Color distortion I have a 73" Mitsu DLP that is about 2.5 years old. I have already replaced the lamp once, about 6 months after I bought it. Recently I have noticed a distortion with the color. There seems to be a LOT of noise on the screen, where backgrounds look almost like a photo negative with pinks surrounding it. Faces look the same way. I have played with the color noise and it doesnt seem to help. I have even tried to decrease the magenta level and it doesnt seem to help. any suggestions? My TV is making a loud buzzing noise when there are graphics on the screen or if there are bright colors. There is also an aura around the offending picture.
techman
  • 3130 Answers
SOURCE: dark picture (HELP)
Open up the back of the set but be very carefull. Notice a large black block with a large red wire that runs up to the picture tube. on one side of that large block where the thick red wire is comming out of are two controls, one should be marked focus or F and one should be marked screen or S. With the set operating normally and not touching anything else, slowly turn the control marked screen or S clockwish till the picture gets bright enough. If you go too bright the set will shut down or you see small thin white lines so back down on the control. then touch up the focus and your good to go. good Luck.
Posted on Mar 20, 2007
jerryg50
  • 1689 Answers
SOURCE: 46" Samsung DLP Lines & Freeze up
This is a possible fault in the power supply, and can be a problem with some decoupler caps on some of the boards. The vertical bars and unstability are usually attributed to having high frequency noise and or clocking pulses crosstalking on to the power distribution lines that run through the boards. This can be switching power supply noise, or cross-talk from clocking pulses.
Another thing that can cause your described fault is unstable clocking between the devices that are reading and writing to the data busses. There are a number of data busses running through the set for the boards to be able to communicate with each other.
The tech will use the process of board swapping to service the set, and then do the adjustments as necessary to make sure the new boards match up.
Yes... DLP sets are fairly expensive to service!
This is my personal opinion. If the set is out of warranty, I would change for a Plasma or LCD set. If you compare the performance of these to ther DLP, the difference is very big. From what I am seeing from a service point of view, the DLP's are lower in reliability.
Jerry G.
Posted on May 06, 2008
  • 13433 Answers
SOURCE: Color Tv
Well im not sure what can be done about it, our tvs also have a little buzz in them, my laptop also has a background buzz very silent one, if I plug my headphones directly into my computer, I get the same buzz from there also, but when I plug my headphones into my lcd screen there is no buzz, there seems to be somekind of a filter or amp which filters the buzz out and the sound is clear.
this is not really a fix, but I feel the buzz is normal, I suppose it could be cleared out by somekind of a filter or amp between the source and the speaker.
Posted on Aug 11, 2008
  • 58 Answers
SOURCE: Samsung DLP TV has lot picture. Makes a Humming sound
That sounds most like the color wheel,
to change that you need to have some skill in electronics, I would recommend to take it to a shop
Posted on Apr 25, 2009
SOURCE: color distortion
I have a 2005 73" dlp . Your light engine is going bad ! soon you will have a pyschadilic light show then total failure. I've replaced 3, Mitsu paid for all of them. But its getting very old.....I'm about to replace a fourth as soon as i can get it scheduled. Don't wait too long to order it . it can take up to 3months to get it.
Posted on Jun 24, 2009
My Mitsubishi tv WD 73734 won't show a picture you can hear sound and it powers on and off lamp light red and timer lighter blinking
No TVs will behave that way due to a timer. TVs only will display a nag screen telling you to reset the timer. If your lamp is more than 2 years old, it is suspect of failure. Be sure you buy a lamp with an Osram brand or Philips brand bulb inside. Any compatible(knockoff)lamps will not perform as they should. Mitsubishi DLP TV Bulbs
These folks sell original Osram bulbs in their lamps and they have a 6 month warranty. I use them myself for repairs and really have had great experiences with them.
Sep 09, 2015 | Mitsubishi WD-73734 73" Television
Just paid to replace the lamp 2 weeks ago in our mitsubishi 73 dlp 1080p tv purchased a 5 year in home contract with Tweeter Sevice net 1/2008 lamp fixed and picture is once again great but now the 73...
Mitsubishi that the one,who u should contact.Talk to them make some kind of deal with them to help u to do a repairing or replace the tv Light Engine Projection Block.That the tv problems,this problems a design flaw on the tv Light Projection Egine Block the IC they put in that causes of this white spots are showing up will continue showing up more and more white dots.It will not stops.
Sep 03, 2011 | Mitsubishi WD-73833 73" HDTV
I have a 2 year old Mitsubishi WD-73732 - 1080p 73" Medallion Series DLP HDTV - WD73732. I am getting blotches of color when there are large areas of blue color. Looks like irregular moving stains...
It will cost you probably in the area of $700.00 to replace the Light Engine. I don't think it would be a good idea to repair it. DLP sets have been out of production a few years now due to high failure rates of the light engines for all makes and models and the consumer cost for the lamp.
Nov 10, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
LAMP JUST WENT OUT
I have a 57" DLP and have replaced the bulb 3 times in 2&1/2 years. I'm not possitive but I think I have 6-800 hrs on it total. Mitsubishi claims it a part they expect to go out, but the told me they typically last about ten yrs. If you have proof of purchase they will send you a new one for free, otherwise it'll cost you about $150 on ebay.
May 29, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Color distortion
May 16, 2009 | Mitsubishi WD73727 73" HDTV
TV won't stay on
Hello Fonzell!
Regarding the tv turning, my question is, do you hear a clicking sound? if so, it's most probable tio be your ballast, that might not have enough voltage to keep on with your lamp, and that's why it shuts off.
You could try replacing it and seeing if it resolves your issue, I believe they're running around 70 dlls..
have a great one ! :)
Apr 21, 2009 | Samsung DLP HL-P5663W 56" TV
HLN507W Samsung DLp Horiz. lines
it sounds like the dmd board is failiing
Mar 13, 2009 | Samsung DLP HL-P5663W 56" TV
Mitsubishi 1080p 73'' DLP HDTV - Color distortion
This would be the little sensor on the light wheel. Its cheap, you can get them online for around $2. You will need to take the light engine out and remove the color wheel cover and remove the color wheel and then remove the sensor. You will have to desolder the sensor and remove it to replace with the new one.
What is happening is the sensor is overheating and not tracking the color wheel properly there for the colors get messed up. Once you replace the sensor the tv should work like normal. The part is
(Sharp GP2S40 Photointerrupter). It is very difficult to find because they are not made anymore. Most major online part stores do not carry them but I found a lot of them at Wright Hobbies. Good luck.
Nov 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
