Question about Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT ROUTER
The network path was not found.
Windows cannot locate the server copy of your roaming profile and is attempting to log you on with your local profile. Changes to the profile will not be copied to the server when you logoff. Possible causes of this error include network problems or insufficient security rights. If this problem persists, contact your network administrator. DETAIL - The network path was not found.
    Sergeant:
  • 145 Answers
Had similar problem w same router when originally purchaased call linksys theyll walk you through it there custmer support is xcellent and they speak english only takes a few minutes
Posted on May 25, 2009
2 Suggested Answers
  • 169 Answers
SOURCE: Network Path not found
Your windows profile is broken,.or loaded from another computer (or server) that is down or not running. If you and your computer go direct to the net, not through some kind of network, then you might want to creat a new ADMINISTRATOR profile (via windows control panel)and delte the old one once you have copied what you need.
Posted on Aug 16, 2009
When i log in to my computer, i am been given a temporary profile,how can i return to my user profile
Windows has a roaming profiles if you are on a networked computer. Change it back to local if you have rights and not on a work PC. Right click My Computer > Properties > Advanced > User Profiles > Settings. Highlight the profile and Change Type.
Nov 01, 2012 | Advent Computers & Internet
XP problem
It means your roaming profile in server is missing.
please tell me do you have roaming profile in domain or not.
May 03, 2010 | Microsoft Windows XP Home Edition
Roaming profile error when I log on with my hnah\3500018 id.
how to solve Windows cannot find the local profile and is logging you on with a temporary profile. Changes you make to this profile will be lost when you log off.
Apr 15, 2010 | Profile 200SX Car Audio Amplifier
Network path not found as defined below when logging on
Sounds like you took your work computer home to do some work and its looking to connect to the company server to get your credentials to give you access to the system and files.
I would guess you need the VPN connection to connect to the server its looking for.
From what info you provided that's all we can tell you.
Aug 28, 2017 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
Windows cannot locate the server copy of your roaming profile and is attempting to log you on with your local profile. Changes to the profile will not be copied to the server when you logoff. Possible...
When you "logon" to your local network, your computer is configured to fetch your "desktop" (My Documents and wallpaper and everything else) from a "server" computer on your network.
Was your "logon" to the local "domain-server" a successful login?
Does your local Network Administrator indicate that the "domain-server" is functioning properly?
Does that server's log-file show any error-messages, such as "not allowed to login between 10 PM and 6 AM" (a "security" setting on the server).
Since your "desktop" could not be loaded from the domain-server,
your computer has used a "local" copy of your "desktop",
and it is warning you that any changes will *NOT* be "merged" back to your "network" profile.
Have you contacted you local Network Administrator? What did she say?
May 25, 2009 | D-Link Computers & Internet
May 25, 2009 | Linksys Wireless-G WRT54GS Router...
Server 2003 AD
Hello Dolly, and welcome to FixYa.
As I´m not sure if you want to make a folder for a Domain user or a Local user, so I´ll give you both.
Domain user:
Start -> Programs -> Administrative Tools -> Active Directory Users and Computers.
In the console tree, click Users.
In the Details pane, right-click the user account, and then click Properties.
In the Properties dialog box, click Profile.
Under the Home folder, type the folder information. To do this, follow these steps:
To assign a home folder on a network server, click Connect, and then specify a drive letter.
In the To box, type a path. This path can be any one of the following types:
Network path, for example: \\server\users\test
You can substitute username for the last subfolder in the path, for example: \\server\users\username
NOTE: server is the name of the file server housing the home folders, and users are the shared folder.
Click OK.
- next in the next comment:
Dec 11, 2008 | Microsoft Windows Server Standard 2003 for...
Setting up Active Directory and login scripts based on PC's name
if you are using AD.
do the following:
open AD, select the user, right click on the user and select porperties.
click on the Profile tab, put in the location where you want the file to g to.
i.e.\\server\laptop1\mydocument.
you can alway created a roaming porfile and direct the home folder to the server.
Note:
this is only effective if the user login to the network. if not, then the document will be on the local machine.
Dec 04, 2008 | Microsoft Windows Server Standard 2003 for...
Windows 2003 Logon script
create a user folder on the server.
create each login folder "PC0001","pc0002", etc............
set the user rights by right click on the folder and select properties. (you need all users name. otherwise, one of more people will not have their file on the server.
now, you need all fo the users that will be using that particular PC login, in order to create the user profile. unless you have one generic login.
right click on "my document" on each of the local machine.
redirect the path under the general tab. to where you wan the files to go to.
that will place the file where you want them to be. like you say it is machine direct, not user direct. i you want user direct, in another words, you want the user files to go to the server regardless where the user is, then you need a Domain Controller and Active Directory setup.
Nov 20, 2008 | Microsoft Windows Server Standard 2003 for...
Install of IBM infoprint printer drivers
make sure you are logged on a the Administrator to the computer then try installing..
Dec 26, 2007 | Office Equipment & Supplies
Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT ROUTER Logo
191 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
