Question about Toshiba e-Studio 350 Copier
Print a part of paper
How to change the develper
  • Toshiba Master
  • 643 Answers
I will recommend to do a negative post copy. Then check whether solid black or not. If not solid or blur, then the developer material might be dirty or not enough where u need to replace. If only certain area, such as top or bottom part not solid or blur, it might be caused by the roll guide also where u need to replace it.
To replace developer is very simple, take out the waste toner box, unplug the connector on the developer unit, loose one screw, and u can take out the unit. On the unit, take out the 2 screws, and u can open the cover.
Posted on May 27, 2009
How can solve km 8030 paper ground clear fault??
my dear you chek develper unit and clean unit
and grid wire change
Feb 21, 2015 | Kyocera Km-8030 With Feed, Bank, Print,...
How to reset error code c21 in the Toshiba e studio 166?
how can to reset error code c21 my toshiba e-studio 166 printer
Feb 28, 2011 | Toshiba e-STUDIO166 Printer
Minolta EP2010 CSPro copier: Where does the develper bottle go??? I see the Toner MT 102a bottle but where does the Develper bottle install. Or does the toner bottle already have the develper filings?
When the developer is added during normal replacement, the developer bottle is installed in place of the toner bottle. Then when the F8 mode is initiated from the service mode the developer is added into the developer unit and automatically calibrated. This is only done after the old developer has been cleaned from the DV unit.
The toner bottle contains no developer. The developer is replaced separately and only needs to be changed about every 80,000 pages.
Good Luck and Thnak You for using Fixya.
Sep 21, 2010 | Minolta Office Equipment & Supplies
Copier working fine. moved from one office to another. now no print. pages come out blank. what could we have done?
Check the high voltage unit.Remove and clean the transfer / separator corona unit.
Aug 12, 2009 | Xerox 5855C Copier
Prints aren't plain, it have some texture like crayon
its problem of toner
its of good quality
and also check proper supply of toner into develper assembly
trying to add some extra ink directly in developer assembly
if problem solve
check
cartridge motor running
and supplying toner proeprly
May 24, 2009 | Xerox DocuColor 12 Color Copier
4x6 glazed paper does not print
You need to change the paper size in your computer
Click on file
Print
Properties
And under general tab change the paper size as well as the paper
tray
and Print it
Your all set ..
Mar 22, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper jam when trying to print envelopes.
You need to make sure that your print sriver setting match the setting on the printer itself.
If setting are changed on the printer itself to envelopes then when you go to print click preferences button on print screen and look for a place to change paper type (usually defaulted to letter size.) Change paper type to envelpoes and click ok. Click ok again on print screen and it should print correctly.
Paper types must be configured the same on the device as well as the print driver installed on the computer.
Hope this helps
TankMurdock
Mar 09, 2009 | HP Photosmart D7260 Printer
My HP C7200 printer won't print from the photo tray
If you using a mac: After choosing the Photosmart C7200 to print your file on the print preview, change PAPER SIZE to 4x6, then lower down, change from PREVIEW to PAPER TYPE/QUALITY, more options will open underneath, on SOURCE, change from MAIN TRAY to PHOTO TRAY. You should also change the PAPER TYPE to some kind of PHOTO PAPER (whichever one your using, but the standard seems to be HP ADVANCED PHOTO PAPER)
Jan 27, 2009 | HP C7200-69016 Network Adapter
Toshiba e-Studio 350 Copier Logo
71 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
