Temperature Alarm
although you could just close the door and it should right itself,could it be the right time for a total defrost and clean.all the drains/vents.....auto defrost only does the inside of the unit,
Jun 24, 2010 | Frigidaire 13.7 cu. ft. Upright Freezer...
Moisture forming on inside of freezer
is there anything that's preventing the door from fully closing( too fully)? the door gasket might be the culprit (problem).
May 04, 2010 | Frigidaire 13.7 cu. ft. / 388 liter...
FREEZER MAKING ICE, BUT FOOD IS THAWING
If you have a Freezer on the top model Kenmore, with warm temps in the fridge, AND water dripping onto the top shelf of the lower fresh food compartment (FFC), this is usually caused by a clogged defrost drain. Since Kenmore is not an actual manufacturer of anything, they take other brands, i.e. Kitchenaid, GE, Frigidaire, etc., take their names off and put on a shiny Kenmore nametag. This is a common problem with Kitchenaid refrigerators. You can determine if your Kenmore is made by kitchenaid by looking at the model # tag. the first three digits will indicate the manufacturer, Kitchenaids begin with the sequence, 106.*.If this is indeed how your model # begins, keep reading. Since the water cant go down the drain tubing to the pan at the bottom of the unit, it builds up on the freezer floor, eventually blocking the air return vents from the fridge to the freezer, and the vent from the freezer to the fridge. YOu can check this very easily. Look at the ceiling of your FFC, near the back. toward the sides you will see two square holes, about 2" square, stick your finger and feel around the inside of those holes, do you feel any ice/frost, or do you just feel styrofoam, you might even see frost/ice below the level of your ceiling? This drain usually gets clogged with defrost water that does not completely drain, then of course it freezes, eventually plugging up the drian hole located at the level of your freezer floor, behind the back wall. The water keeps accumulating, and freezing, on the freezer floor, eventually filling in and clogging the air vents..no air flow , the fridge wont cool. The easiest way to resolve this, empty out all contents and store someplace cold for 24 hours...a 2nd fridge, outside in a cooler if its cold like here in chicago. After its empty, unplug, open both doors and blow a fan for 24 hours. Prepare for an abundance of water due to melting ice.
After you defrost, you can plug it back in and it will be fine, HOWEVER, I suggest you take the back freezer wall off, you might have to take a floor cover off first, likely 2-4 screws in both the floor and the back wall. When you have the evaporator exposed, you will see a black cal rod defrost heater underneath the evaporator, as well as your drain hole just to the right of center underneath both heater and evaporator. Take a piece of 12-14 gauge solid, not stranded wire, removing the insulation and exposing the entire 6-8" piece of copper wire. wrap the wire around the diameter of the cal rod heater, 3-4 turns should be sufficient, and stick the other end of the wire down that drain hole. This will melt any ice that will build up in the future, everytime your unit goes into defrost cycle, so this wont happen again.
If air vents are clear of frost/ice, next thing to check is the back wall of your freezer, does there appear to be frost/ice/snow on the back wall? If so, your unit is not defrosting. On most Kenmores, this is usually caused by your defrost timer, located in the canopy mounted at the top of the FFC on Top freezer models, or your defrost thermostat, which is clipped onto the evaporator coil inside your freezer. Again, if its a 106 model Kenmore, this thermostat will have a pink and a brown wire coming into/out of it. My suggestion, if it isnt defrosting, change both. tjhe defrost control will connect with a plug, but you will have to hard wire the thermostat, ( cut wires from old, strip wire, and connect using wire nuts and electrical tape.)
Since y ou mentioned the water accumulation, more water recently, my diagnosis would be the former versus the latter, as the lack of actual defrosting coincides with lack of defrost water, however I'll never say never.
If your unit is a side by side model, check for ice on freezer floor...clogged drain. Check again for frost/ice on back wall, not defrosting, check same two parts, (the heaters rarely go bad on Kitchenaids, but never say never) You should also check for air flow into fridge, even if no frost / ice visible on back wall. Open the FFC door, and locate the air vent near the top, back of the fridge, on the left wall. While depressing the door switch, AND WITH THE FREEZER door closed, put your finger/hand near that vent. Do you feel any cold air? If you dont, you could have a bad door damper, not uncommon, or a bad damper control--> the temperature control WITHOUT the off or "0" position.
If any of this seems a bit overwhelming, I suggest you have a reputable repair technician check your fridge.
Oh, and lastly, you WILL NOT have two compressors, one for each compartment, nor will you have two sets of defrost heating elements, one for each half.
ALL cooling for 99% of refrigerators made in last 25 years takes place in the freezer, with the fridge being an empty box, except for an air intake vent, and an air exhaust vent which leads directly back into the freezer. When a refrigerator unit seems to still be cold in the freezer, but not cold enough or not cold at all in the FFC, its ALWAYS going to be caused by lack of air flow. But as you can see, there are a few things that can cause that lack of air flow.
Apr 05, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Kenmore side by side water leaking from freezer
You can buy a kit from whirlpool. In the kit is a metal tab that mounts onto the defrost heater. It is long enough to go into the hole. When the heater comes on for defrost the heat transfers down to the hole and keeps it from getting plugged up with ice. Part number 819043
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 05, 2010 | Freezers
Top coil in upright freezer icing up
its a manual defrost freezer, it is normal to ice up, if it is unusually more than you have noticed over the past 40 years, see if the door liner is cracked around the screws under the gasket, if so put some washers there to reseal the door liner
Nov 01, 2009 | Freezers
Upright freezer door inside developing ice
The door seal is at fault. Regardless of the small tear it is not sealing well.
Take a dollar bill and close it in the door. Then pull on the bill to feel resistance.
You will find it pulls easily in some place. That is where your air leak is that is causing the condensation.
Do this about every 6 inches all the way around the seal.
Mar 27, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore upright freezer not cold enough to freeze
Sounds like a door seal that isn't sealing all the way around. That would be my first replacement. Is the unit level back to front and side to side? Is it really full of food?
Call your local appliance parts house and get a magnetic door seal first. They aren't that expensive. But make sure you do not have the freezer overloaded, which could account for the lack of that vacuum sound.
Finally, is self defost? Even if it is, a lot of times the vent on the bottom in the back gets packed with ice. If it is, remove the food and use a hairdryer, being carefull to unplug the freezer first. Melt all that ice and empty your overflow tray at the bottom underneath.
Mar 07, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frigidaire Frost Free Commercial Freezer
The drain has most likely frozen over. It is at the bottom behind the back panel inside the freezer. You will need to remove all of the ice and run hot water down the drain until it is clear.
Nov 16, 2007 | Freezers
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424 Logo
229 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
