Question about Sony CDP XE270 CD Player
Knowing if a CD has sockets for a iPod/mp3 jack?
If i'm ordering a CD player without seeing it physically is there anyway i can tell if it has the sockets for a mp3 jack.
My terminologies not very good, but i mean using one of these http://www.amazon.co.uk/exec/obidos/ASIN/B0000992SA/ref=ord_cart_shr?%5Fencoding=UTF8&m=A2W4BJWXAWQEQO to attach my mp3.
Thanks!
    President:
  • Sony Master
  • 1,114 Answers
If you go to www.sonystyle.com then support, then type in the model # you can download or view the complete manual for the unit. Hope this helps
Posted on May 25, 2009
Will a ipod player play in my sony TA-AX301 AMPLIFIER-No sound
You need a 3.5mm to stereo phono/RCA cable
Plug the red and white ends in to any of the following sockets that are free - Tuner, Tape In, CD, Aux, Video In. They all do the same job. The names are just suggestions, they're not mandatory.
Plug the headphone jack plug in to the MP3 player's headphone socket. Turn the volume up on the MP3 player to about half way. Then select the source input on the amp that matches where you plugged the cable.
That's it. Hope this helps..
Sep 16, 2014 | Audio Players & Recorders
Can i get my ipod player to play in my sony TA-AX301 AMPLIFIER-No sound
How to play ipod on koss progressive scan
Take a look at the inputs on the DVD player. If it has an AUX input (looks like a headphone jack) you may be able to connect with a male to male 3.5mm headphone jack. Otherwise you could use a converter that goes from headphone jack to RCA (Red, White, Yellow)
Jul 30, 2012 | Koss KD305A DVD/CD/MP3 Player Progressive...
I pod wont play sound on the left speaker or
if you have already tried a new pair of headphones , and still have same problem . you probably have a bigger problem , i had the same problem with one i bought from pawnshop . i immediately took it back knowing the problem was wear and tear on the audio out jack for headphones . usually happens when people carry there ipod in there pocket and are active , the audio headphone jack ends up breaking or bending insdie . this should work work > http://www.amazon.com/Cables-Go-35508-iPod-Compatible-Connector/dp/B000J022G6 AND THiS http://www.amazon.com/Cables-Go-35508-iPod-Compatible-Connector/dp/B000J022G6 YOU COULD ALSO CALL APPLE to see if they jave anything else like this.
May 02, 2010 | Apple iPod classic MP3 Player
My Ipod Nano only has sound in one ear. when you turn the headphone jack in the socket it picks up the other sounds ear for a second then disappears. I've tried different using headphones and the samething...
Within the jack, there is a very delicate balance. The same thing happened to the auxiliary jack in my car. Since it is broken, you'll need to either see if you're eligible for an Apple warranty replacement or repair, see if a local electronics place can fix it at a decent price, or spring for a replacement.
Oct 02, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
Can i change the battery on my ipod mini
You sure can!
ipodbattery.com
You may incur some minor physical damage to your ipod (like the case) but other than that it should be fine as long as your willing to open up your ipod! I replaced my ipod video with no problems, only a few dents in the plastic case, but since ipod mini is metal, you should have less damage to the case while prying it open, and i believe you open it by unscrewing some screws anyway...
Mar 07, 2009 | Apple iPod mini M9160LL/A MP3 Player
Pioneer DEH-P670MP
Sorry to tell you, but that jack is for a wired remote. But if you want to hook up an mp3 player to it you can buy an accessory that plugs into. http://www.google.com/products?q=ip-bus+aux&hl=en&show=dd this is a link to google shopping that will have a bunch of choices if you have an ipod or not. good luck
-Andrew Hawkins
Aug 26, 2008 | Pioneer Audio Players & Recorders
Hi, I have a Panasonic SA-EN9 digital radio / CD player ect shelf system. I want to play music from an mp3 handheld player through it, and I see that there is an AUX jack in the back of it. I can connect...
Hi, I have the Panasonic SA-EN9, and if you plug your mp3 player (I have and ipod) into the auxiliary socket you should be able to play it by pressing the AUX button on the remote provided.
Hope It Helps :)
Jul 11, 2008 | Audio Players & Recorders
My headphone jack doesn't work on my iPod...
i had have the same problem.....but im tolazy to go to the stor and let is fix ......but i found a solution....my right earphone didn't worked only if i applyed preasure but i thought the jack doesnt make good contact so i put around the jack some aluminum foil and putit inand iwork perfect:P!!!!!
Apr 16, 2008 | Apple iPod MA446LL/A MP3 Player
Sony CDP XE270 CD Player Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
