Question about HP PSC 1510 All-In-One InkJet Printer
Spooler my printer says the spooler is turned off how do i turn the spooler on
  • 495 Answers
Go to command prompt by pressing windows + R and the type "net start spooler".
Posted on May 25, 2009
Trying to print which it won't. It says that the printer spooler is not running and that i need to restart the spooler or the machine...i have no idea what the spooler is but i have unpluggd the printer...
From the Start menu, select Control Panel. Then follow this path:
Administrative Tools > Services > Print Spooler
Once at the Print Spooler, right click on it. Select Stop. Leave this window open. Turn off your printer.
At the open Print Spooler window, right click on the Print Spooler, and select Start.
Go to the Start menu, and select Printers & Faxes. Find the printer you are having problems with and double click on it. From the menu, select Printer, then select Cancel All Documents. The documents should clear.
Turn on your printer. You sould now be able to print.
Jul 11, 2010 | Computers & Internet
Spooler turned off
The print spooler servie might be turned off.
Click on start go to run type services.msc
locate print spooler double click it and then select startup type automatic and then click on start. close all the windows, restart the computer and then try again it should work.
Jun 22, 2010 | HP Photosmart C5280 InkJet Printer
Printer keeps printing same pages. how can this cycle be stopped?
1- Turn off your printer
2- Go to Start, All Programs, Accessories, and then RIGHT CLICK "Command Prompt" and select "Run as administrator". The terminal black screen will be opened.
3- Type NET STOP SPOOLER and press they Enter key (you should get a message confirming the spooler is stoped now)
4- Now in the same black terminal screen (see step 2) type NET START SPOOLER and press the ENTER key (you should get a message confirming the spooler is started now)
5- Restart your computer
6- Turn on your printer
Thank you
TechSaver
Feb 07, 2010 | Epson Office Equipment & Supplies
The spooler has turned off ... how can I turn it on so I can reload my printer??
Go to Administrative Tools > Services and make sure print spooler is set to automatic and is turned on. If it's a Lexmark printer, the service LexBce also should be set to automatic and turned on
Feb 06, 2010 | Lexmark X5150 All-In-One InkJet Printer
Says printing but won't print
After resetting the spooler, I had to reboot the computer for the printer to work.
Jul 22, 2009 | Office Equipment & Supplies
PRINT SPOOLER IS OFF
go to the run box and type
net start spooler
note: There is a space between the words above
Should be good.
or start, control panel (classic view), administrative tools, services, scroll down to
" Print spooler "
Stop and re-start it here
Regards
Richard.
May 20, 2009 | HP PSC 1510 All-In-One InkJet Printer
Lexmark X1185 all in one
remove the previous install of all software and then try again unhook the power from the printer tho first and unhook the usb cable
hopefully it will install so you can turn the spooler on
Aug 12, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
"Error 1068 Could not start the Printer Spooler on local Computer"
ahah..first things first...what Windows Operating system do you have...??
Feb 10, 2008 | Lexmark X1270 All-In-One InkJet Printer
Both power & feed lights flash
Information gathered: Basically the printer carrier has stalled.
Lexmark documentation states that you should turn off your printer and wait a few seconds and turn the printer back on.
Restarting the spooler will sometimes do the trick as well.
Go to start, run
type: <cmd> without <>
Command prompt will open up.
Type: net stop spooler
The spooler will say it stopped successfully.
Type net start spooler
The spooler will say it started successfully.
Hope this helps!
Jan 20, 2008 | Lexmark JetPrinter Z22 Color InkJet
X3470 printer installation
One of the most possible reason is related to Print Spooler service. Please check the "Print Spooler" service if its turned on. if its not you can turn it on. Here is the way to go Services screen
  • go to start menu then run and type "services.msc" then hit enter
  • locate the Print Spooler service in the services list
  • Change turn it on  switch to Automatic mode
Try reinstall
Good Luck
Dec 29, 2007 | Lexmark X3470 All-In-One InkJet Printer
HP PSC 1510 All-In-One InkJet Printer Logo
51 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
