Question about Onkyo TX-DS676 Receiver
Right front channel sometimes does not work
I have some problems with my Onkyo TX-DS676 receiver, sometimes when I power it up my right front channel is not producing any sound. Work-arround solution is to turn  to volume up to above 60 and then it starts working again also on lower volume. Does anybody know this problem and have suggestions?
  • Anonymous Nov 19, 2007
    I have the same product and similar issue. My right front speaker and back left go at the same time. I can be listening and then no sound comes out. I will try switching speaker wires and see if it changes, but find it odd both speakers mentioned go at the same time. They use to come back on, but have not lately. jdy
  • Anonymous Mar 29, 2014
    Now even turning volume doesn't help anymore.
  • 1,512 Answers
You have dry solder joints in the output stages to the front channel.-solution. resolder channel.... or dirty speaker protection relay contacts. can be determined by tapping the top of the protection very gently when fault occurring. solution. burnish contacts and treat with crc2-26
Posted on Dec 10, 2007
  • Graeme Ross
    Graeme Ross Dec 10, 2007
    second persons problem if different to first. may still be dry solder joints but operating speaker protection relay to cutoff speakers to avoid damage. not dirty contact problem
check that you have selected that option on both player and receiver.
optical setting. a lot of systems are defaulted to hdmi
Apr 12, 2014 | Onkyo TX-DS676 Receiver
Just want to know watts per channel in traditional stereo mode.
Im geusing this means not all channels driven, but in reality it will be the same as the left and right speaker output regardless of if its in multichannel mode, whenswicting between all it will do is bypass the ADC/DSP/DAC circuitry and use a relay to directmode, it will not turn off the other amps, only the input to them, so you have the same amount of power avaibly for the right a left channel which will be 110 watts at 0.08 THD at 8 ohms, which is **** anyway, if you want it for pure stereo and nothing else, buy a dedicated stereo amp.
Mar 21, 2010 | Onkyo TX-DS676 Receiver
Onkyo tx-SR605 - how do I use as a processor and
IF and only if, your receiver has connections labeled as "pre-out" can it be connected to an external amplifier.
If it does, then you connect from the left and right channels from the receiver, to the left and right channel on the amplifier.
Jan 02, 2010 | Onkyo TX-SR605 Receiver
Describe your Onkyo TX-SR875 7.1 Channels Receiver Problem All right channels are not working. Left channels including center channel speaker is working. Please advise.
Recommend changing your FINAL drive AMP IC most house BOTH right and left channels, your drivers right channel input is good cuz it is used to make the left channel signal
Nov 22, 2009 | Onkyo TX-SR875 Receiver
Onkyo TX-DS 595 receiver surround channel unrealiable
How you power off the amp won't hurt it generally. I used to fix ONKYO amps under warranty, and I can tell you now, it will be full of dry solder joints. Take you unit to your local repairer, and they will resolder all the offending PCB's inside. This type of repair will fix 99% of strange audio noises and cutting in and out etc. for ONKYO recievers. Otherwise this is quite a good product.
Oct 27, 2009 | Onkyo TX-DS595 Receiver
Memory loss TX-ds676 onkyo
Ik have the same problem as Toolathep.
Is there a solution for it?
replacing the battery?
Feb 07, 2008 | Onkyo TX-DS676 Receiver
Onkyo Tx-SR55
did you swap the left from speaker with the left front?
if still crackels after that them you have bad left output.
Jan 09, 2008 | Onkyo TX-SR500 Receiver
Onkyo tx-ds676 dead no power up
power down the amp totally to reset processor, then try again. If still no go, may have blown internal fuses- replace and try again
.... or failed thermal fuse in mains transformer. this is a workshop repair as it involves mains voltage that can kill :)
Nov 24, 2007 | Onkyo TX-DS676 Receiver
Onkyo TX-DS676 Receiver Logo
207 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
