Indesit w1xxl146 not running full cycle
Gets to rinse then on/off button flashes red and so does extra rinse and mini load also allows me to open the door well the wash is full of water when u turn it off it makes a noise as though it wants 2 rinse but wont do anything.
  • 209 Answers
SOURCE: HOTPOINT AQUARIUS WF250 1500 SPIN
check the cold water supply, either from the mains pipe, there is no water getting into the machine, if water is there up to the machine check the solenoid for circuit, to do this unplug from electric, remove lid, and test the two wires on relevant solenoid, no circuit means faulty solenoid, (test with the 2 wires removed from solenoid) take care note position of wires to put back properly answer above based on info given
Posted on Sep 27, 2007
  • 209 Answers
SOURCE: Inglis Washing Machine - Heavy Duty Extra Large Capacity
if it doesn't empty check the pump for blockages or just not working electrically, or check cold water supply to machine, or the cold water solenoid, this may also be faulty hope you can find what you need starting from the above, if i have helped please rate me
Posted on Oct 04, 2007
SOURCE: Indesit WIL143S flashing lights
hi have you unplugged your washing machine for 2 mins then plugged it back in to give the machine a reset..its says it in my WIL 163 MANUAL TO DO IT was wondering if your is the same gl
Posted on Jan 20, 2008
Timon90
  • 126 Answers
SOURCE: Indesit W11 making grinding noise
I think you have a drumbearing problem.:)
Posted on Jan 22, 2008
jaylex
  • 417 Answers
SOURCE: Indesit widl 102 extra rinse button always on!
Check that the button isn't stuck it if not remove top lid and check the PCB and see if the switch hasn't collapsed causing it to be on all the time. Also if you hold in the go button for about 5 seconds this resets the program try this.
Thanks J
Posted on Feb 10, 2008
When washer gets to 12 minutes it shuts down and flashes ul
Tammy: According to Advantagesupplyfl.com: "uL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
Display clears if mini-cycle successfully rebalanced the load.
If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute
the load."
May 12, 2015 | Washing Machines
My indesit WIB111 is full of water & clothes. how can I manually drain the water out?
put the machine in the emergency drain mode press the start button when it stops
http://www.manualslib.com/manual/76755/Indesit-Wib-111.html?page=13#manual
Dec 12, 2014 | Indesit Washing Machines
Indesit washing machine function lights ruppidly flashing in the middle of washing cycle
Possible that the inlet filter or the valve is blocked and so there is no or less flow at the time of rinse cycle. Please remove and reset the valve.
click on : Inlet valve.
Jan 19, 2013 | Washing Machines
My washer has an error message "uL", the washer is full of clothes and water; but won't do anything...what should I try?
Unbalanced load uL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
the load.
Mar 02, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Ul code about 10 to 15 seconds into spin cycle machine is level code comes up even if i run it empty
Hi
Thanks for using FixYa. UL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
• Display clears if mini-cycle successfully rebalanced the load.
• If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Indesit moon not spinning as it should
my machine is similar...............but has an extra rinse button which adds 5 minits to the wash.....but spins faster to get rid of extra water...............see if you have extra rinse option......
cheers
Jul 24, 2017 | Indesit W 123 Front Load Washer
Indesit wil 103 door won't open...
Welcome to Fixya.
Try holding the Start/cancel button in for at least 2 seconds.
If there is another lamp flashing at the same time as the door lamp, then you will have to call an engineer.
Dec 18, 2008 | Indesit W 123 Front Load Washer
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Thanks J
Feb 07, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
123 people viewed this question
Top Washing Machines Experts
