Question about Kenmore 63792 Microwave Oven
How do i take it down?
I have a Kenmore over the range microwave mounted to the wall. How do I take it down?
    President:
  • 2,976 Answers
If possible, to make the job a LOT EASIER, pull the stove out from the wall, so you can get under the mocrowave.
DISCONNECT THE POWER.
You'll have to remove the unit from the case.
Remove the screws from the bottom and it should slide out. Then, remove the mounting screws. It's best to have a helper, it isn't always in a good position.
Posted on May 25, 2009
I have a used microwave that mounts under a cabinet, Kenmore model 721. It has only two screws to mount through cabinet does it require additional hardware? Seems alot of weight for just two screws.
Kurt,
There is usually a mounting bracket that mounts to the wall and the microwave hooks into that and is held up by the two screws you referred to in your question. Unfortunately, you have not provided enough of the model number for us to look up any info to help you find a new bracket to mount to the wall. Hope this helps!
Feb 22, 2016 | Kenmore Microwave Ovens
Over range microwave doesn't fit in the space outlined by the installation template
You missed something while reading the installation directions but that won't fix it. since you already drilled holes in the wall lower the mount down as needed then drill new holes in the mount to match the holes you drilled in the wall. The problem would have been worse if you were off left or right... up and down is easier. Remember you maybe just not dropping the microwave low enough to fit in the slot at the bottom of the wall mount before you tilt the micro up.. check it one more time...including the directions before you re-drill
Sep 26, 2015 | Bosch 30" 500 Series Over-The-Range...
Uninstall Frigidaire FMV156EMA over range microwave?
If you have removed the bolts in the cabinet above, the unit is hanging down on the range. All you need to do is get a helper and lift the front edge a little bit and then lift the edge at the wall up about an inch and lift it off.
Mar 05, 2015 | Frigidaire Microwave Ovens
Over The rang microwave installation
I would say finish the wall, because the microwave needs the space for cooling.
Dec 17, 2017 | Samsung Microwave Ovens
Over the range microwave fuse access
No you will have to pull the unit out and take the casing off, Please Discharge HV components to ground with no power applied before touching anything in the unit, failure to discharge high voltage components could result in death
Aug 13, 2012 | Kenmore Microwave Ovens
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
I don't see how you remove it from the wall mount
do you have cabinets abofe the microwave. open and see if the brackets that hold it on are in there.
May 25, 2009 | Kenmore 63792 Microwave Oven
One stud in the middle for an OTR Microwave Install?
i had the same trouble, yes i used a solid bolt to hold the microwave bracket in the stud then used the biggest toggle bolts that will fit, also the cabinet will not have to be changed. it works fine, if you had a vent a hood dont forget to hook up the exhaust vent. i figure your old exhaust vent is in the cabinet like mine was
Dec 31, 2008 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Kenmore microwave removal
the top vent exhaust grill has two screws facing down-remove these. remove plastic vent. inside you will see a solid wire tringle assy. turn and pull this release.
warning if you have granite counters or tile, place plenty of material under it to stop the impact if oven gets away from you
Jul 11, 2008 | Kenmore 62622 Microwave Oven
Kenmore 63792 Microwave Oven Logo
123 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
