Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag mdg5500aww dryer does not dry
Maytag mdg5500 dryer goes through several cycles of proper operation.
Ignitor glows and gas flows. After three cycles, the igniter will turn on, but there is no gas flow.
Air flow is strong. I suspect either the thermostat or the radiant sensor.
Any suggestions will be greatly appreciated.
Thanks
5 Suggested Answers
  • 77 Answers
SOURCE: maytag gas dryer, no heat, ignitor wont glow
The machine will check all safety features first. check the overlimit by the burner. It may have a reset. If not, turn power off and check continuity (ohms). Good luck.
Posted on Apr 18, 2009
  • 97 Answers
SOURCE: Maytag Neptune Dryer taking hours to dry a load
Hello Friend, Your solution is simple. It sounds like your dryer is working properly, and your actual problem is a blockage somewhere in your 4 inch exhaust tubing. Check it and make sure it is not clogged up with excessive lint. Also if your tubing is clear you need to check your connection where it travels thru the wall etc. It would be a good idea to find the actual location where it exits to the ouside and check for good airflow. Your dryer is equiped with a safety thermistat and if you are not getting the proper exhaust flow the burner will cut off and restart in the manner that your's is doing. I Hope I have helped you, Tim. And please don't forget to give me your rating for my help.
Posted on Jul 11, 2009
  • 205 Answers
SOURCE: I am trying to find the proper way to remove and
HI- First make SURE the machine is unplugged. Open the door and on the inside of the door frame you will see 2 screws on each side (2 of them go though the door hinges), remove these screws and pull the front panel forward from the top, it will hinge from the bottom and you can pull up on it to take it off. On the right bottom you will see the valve, ignitor and burner assembly. Locate the ignitor on the Left side of the burner, behind the valve, and use a 5/16 in wrench or socket to loosen the bolt that holds it in place. Unhook the wires and plug in the new one. Be very careful not to hit the ceramic part of the ignitor on anything or it will break, very easily. When you put it back o the bracket make sure it is all the way back and seated correctly. Reverse process. You can actually run the machine without the front panel on to see if the ignitor is working; just make sure the door is closed. Hope this helps, be careful.
http://www.reliableparts.com/models/49863
Posted on Sep 24, 2010
oldTech2332
  • 2341 Answers
SOURCE: I have a Maytag Atlantis gas dryer, model
The problem is going to be that coils on the gas valve.It is pretty common for the coils to open gas valve when cool but once dryes runs and the coils heat up they will not open gas valve. the coils are the black plastic parts on the gas valve held down by a bracket, one has 2 wires the other has 3 wires in the plug on them. To replace them remove bracket over top of them(dont worry the bracket that says dont grip is for when dryer is plugged in you will be potentially shocked if gripping when plugged in but to repair when unplugged no danger)pull off of the plug and install the new ones,the bracket has a notch and the coils have a corosponding tab they interlock to positon coils correctly.
The part # for the kit that contains both coils is 279834 and sold for under $20.00 from your local appliance parts store on online at;
assuredparts.com
apdepot.com
appliancepartspros.com
repairclinic.com
I hope this will help you to repair your dryer,
Gene
Posted on Aug 08, 2011
Maytag Gas Neptune Dryer MDG5500AWW no heat
see this causes and fix it. God bless you
Dryer tumbles, but there is no heat
Sep 27, 2012 | Maytag Neptune MDE5500AY Electric Dryer
I have a maytag Mdg5500. When I turn the dryer on the ignitor glows gas valve opens and I get flame for about 20 seconds and then it shuts down. It will then retry after about 1-2 minutes. Also the...
While i understand that you cleaned the lint build up from the dryer,the problem your experiencing sounds like a airflow issue that is causing the flame to starve for air and the flame is blowing out. In addation to possible lint build up the things that will cause poor airflow are;
The blower wheel being bad...do you fell any air flowing out the back of the dryer?
A blocked/crushed vent..if air flow from back of dryer is their airflow close to equal volume of air flow where the vent goes outdoors?
You can disconnect the vent from the rear of the dryer temporarly and see if it works better with the vent off to check it
Good luck,i hope i have been able to help you fix your dryer,
GENE
Sep 04, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer (model MDG5500AWW) will not heat.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 09, 2011 | Maytag Neptune MDG5500AW Gas Dryer
My Maytag Neptune dryer model mdg5500aww has no heat when running . ignitor never gets red. there's gas to the unit and 110 volts. there really not much lint in there. is the problem the flame sensor?
heatman101
Dec 15, 2010 | Maytag Neptune MDG5500AW Gas Dryer
NO HEAT MDG5500AWW 56780829AX DRYER TURNS BUT NO
heatman101
Dec 06, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Lights once then not again
Hot Surface ('Glow Bar') Ignition System glow-amin.60x20.gif (most common)
This is the most popular system currently in use and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve. What happens in this style control system is that the thermostat or electronic control supplies power to the oven ignitor and gas valve which are connected in series (one after the other). As power flows through the ignitor it heats and allows a specific amount of current to flow to the oven valve which is in the same circuit. If the oven valve senses the proper current flow, it opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 20, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Jul 11, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Stops heatinng
Hi, first thing to check is the venting. If the vent is plugged, it will cause the heat to short cycle.
If later in the cycle, the ignitor glows but will not ignite the gas, you will need to change the coils on top the gas valve. This is a common problem.
Please let me know if I can assist you further.
Thanks
Vic
May 24, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag gas dryer model#NDG2330AWW heating problem
your gas coils are bad. they open up for the first cycle but fail to after. Replace your coils and this will solve your problem
Dec 13, 2008 | Maytag Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
159 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
