Question about McCulloch MCCFH180B Electric Pressure Washer
Pressure washer leaks
The pressure washer McCulloch 1800 psi FHH1 18a)leaks water from the side of the power washer motor. It leaks no matter if the washer is on or off. My guess is that there was some water left in the pressure water over winter and this caused a seal to break, can this be repaired? Do I have to by a whole new assembly? The pressure washer works fine, it just looses as much water as it sprays while the hose is hooked up.
  • 104 Answers
I had a Karcher water sprayer that did the same thing , the repair man told me it could be repaired IF he could get parts , guess what, he COULDNT get parts so i had to buy another one , the answer to your question is yes they can be fixed provided you take it somewhere that can get parts . hope this helps
ps i could have fixed it myself with the right part, its not a hard job to strip it and rebuild it
Posted on May 26, 2009
Is the power switch for the FH180B replaceable?
  1. McCulloch napa auto parts Pressure Washers Problems ...
    www.fixya.com > Forum > Tags > napa auto parts > Pressure Washers
    McCulloch pressure washers napa auto parts related questions and answers. ... a 7022-140a02 power switch for a McCullouh high pressure washer FH180B.
Jul 22, 2015 | McCulloch FH180B - Pressure Washers -...
Switch power on and it works and then it switches off and will not switch back on until you leave it for period of time and then it powers up again
This is an indication that it is overheating in the motor. When this happens, very carefully check the temp of the motor and see if it is too hot.
Mar 02, 2014 | Karcher 16017720 K3.690 X Series 1800 PSI...
What is the price and types of the pressure washers and where can i buy it?
Hi mary
About the price i think Mr JERRY is true
About the types there are many types like : -
- 2000 PSI Electric
- Gentron 2200 PSI Gas Pressure Washer
- Gentron 3000 PSI Gas Pressure Washer
- Gentron 4200 PSI
- 1600 PSI Electric Pressure Washer
- 2000 PSI Electric Pressure Washer
- 2200 PSI Gas Pressure Washer
And about the place you can buy these products, you can find many depots online like : -
http://www.generatordepot.us/pressure-washers.aspx
Thanks
Oct 30, 2011 | Garden
When using the sweep nozzle (yellow tip), the pressure starts and stops but the machine works fine when using the circluar nozzle(red)
usually when the power washer pressure stops the machine is running out of water. the sweep function uses a little more water than the round wash tip. Make sure there are no leaks in the supply hose and that the supply faucet is turned on all the way and has plenty of "flow". also make sure the water connection at the washer is not leaking. use a new rubber washer to make a good seal on the supply hose on both ends. if either end leaks or can **** air, just a little bit of air into the pressure washer will cause it to loose pressure.
Apr 20, 2011 | Briggs & Stratton Briggs Stratton 1800...
I am looking for a nozzle for a Mcculloch 1800 psi model FH 180B Can you help me? Thank you. Ken
http://ipl.ordertree.com/ipl/604/FH180B%20(DSC).pdf
There is the link to your breakdown, choose which part you need, then I would call them direct and have them send it out. Their Number is
1.800.521.8559
Let me know if this helps~!
Nov 23, 2010 | McCulloch Garden
Mcculloch power washer fh140A 1400 PSI help
the unit will only **** up solution when the pressure is low, thats how they all work so you cant use pressure at the same time. You will notice that the pressure drops when using the solution ****..
soap 1st the pressure wash.
Jul 02, 2010 | McCulloch FH140A Electric Pressure Washer
1800 power washer will not run - power is getting to on/off switch
Maybe just the pressure switch is stuck or you have trapped pressure in the lance. Try without the high pressure hose and then activate the pressure switch on the side of the pump as this may not be letting the machine to statr if its stuck.
Nov 12, 2009 | Campbell Hausfeld 1800 PSI Electric...
Motor runs fine but not pressure other that from garden hose.
you have a unloader or bypass valve on the machine & it sounds like that is sticking.
take out and lubricate
Jun 17, 2009 | RTO 1800 PSI Pressure Washer
McCulloch MCCFH180B Electric Pressure Washer Logo
484 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
