Question about Dryers
Kenmore elite he3 model 11084832200 The dryer runs but no heat can i replace the heating unit
    Brigadier General:
  • Dryers Master
  • 3,614 Answers
Before replacing any part on the unit, better to check and test first the FF;
Heating element:
A heating element can burn out and not trip the circuit breaker or blow fuse. The heating element can be checked for breaks (continuity) using an ohm meter. If it proves to be open, then you will need to replace the element.
Thermal fuse:
A lot of machines have a thermal fuse that is located beside the exhaust duct inside the back panel. It'll probably be resin covered and inside a white housing. You can use an ohm meter to check the continuity on this too. If it proves to be defective then you will have to replace it.
Wiring:
If there is no heat, don't forget to check the main power feed and terminal block. Remember that the dryer can still operate with only partial power.
Hope this initial info/idea helps.
Let me know for any clarifications
Posted on May 25, 2009
I have a kenmore elite he3 smart heat quiet pak4 how much is a motor for this dryer
  1. Kenmore Elite He3 Parts - searspartsdirect.com‎
    Adwww.searspartsdirect.com/Kenmore-Parts‎rating for searspartsdirect.com
    Shop Today at Sears PartsDirect™. The Largest Appliance Parts Seller.
    Ratings:Shipping 9/10 - Website 9/10 - Selection 9/10 - Quality 9/10
Search Results
    MOTOR diagram for model # 41794130000 Kenmore-elite ...
    www.searspartsdirect.com/model-part/41794130000/0583/.../00004.html
    MOTOR Diagram and Parts List for KENMORE ELITE Dryer-Parts model # ... MOTORdiagram for model # 41794130000 Kenmore-elite-Parts Dryer-Parts (18).
    PUMP AND MOTOR PARTS Diagram & Parts List for Model ...
    www.searspartsdirect.com/model-part/11047789702/0583/.../00006.html
    PUMP AND MOTOR PARTS Diagram and Parts List for KENMORE ELITE ... ANDMOTOR PARTS diagram for model # 11047789702 Kenmore-elite-Parts ...
Nov 01, 2015 | Kenmore Dryers
He3 gas dryer not heating
http://homeguides.sfgate.com/troubleshoot-kenmore-elite-gas-dryer-wont-heat-77443.html
Apr 30, 2014 | Kenmore HE3 Gas Dryer
Kenmore elite he3 electric dryer no heat
Do you mean the heating coil was replaced? or the thermal cut offs?
You might have a bad thermostat or heating relay.
Mar 25, 2014 | Kenmore Elite HE4 Electric Dryer
Kenmore he3 does not heat
What is the model number of your unit?
Nov 09, 2012 | Kenmore Elite HE3 Steam 8674 Dryer
I have a Kenmore Elite HE3 model 11094834200 it heats up for about 5 minutes and than stops heating. I replaced the thermistor thinking that was the problem but it wasn't. If I try re starting t
Number 34 is the sensor strips located on the rear bulkhead inside the dryer. Clean them thoroughly with Windex or 409. Dryer sheets build a wax buffer on them sensors that moisture cannot penetrate. If no wetness is detected the control shuts her down thinking them clothes is did. Either that or you forgot to reconnect the sensor wire when puttin her back together Kimosabe.
Jul 10, 2012 | Kenmore Elite HE4 Electric Dryer
My kenmore elite he3 dryer has quit heating could it be the heating element and if so where can i find it on the dryer? The model # is 110.82822103 and the serial# is MR1751757
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jun 05, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
My Kenmore Elite (Whirlpool) HE3 elctric dryer is no
A dryer not heating usually means that either the heating element is burned/broken (open circuit); a thermal fuse in line with the heating element is blown or; a thermostat is faulty.
Dryer needs to be partially disassembled to diagnose with a multimeter.
Charlie
Sep 29, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore elite dryer runs cold no heat
Most of the time its the thermal fuse part # 3390719
Jul 21, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore elite dryer no heat
You may want to check if the heating element needs replacing. Most Dryers have 2 heating elements that are found by taking the back off, some of the newer dryers have 3.
Jun 08, 2009 | Kenmore Dryers
Dryer working but no heat
The manual says that two circuit breakers used,and that the dryer
can spin but no heat if one of them tripped, check your panel and see
if any breakers are tripped. If this was the problem,have an electrician
check the circuit.
Apr 09, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Dryers Logo
76 people viewed this question
Top Dryers Experts
