Question about Black & Decker Grasshog 12 Inch 18 Volt Cordless String Trimmer/Edger NST2018
The motor runs but the base doesn't spin.
I have a black and decker grass hog that won't turn. The motor runs and I was using it just fine when suddenly the line stopped spinning. How can I fix this?
The nylon Gear in the head has theeth missing. I need a parts break down and a source for part.
this is for a Grasshog. NST 2018 Trimmer
Posted on Jul 17, 2009
I just bought a BD Grass Hog and after 1 h of use,
If the noise was up by the handle it may have been the drive pulley breaking loose of the shaft on the motor causing the motor to spin and stop the flex shaft of the trimmer. Another possibility would be the small belt that aids the flex shaft. If those don't fix the problem check the lock nut that bolts the flex shaft to the spool housing. If the shaft broke free from the housing the motor would still run and the shaft would turn, but the spool housing would not spin if it does it could be stopped very easily. Definately check the warranty.
Jul 07, 2010 | Black & Decker String Trimmer Cordless 12"...
;How do you lengthen the string? (Have the grass
To lengthen the string:
- Turn the Grass Hog upside down
- Push in on the two release buttons on either side of the spool (they're orange)
- Pull the spool head off and spin it to release more string while you pull the string with your hand (make sure it is still fed out through the hole in the base)
- Pop the spool head back into place
Test the Grass Hog to make sure the string is not too long. If it is you'll hear it cracking against the plastic guard on the base.
May 02, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
We were trimming our grass and the line stopped spinning
flex shaft most likely broken check online or at a local lawn and garden shop the are normally not too much and somewhat easy to replace
Aug 07, 2009 | Black & Decker 14" Grass Hog Xp...
Motor spins, shaft does not...
I'm in a similar situation with my GH1000, except that it was a part that comes with whole motor assembly. I could sell you the shaft assembly of my trimmer, or I'll buy your motor assembly. Yes?
Jul 26, 2009 | Black & Decker 14" Grass Hog Xp...
Head of trimmer/edger doesn't spin
i have the same problem, the plastic timing pulley on the motor assembly is probably melted, remove all the screws down the side of the housing, including the one hidden under the label, and you will find that the belt and the pulley are both chewed up.
Apr 18, 2009 | Black & Decker 14" Grass Hog Xp...
Black & Decker Grasshog 12 Inch 18 Volt Cordless String Trimmer/Edger NST2018 Logo
1,142 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
