Question about Black & Decker Grasshog 12 Inch 18 Volt Cordless String Trimmer/Edger NST2018
Motor runs but base doesn't spin to do the trimming. How can I fix this? I have a Black & Decker 14 inch Grass hog- electric trimmer.
I have a black and decker grass hog that won't turn. The motor runs and I was using it just fine when suddenly the line stopped spinning. How can I fix this?
  • Julie Pagliarulo May 27, 2009
    Hello Taper,
    I have a trimmer purchased last year. It's the Grass Hog 14" Black & Decker Electric Trimmer. I hope this answers your question.
    I was told the cable is broken and needs replacing.
    Thanks for your time
  • Jim Parker
    Jim Parker May 11, 2010
    How old is your trimmer? Gas or electric?
  • 4 Answers
Gearbox!! get rid of it
Posted on May 29, 2009
My black and decker grass hog wont last about 5 minutes and the line empty?
Have you tried re assembley? take it apart and completely redo the whole line reel. i f this does not work. Contact Black and Decker online.
Jun 14, 2015 | Black & Decker Black and Decker & Grass...
The motor is working but the trimmer part stopped spinning. I checked the line but there is plenty, I removed and replaced the line spool but still not working.
Does the trimmer head spin freely? If so then it is somehow disconnected from the motor. There should be a motor coupler somewhere near the motor and also near the trimming head. Make sure they are connected.
Jun 06, 2011 | Black & Decker 14" Grass Hog Xp...
Parts for Black & Decker 14" Grass Hog Xp Trimmer/Edger
Easily, the best place and discounted parts place for this Black and Decker trimmer is eReplacementParts.com
Oct 06, 2010 | Black & Decker 14" Grass Hog Xp...
I just bought a BD Grass Hog and after 1 h of use,
If the noise was up by the handle it may have been the drive pulley breaking loose of the shaft on the motor causing the motor to spin and stop the flex shaft of the trimmer. Another possibility would be the small belt that aids the flex shaft. If those don't fix the problem check the lock nut that bolts the flex shaft to the spool housing. If the shaft broke free from the housing the motor would still run and the shaft would turn, but the spool housing would not spin if it does it could be stopped very easily. Definately check the warranty.
Jul 07, 2010 | Black & Decker String Trimmer Cordless 12"...
The cutter won't rotate --- engine runs, but no spin.
Plastic gear inside is likely stripped or broken. But...there may be grass or line bound between moving head and none moving part. That will cause the unit to not turn as well. It there is sound, then these two are likely. If no sound, then there is typically a one time thermo link that has tripped. This is the case with the GH500. $2 fixes that.
Apr 11, 2010 | Black & Decker 14" Grass Hog Xp...
Describe your Black & Decker
You can order these thru black and decker at blackand decker.com
Sep 12, 2009 | Black & Decker 14" Grass Hog Xp...
We were trimming our grass and the line stopped spinning
flex shaft most likely broken check online or at a local lawn and garden shop the are normally not too much and somewhat easy to replace
Aug 07, 2009 | Black & Decker 14" Grass Hog Xp...
Black & Decker Grasshog 12 Inch 18 Volt Cordless String Trimmer/Edger NST2018 Logo
1,401 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
