Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
Sani rinse, power scour and air dry does not work
Under the Options Panel: sani rinse, power scour and air dry do not light up and do not work
    Problem Solver:
  • 6 Answers
Wat does it do?
Posted on Feb 10, 2010
How do i reset the consol on a westinghouse dishwasher with the buttons rinse only, quick wash, china crystal, normal, pots and pans, soak and scour, hi temp scour, sani scour, air dry and cancel?
Normally you will have to press High Temp and Air dry button alternatively 3 to 4 times within 8 secs until the whole panel lights up. Then press Cancel. That should reset the dishwasher.
Hope this helps. Welcome to fixya.com.. It is a public forum and you can also answer questions by selecting Solve Problems and answering solutions for problems on categories that you are comfortable with.
May 03, 2014 | Westinghouse Dishwashers
Kenmore dishwasher model #665 15872000 is stuck on time saver option for washing and I can't get it to switch to any of the other options such as normal wash
Similar Kenmore Dishwasher 665.18664000. Time saver and Quick rinse were the only programs that would run. I pressed "high temp scrub" then "air dry" then "high temp scrub" then "air dry" and the machine went into a diagnostic mode and counted down from 10 while running a series of tests. After about 10 minutes and various test cycles the machine reset and the "normal wash" light had come back on. If this doesn't work then you may have a problem with the controller which other threads have mentioned replacing yourself for about $120.
Feb 11, 2012 | Dishwashers
Normal wash and rinse only lights keep blinking on whirlpool gu1500xtls. tried cancel and uplugging and they still blink
Have Whirlpool GU1500XTLT1 with exact same symptoms, even tried power off but the lights resumed blinking when powered back up. Used solution from "kent168" of 17 Nov 2010 for similar GU1500XTLS1 with a different problem, and IT WORKED: "Reset the machine: press control buttons in this sequence: sani rinse, air dry, sani rinse, air dry, clear."
Jan 18, 2012 | Whirlpool 24 in. GU1500XTLS Stainless...
How do you get the Codes? for GU1500XTL Dishwasher. Only buttons that work are: Anti Baterial, Pots n Pans, Delay Start, Air Dry, and Cancel. We normally use NORMAL. Need Codes and Wiring Diag. Thanks Walt
I am having the same issue. Did you find a solutions? Looks like websites I've searched talk about resetting the controls by hitting either high temp wash -> airdry -> high temp wash -> air dry OR saniwash -> air dry -> saniwash -> air dry. I'll have to try that tonight.
Oct 20, 2011 | Whirlpool 24 in. GU1500XTLS Stainless...
Hello. I have a dishwater KUDS01FL, and today I noticed that it didn't work at all. It has had the clean light flashing all day long, and it wont work when l push start . please help me Claudia
The blinking clean light is an interruption in the dishwasher program that either indicates a component malfunction, or a program glitch. The following link explains how you may be able to clear the blinking clean light problem and possibly avoid a service call:
http://www.fixya.com/support/r3575752-dishwasher_blinking_clean_light
Now...keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting. Just remove the screws that hold the panel in place and remove.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
In many cases, I found this to be a momentary glitch in operation. If the problem keeps reoccuring the number of flashes is an indication of WHICH circuit is causing your problem. As all dishwashers differ in operation and features, refer to your tech sheet for the recommended troubleshooting steps.
NOTE: Some dishwashers use the Sani-Rinse/Air Dry combination, some use the Sani-Rinse/Heated Dry combination. Some use a sequence of three, others use a sequence of 5 pushes of the buttons. If the tech sheet is not located behind the lower toe panel, it should be affixed somewhere under the dishwasher. I have also found them located inside the inner door panel. Let me know if you still need assistance.
Feb 23, 2010 | Dishwashers
Lights are blinking and nothing happens when you push buttons
Have you tried pushing and releasing the sani rinse button, then the heated dry? go back n forth several times. If that doesn't work try the soak and scour and hi temp wash buttons and re post results
Feb 20, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwarsher
This worked great - press Sani Dry, then press Heated Dry - then repeat - press Sani Dry, then press Heated Dry. All control lights will light and then press Cancel. The control panel should work normally.
Nov 05, 2008 | Kenmore 24 in. 17033 Built-in Dishwasher
Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Feb 02, 2008 | Dishwashers
Kenmore Elite 8269645
I have this model, but not this problem (my impeller motor seems to have burned out). Anyway, try pressing Hi Temp Scrub, Air Dry, Sani Rinse, Air Dry, in that order and see what happens. Mine appears to reset and run through a set of warm-up tests.
Nov 13, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Blinking Quick Rinse
brent, After doing a little research on this model, I see that Sears put out a service flash concerning this problem. Dishwasher stops in mid cycle and one or more of the lights are flashing. SF22-715. The correction is to replace the existing board with an updated board that controls the line voltage better. Part number 8530928. You could be covered under this flash. The tech will have to eliminate the possibility of a stuck or shorted keypad which will cause this same effect. You can try to get this back in operation by pressing in this order: high temp wash-air dry-high temp wash-air dry. This will put it into a self test mode. Just let it run through if it works. If you don't have those keys try power scour-air dry-power scour-air dry. Catriver...post back.
Nov 19, 2006 | Kenmore 16639 Built-in Dishwasher
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
211 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
