Question about Worx GT WG150 10 in. 18 Volt Cordless String Trimmer w/ 1 battery
How Does the line feed?
I have used the the trimmer but line doesn't refeed. It backs up inside
    Scholar:
  • 72 Answers
The line must have been rolled in the wrong direction, I guess it is an ordinary "tap and go" solution. Maybe it is possible to install the line roll upside down? It could be a good idea to double-check.
Posted on May 25, 2009
Gh1000
There is a spring inside the button on bottom. If it is missing broken or not seated properly the line will feed continuously.
First try tapping the bottom to set the button. Then inspect the line feed assembly.
good luck
May 05, 2013 | Black & Decker 14" Grass Hog Xp...
How do I change the line on my 25 cc homelite zip start trimmer
1) Use a pair of vise grips to open the wheel on the bottom of the feede;
2) Remove the wheel, taking care not to lose the screw inside it;
3) Remove the outside wheel, feed line into one of the interior wheels and wind it around until the wheel is full following the direction of the arrow on the outside. Leave enough line (4 - 6") to feed out the holes;
4) Repeat for other wheel;
5) Replace wheel, feeding excess line into outside wheel holes on wheel frame still attached to weedeater;
6) Hold wheel together tightly and reattach wheel hub. Hand tighten only as it will tighten itself with use and require vise grips to remove again.
Hope this helps.
Nov 01, 2010 | Homelite Mighty Lite Lawn Trimmer
Line doesn,t feed automaticly
The line may be on backwards or has developed a knot. Debris may have worked its way inside the bump head preventing it from functioning.
Check out these items.
Best regards
Mike
Aug 20, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
My weedeater with auto line feed will not stop feeding the line when in use.
Did you ever get an answer to this problem? I'd like to know because I have the same problem with my cordless 14" Black N Decker Gass Hog. I rethread it, but the line continually feeds and is out in about 2 minutes.
May 03, 2010 | Black & Decker String Trimmer Cordless 12"...
Troy built weed eater won't feed line
Check the size of the line,(OD), make sure you are using the correct size, sometimes cheap line will be problematic, also, you said you are re-stringing it, try a new batch of string, the old string inside the hub can get chaffed and will stick to itself...
Aug 22, 2009 | Troy Bilt Tb70ss Gas Trimmer
Echo trimmer with bump feed is not feeding
Sadly, they do wear out..... but sometimes they're just stuck. The line can refuse to feed if the line is caught on itself in the spool winding, or if the head is bad. Try this: remove the spool and clean it pretty good. Check that the line isn't caught on itself in the spool. Sometimes it just locks itself in between wraps, and you have to pull it out of the groove to get it to continue to feed. Give the inside of the spool a liberal dose of graphite powder. Put the spool back on with line. Bump it against the ground as much as you feel necessary to further distribute the graphite. Now, push the spool in as if to feed line, and pull on the line. It should feed a bit and stop. If it does, you're good to go. If not, replace the spool.
Best regards. Hope this was helpful to you, --W/D-- Please feel free to rate this solution! Thanx!
Jul 30, 2009 | Echo Garden
Line gets tangled in gear under feed spool
Problem solved. We noticed something was broken off a small part inside the spool holder. My husband took it to the local hardware store, and one of the employees gave him the part from a trimmer that had been returned.
Apr 06, 2009 | Black & Decker St7000 13'' Automatic Feed...
12 volt grass trimmer/string breaking
Just a reminder, do not use cordless string trimmer as heavy work.
Aug 29, 2008 | Black & Decker String Trimmer Cordless 12"...
Worx GT WG150 10 in. 18 Volt Cordless String Trimmer w/ 1 battery Logo
441 people viewed this question
Top Worx Garden Experts
Tim Whalen
ray gallant
Wayne McNeil
Are you a Worx Garden Expert? Answer questions, earn points and help others
