Question about Kitchen Ranges
We had a power outage to our home, and when the power came back on, the F1E1 error light came on, and it will not reset. It keeps beeping and none of the controls will work.
  • wagner_garre May 25, 2009
    all guru,
    Where is the ERC located, and do you have any idea how much it costs?
    Gary
  • 3,230 Answers
This it the proper solution for your problem:
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Good Luck
regards
all-guru
Posted on May 25, 2009
  • Mukesh Kumar May 25, 2009
    It's the internal chip that control the display board.
    it cost aprox. 50 usd + fitting
Oven is two weeks old. Town had a power outage we reset at breaker but still just beeps once and nothing happens
power outages cause power surges when the power comes back on
this surge generally manages to fry the power/control board
I suggest that you get the services of the service centre to come out and check it out.
May 30, 2015 | Bosch 27" Double Wall Oven HBN56
F9 error message after power outage
The F9 is a door lock latch circuit problem, either the motor latch or the control/power supply board will need to be replaced.
Mar 22, 2008 | Jenn-Air JES8750 Electric Kitchen Range
After a power outage, I have to unplug it, otherwise it stays on and keeps recycling. Reset?
The power outage, can be caused by an over voltage, or after the power came back there could have been a spike.
It must have damaged something in the logic or in the power supply. Ask a repair store to fix it.
Mar 16, 2015 | Audio Players & Recorders
Hello I have an HMCF7W1 Magic Chef freezer, after a power outage the power light comes on, but the Run light will not turn on and everything is thawed. What can I do?
Perhaps the power outage, was caused by your freezer?
When you think a reset would help, the run light should come on, after a little while. But perhaps only the thermostat is defect.
Be aware there can be so many causes, and none has to be related to the power outage, for your freezer not to work.
It would be virtually impossible to see what is wrong, from a distance. Better try to bring the food to a working fridge and call a tech to solve the problem.
Feb 08, 2015 | Magic Chef Freezers
F1e1 error codes
Check the harness from the ccu .If all in tacked replaced the ccu.
Apr 29, 2014 | Whirlpool duet Washing Machines
F1E1 error happened repeatedly, jenn air says cut
F1 - E1
EEPROM checksum error
1.
Note: Applies to all F1-E...
codes except F1-E3.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Jenn
Air Range / Stove / Oven Fault Codes#ixzz19GMNtS3r
Dec 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
I Have aINSPIRON 531S AND WHEN I PRESS MY KEYS THE COMPUTER IS BEEPING AND THE RESPONSE TO THE KEYS IS SLOW.ALL THIS TOOK PLACE AFTER THE POWER WENT OUT AND CAME BACK ON. WHAT IS MY PROBLEM
assuming that none of your keys are stuck, unplug your power supply connections for a couple of minutes and reconnect. It could be a problem with the ram. Always make sure that you have surge protection for your pc. A power outage can permanently damage the hardware in your computer.
Jan 09, 2010 | Microsoft Windows Vista Home Basic for PC
F1 error will not reset. unpluged for hours and still f1 and beep
HI. this is an unfortunate Electronic oven control failure. This will require you to replace the entire control Board in this unit. it has failed.
F-1---{Electronic oven control failure}--{replace EOC/CLOCK}
Jun 12, 2009 | Frigidaire Ovens
F2 and beeping
The F2 error is the user control board gone south on you, a new board will fix the machine, as always do you own your home and does the insurance cover appliances?
Sep 05, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Range RF367 Error Code F1E1 appears when attempting to turn on oven.
Hi Rooster,
I would need the complete model number to give you a price and part number for the ERC. Just let me know if I can help you more.
Mike Anderson (Owner)
Anderson Appliance
(865)945-3808
Aug 31, 2008 | Whirlpool RF367 Electric Kitchen Range
Kitchen Ranges Logo
67 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
