Question about Hayward H Series Induced Draft Abg 100,000 Heater
1 year old hayward h1001d pool heater clicking
Our pool heater seems to be clicking and shaking after we turn on the heater. Checked filter and pressure - starts up fine, heats water, but clicks and shakes.....need help! Should we not run the heater while it is shaking?
Your pool chemistry is likely out of balance and leaving a residue on your heat exchanger coils. Had the same exact problem. Called a technician out and he said that I needed a new Heater after talking to Hayward. No warranty situation for sure. I went to the pool store, got 2 pieces of hose and hooked it up through my pump. Put a coil cleaner mixed with industrial vinigar and ran it for two days and all is good now. Solution after that was simply good chemistry in the pool. Salt water pool by the way.
Posted on Sep 20, 2012
  • 4 Answers
2 Suggested Answers
john224
  • 1378 Answers
SOURCE: 1 year old hayward h1001d pool heater clicking
Actually, the clicking is likely causing the shaking. Inside the manifold of a H100 is a stainless steel diverter plate that send some of the passing water into the heat exchanger and lets the rest past and back to the pool. When it breaks, you will hear a 'clicking' noise at it rattles in the water path. When it breaks, the flow to the heat exchanger is intermittent and you will begin to boil the water, causing the shaking. This situation is dangerous, especially without a pressure relief in the heater or pipe. As long as your water chemistry is sound, Hayward will usually cover this under warranty even if the unit is over a year old. Contact them to get a factory authorized repair rep out at: http://www.haywardnet.com/locator/
Posted on Jun 12, 2009
Noise
is this heater is been install for above the ground pool it will be better either way to use a hard schedulle 40 pvc to prevent any checking in the hoses for future leak ,is the heater connections are correct in and out , mean from the return the filter go to inlet side the heater them the outlet side of the heter (HOT WATER) GO TO RETURNS of the pool ? also check if the pump got full prime not air,is the filter is clean? also check for any brocken parts inside the flowvalve control, after years low PH AND TA will destroy internal parts in heater include leaking heater exchangers.
Jun 09, 2013 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Need to download a manual for Hayward H1001D pool heater
Hayward.com has owner's manuals available for download. It's about 30 pages long so make sure you have enough paper
Sep 21, 2009 | Hayward H Series
I have a H1001D pool heater that will not continue to stay hot. with heater turned on hi, fan comes on 20 sec.later temp. at vent is hot from the burning gas ,10 sec.later temp. is cool. fan continues...
One of the internal safeties are opening causing the main burner to shut down. Ensure you have proper water flow through the unit. It may be a high limit tripping and can be caused by several things, one being the limit is weak, second the heat exchanger may be partially plugged from scale. You may be able to determine the cause if your mechanically inclined, but I would recommend professional service.
Aug 03, 2009 | Hayward H Series
Trouble shooting Hayward pool furnace
Big enough propane tank? proper pressure reducing valve on the propane? Check both of those.
May 30, 2009 | Hayward H Series Pool & Spa Heater 400k...
May 27, 2009 | Hayward H Series Induced Draft Abg 100,000...
Hayward H Series Induced Draft Abg 100,000 Heater Logo
984 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
