Question about Mitsubishi WS-65809 65" Rear Projection Television
Wont power on
Mitsubishi 1080hd Ws-65809 Wont power on. Changed both convergence ic's. Still wont power on.
  • 6 more comments
  • Mike May 25, 2009
    Checked with meter. Not open.
  • Mike May 25, 2009
    error code 23
  • Mike May 25, 2009
    Q5A31 solder connection was loose. Re-solder connection. How can I check to see if either one is o.k.
  • Mike May 25, 2009
    I believe that the Q5A31 transistor is open. Do you happen to know the part number is. The only numbers I can get off of it is panasonic C5418. Can't find on any web sites.
  • Anonymous May 25, 2009
    light keeps blinking want power on
  • Mike May 25, 2009
    Ordered part. Will let you no if that was the problem. Thanks for your help.
  • Mike May 30, 2009
    Where can I order toshiba transistor #2SC4690?
  • Mike May 30, 2009
    Thanks. Didn't come up on search. Will try to email.
  • Mitsubishi Master
  • 8,617 Answers
Did you check the two 5 amp picos that normally blow when the Ics fail? They are F9ao4 and F9a05
Posted on May 25, 2009
  • 3 more comments
  • Sonny Berry
    Sonny Berry May 25, 2009
    do you get an error code when you press the menu and device/input button both in together and hold for 5 seconds on the front panel/ The led should blink a series of blinks pause slightly then blink the second series of blinks for a two digit error code.
  • Sonny Berry
    Thats Horizontal deflection Check The two following transistors Q5A31 and Q5A01
  • Sonny Berry
    you will have to remove them from circuit then check the pins for continuity then reverse the leads to check the same two pins again you should get continuity in one direction then none or very little when the leads are swithed on any two given pins.
  • Sonny Berry
    Thats a 2SC5418 Horizontal output transistor you can get original transistor at the following link its free shipping within the US
    http://servicemanuals.vstore.ca/product_...
  • Sonny Berry
    Sonny Berry May 30, 2009
    That same website should have that one also, they dont list them all but I am sure if you leave them a email they will most likely have it and list it for you.
Mitsubishi WS-65809 convergence problem
I know these sets very well and have posted instructions here for the chip replacement many times.
If you really need help I am in California and will be online noon until 11 pm tomorrow- (Pacific time) if you really want help post a question in the Premium section here attention SD TECH and I will help you more.
SD TECH
Jan 28, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Blurred Picture Mitsubishi WS-65809 65"
the convergence IC's will most likely need to be replaced as well as a resistor or two
electech
Oct 29, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Convergence problem I have an intermittent vertical convergence problem. I have to shut off the TV and turn it back on to get a normal picture again. Need to fix this problem. The TV is a Mitsubishi...
Good Day;
You have poor connections on your "convergence IC's. Middle board IC's on large silver heat sink. Redo solder before total failure. Good Luck, big IRISH.
Oct 17, 2008 | Mitsubishi WS-65809 65" Rear Projection...
MITSUBISHI 65"
You need to replace both convergence ICs Number STK392-570 If your model number is a WS-65809 you can get new replacement ICs at the following link and they provide instalation instruction with pics as well as free on line tech support so you can do the repair yourself.
Apr 30, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65809 65 in. Rear Projector
Bad solder connects on pins of STK convergence IC's.Replace IC's for reliability,then re-align if necessary.
Oct 04, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Convergence ics
www.matelectronics.com Check resisters (low ohmage) in front of IC's, usually discolor or change value.
May 25, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
343 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
