Question edited for clarity and toss in some CAPS.
Question moved to model category.
P2177 is Fuel Air sensor showing Lean mixture, so it is dumping more fuel and sooting up plugs and the catalytic converter. After fixing, you will need a system cleaning additive.
Malinda, Order the routing sticker through the dealer if available or go to auto recycler and take picture, down load and print, laminate and stick on your car. Check the attached links pics. of vacuum lines. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." 2004 VW jetta 1 8 turbo vacuum hose diagram Google Search
It is not wise to install a BOV on a 1.8t since it could cause problems with stalling in between shifts if it is vented to the atmosphere. The most recommended aftermarket solution is a new diverter valve (ex: Baileys, APR etc). If you still want to install the BOV they sell kits for the ssqv that mounts it to the charge pipe and routes the air back to the intake.
Support the engine as the bolts go through the front motor mounts, disconnect battery (have radio cde if ness) diconnect starter wres, remov bolts> Install is reverse.
