Question about Hotpoint RB787 Electric Kitchen Range
RB787WH1WW BURNER DOESN'T COME ON. WOULD IT BE THE SWITCH ITSELF OR THE BURNER ELEMENT? HOW CAN YOU TELL?
  • 4 more comments
  • Anonymous Feb 29, 2008
    I bought mine an less than a week later 3 of the eyes no longer come on just the front burner.
  • Anonymous Aug 27, 2008
    Model RB7787GYBB switch light on backboard comes on but the front glasstop burner does not come on.
  • Anonymous Nov 29, 2008
    3 out of 4 elements stopped working after 1 1/2 years. All within the same week.
  • Anonymous Jan 31, 2009
    Me too, right front burner doesn't heat, although indicator light does. It quit while it had been on "high" for about 15-20 minutes. Months before, (and not related?) the timer started to freeze on the minute setting from time to time - sometimes it works and sometimes it don't. I have a circuit tester but I'm not qualified on it - but I have an IBM engineer coming to dinner Sunday and I'm going to quiz him on how it works. Please advise any special tricks to getting to the wiring/components. Thanks, Mike Dominguez, Tucson, Arizona
  • Anonymous Feb 15, 2009
    Upper right burnner does not work after two years of used
  • eddiewyatt May 11, 2010
    Is that L1 to L2? Upper right connections looking from the back? I tried and they read open but so do the other 3 that do work. Those wires jumper over to the other switches. One red and one black. The ones that look to be for the burners appear to be L-H1 and L-H2. Based on the insulation used on them. Each burner has different colored wires. For instance the one I'm dealing with is yellow and yellow with a black dash. Could this be correct? I checked them and they read open. The ones on the other 3 read resistance.
    Thanks
  • 473 Answers
Could be either one.  You can check the element at the switch by checking for resistance on L1 and L2 with an ohm meter.  If it shows resistance then the element is ok, then you would replace the switch.  If it shows open the element is bad.  Make sure the oven is unplugged before removing panels and conducting test.
Posted on Oct 20, 2007
Large burner not working
It is possible the burner itself is bad. Most tops have a couple screws under the glass panel the will allow you to open up the top and install a new burner element. these elements are very fragile so be careful installing a new burner element. The other possibility is a burned wire or a bad switch.
Oct 04, 2014 | Kitchen Ranges
Radiant element
Most likely the switch for that burner needs replacing
Sep 29, 2017 | Kenmore Kitchen Ranges
Roper range oven
follow this steps and fix it. God bless you
.Bake element
Replace if found defective
1.Broil element
If the element only works partially or not getting red hot at the "Hi" setting, the problem might be with a burned out receptacle that the element plugs into. If this is the case, replace both the element and the receptacle.
You can usually tell when the element itself burns out. It might have small holes or bubbles on the coil. Replace the element, if found defective.
2. Infinite switch
Another reason, why the element would not start, might be a defective infinite switch (located behind the control panel, with the burner knob on its shaft). Replace the switch if found defective.
Read more: http://www.appliancepartspros.com/repair-help/rangeoven-repair-help.html#electric#ixzz2ab45pXtc
Jul 30, 2013 | Dryers
Spectra GE model JBP64W0B4WW stove top burner stopped working
Which element is it? Try to switch the infinite switch from another element. This will tell you if it is the element or the switch problem.
Apr 06, 2013 | GE Spectra JBP78 Electric Kitchen Range
My oven does not start
Hello there:
It doesn't work at all dot_lineone.gif 1. No power
Make sure there's power getting to your range, oven or cooktop. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter. Sometimes the power cord disconnects or burns at the appliance, if this is the case, the wiring and the terminal block must be repaired or replaced. ^ top clear.gif Top element doesn't work dot_lineone.gif 1. Top element
2. Infinite switch
Read more: http://www.appliancepartspros.com/repairtips/repairtips_range_oven.aspx#2-1#ixzz1CZ54wKfT
Jan 30, 2011 | Whirlpool Ovens
Both heating elements in the oven not working. I did inspect the h. elements found no burn. thankyou help
Ok, you can confirm element failuer by testing for continuity with a Ohm meter. A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
Another reason, why the elements would not start, might be a defective infinite switch (located behind the control panel, with the burner knob on its shaft). Replace the switch if found defective.
If the elements show continuity, you will need to replace the entire control board(clock, EOC)..
Jun 01, 2009 | Frigidaire Kitchen Ranges
Rear element will not get hot . has been replaced and has electric up to the element when turned on
Check the receptacle you burner plugs in to. There are only three items to a burner. The switch, supply power. The receptacle where the element plugs into and of course the burner itself. You say you replaced the burner and has electric up to the element. How are you testing this voltage? Perhaps you are only reading 110 volts and your burner needs 220 volts to operate. Double check these item s and let me know if I can help further.
Waiting to hear from you,
Eric Campion
Feb 18, 2009 | Tappan TEF242 Electric Kitchen Range
Kenmore electric stove model c880.6383880 left front burner does not work....it is not the element itself as it heats up on another burner.
hi,
sounds like you have the old-style coil elements on you stove.
your problem is the switch under the element, called the infinite switch. i would suggest to have a technician replace it. they usually charge for the labour but if you have never done it before, it's money well spent.
Aug 19, 2008 | Stoves Kitchen Ranges
COOKTOP
its been my experience that the dual burner switch is far more likely the culprit, unless you can physiclaly see the outer ring is broken( visual inspection works wonders. as far as trying to ohm out i generally look at theelemnet itself (4 wires lead to the elemnt you can trace 1 to the outer portion of element, and 1 to the inner portion.WITH POWER OFF Iswithc those 2 wires and the restore power try element ad watch for outer ring to work inner ring no good. now i know its the switch not sending power. reset wires and order new switch
Mar 08, 2008 | Cooktops
Hotpoint RB787 Electric Kitchen Range Logo
376 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
