Question about Homelite Mighty Lite Lawn Trimmer
Homelite trimmer dies every time I squeeze the handle
It will run until I squeeze the handle to use it
  • Jim Parker
    Jim Parker May 11, 2010
    How old is your trimmer? When was the last time it ran properly and how did it run?
    Jim
  • 4 Answers
Try to adjust the air intake??
Posted on May 29, 2009
The engine cuts off when i squeeze the handle on the sprayer, what is causing this to happen?
Sounds like a bad unloader valve. Do a search on "pressure washer unloader valve symptoms". When they are faulty there will either be little pressure or it will stop an engine abruptly. The engine will not just die down as it you were turning it off. It would stop cold.
May 28, 2015 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
After cleaning carb, engine will start and run fine until it starts to idle then dies or you let off the throttle and dies....have to hold throttle open to start !!
Here are a couple of Tips to remedy your problem:
www.fixya.com/support/r6078121-fuel_line_relacement_trimmer_weedeater
I know you've cleaned the carburetor, but pay attention to some of my details that you may have missed. They are crucial to getting your machine running properly.
These Tips should do it for ya.
Good Luck!
Jim
Aug 09, 2011 | Homelite Mighty Lite Lawn Trimmer
I have a Homelite Easyreach Model # UT20044A that will start, but then dies. Cleaned the filter, spark plug but still dies
Check that the carburettor and fuel lines are clean. If the unit has not been used for a while the gas (petrol) will evaporate leaving the oil behind to choke up the fuel system. Dirty fuel will do the same. When adding fuel use a funnel with gauze filter in it and always empty the fuel tank and then run the motor until it dies when you've finished work.
Sep 09, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite mighty lite wont stay running
the problem is in the carburetor most likely, it may be cleaned and adjusted, if not it will likely need a new carb
May 31, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite whipper wont start. Replaced the primer
check your gas and oil mix remove the plug take some carb cleaner spray in plug hole pull start replace plug pull start if it fire you mix is wrong.....Good Luck
Aug 15, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
SX-135 Homelite trimmer-carb diaphram cracked
You can go to an outdoor power & equipment type of store (Independent store). The cost is around $12-$18.
Jim
Jun 19, 2009 | Homelite Mighty Lite Lawn Trimmer
remove the muffler,disassemble it,you will find a spark arrester screen in it.it is either clogged up with carbon or partially clogged,clean all carbon off,reassemble and try again
May 28, 2009 | Homelite Mighty Lite Lawn Trimmer
The engine is not getting enough fuel to the high speed jet. The issue may be one of the following:
  1. Restricted fuel filter (in the fuel tank)
  2. Pin hole in the fuel line (are bubbles seen traveling in the fuel line?).
  3. Improperly mixed fuel/oil
  4. Poor grade oil ~ never use outboard or genaric 2 cycle oil, use the manufactures oil or gold spectra (available at motorcycle shops).
  5. Mal-adjusted carburetor, if you changed the brand oil you used in the past the carburetor may need to be readjusted to compensate, or switch back to the oil used before the issue occured.
May 26, 2009 | Homelite Mighty Lite Lawn Trimmer
Wont run when you pick it up or give it gas
Make sure your fuel line, with filter has slack to move around in fuel tank.
May 22, 2009 | Troy Bilt Tb70ss Gas Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
559 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
