Question about Kenmore 63792 Microwave Oven
I don't see how you remove it from the wall mount
I have a Kenmore over the range microwave mounted to the wall. How do I take it down?
    Problem Solver:
  • 12 Answers
Do you have cabinets abofe the microwave. open and see if the brackets that hold it on are in there.
Posted on May 25, 2009
I have a used microwave that mounts under a cabinet, Kenmore model 721. It has only two screws to mount through cabinet does it require additional hardware? Seems alot of weight for just two screws.
Kurt,
There is usually a mounting bracket that mounts to the wall and the microwave hooks into that and is held up by the two screws you referred to in your question. Unfortunately, you have not provided enough of the model number for us to look up any info to help you find a new bracket to mount to the wall. Hope this helps!
Feb 22, 2016 | Kenmore Microwave Ovens
Over range microwave doesn't fit in the space outlined by the installation template
You missed something while reading the installation directions but that won't fix it. since you already drilled holes in the wall lower the mount down as needed then drill new holes in the mount to match the holes you drilled in the wall. The problem would have been worse if you were off left or right... up and down is easier. Remember you maybe just not dropping the microwave low enough to fit in the slot at the bottom of the wall mount before you tilt the micro up.. check it one more time...including the directions before you re-drill
Sep 26, 2015 | Bosch 30" 500 Series Over-The-Range...
Uninstall Frigidaire FMV156EMA over range microwave?
If you have removed the bolts in the cabinet above, the unit is hanging down on the range. All you need to do is get a helper and lift the front edge a little bit and then lift the edge at the wall up about an inch and lift it off.
Mar 05, 2015 | Frigidaire Microwave Ovens
How to remove overhead kenmore 1000 watt microwave
Unplug the power cord and make sure it will come out easily when you start to take out the mounting screws.There are 2 or more screws in the cabinet floor above the microwave. Be ready to catch the microwave once the last screw is removed because it will drop in the front. Then lift the back of the case off the tabs on the wall mount bracket and the whole thing is in your hands.
Sep 23, 2014 | Kenmore 63792 Microwave Oven
How do I remove a 1991 Roper over the range microwave. There are no cabinets above it that it would be screwed into.
If it is not mounted above, it is most likely attached to a mounting bracket behind the microwave. I would start with removing the vent cover (if there is one) and check for access to screws or bolts on the back side of the microwave. Make sure that you have a friend helping!
Some other tips:
http://www.ehow.com/how_4452966_remove-wall-mounted-microwave-oven.html
Jul 25, 2014 | Microwave Ovens
How to remove from mounting
if its an under counter set-up,then remove the 2 screws inside the cabinet above the unit and lift out of angle bracket mounted to the wall,use 2 people to be safe when doing so
Apr 15, 2010 | Kenmore 61689 Microwave Oven
I am seeking a template for re-installing my 2 year old microwave. Jenn-aire has none of the templates in stock and can't send me a pdf or file so I can print the template myself. I have tried 2 parts...
Since you can't get a paper template for remounting your microwave, I can offer you my tips for doing this, as I've had to reinstall many of my customers microwaves, after they've done a kitchen remodel.
You can use the metal mounting bracket as your "new" template. Just unmount the micro and remove the metal bracket and you can then position it on the wall or under the cabinet where you are looking to mount the microwave. However, before you remove it from the wall, simply measure the distance from the edges at the top and both sides of the bracket, where it is presently mounted and you'll be able to easily remount it in a new location.
If you've already removed it from the wall, not to worry, simply place it on the back of the microwave and measure the distance from the edges of the bracket to the top and both sides of the microwave's canbinet edges. Allow for 3/16" additional distance and you should be able to then remount the bracket at the new location with ease.
Please remember that you want to get the bracket secured into a wall stud so it can hold the weight of the microwave once it's installed and fastened to the bracket. I also recommend that you use wall anchors at the side edges at both the top and bottom corners to help secure the bracket IF there are no wall studs behind the predrilled holes for mounting the bracket to the wall.
If you have trouble using the metal mounting bracket, you can always trace the entire bracket onto a piece of heavy paper or cardboard, but frankly, I find this unecessary and time consuming, since you've already got the mounting bracket right there with all the holes and such.
Also, don't forget to measure the location of the power cord at the top or back of the microwave and remember you'll need to drill a hole in order to be able to pass the cord thru the cabinet. If your microwave has screws at the top front edge that help secure it to the cabinent above it, again, simply measure the distance of these mounting locations from the sides and back of the microwave cabinet and drill holes thru the cabinet, using a drill bit that is twice the diameter of the mounting bolts. You should add washers to these bolts to help prevent the bolts from pulling thru the cabinet bottom.
Mounting a microwave is best done with at least two people, as holding it in place while someone else puts the bolts in it isn't easy to do by yourself. Also, it is much easier to do, when installing it over an existing range, if you move the range out of the way first, so you can stand under the microwave, instead of having to lean over the range while trying to install it. Not to mention the fact that should you drop the microwave, you'll not only damage it, but could destroy your range at the same time.
Hope you find this Very Helpful and best regards!
Oct 23, 2009 | Jenn-Air JMC9158AAS Convection/Microwave...
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
How do i take it down?
If possible, to make the job a LOT EASIER, pull the stove out from the wall, so you can get under the mocrowave.
DISCONNECT THE POWER.
You'll have to remove the unit from the case.
Remove the screws from the bottom and it should slide out. Then, remove the mounting screws. It's best to have a helper, it isn't always in a good position.
May 25, 2009 | Kenmore 63792 Microwave Oven
Kenmore microwave removal
the top vent exhaust grill has two screws facing down-remove these. remove plastic vent. inside you will see a solid wire tringle assy. turn and pull this release.
warning if you have granite counters or tile, place plenty of material under it to stop the impact if oven gets away from you
Jul 11, 2008 | Kenmore 62622 Microwave Oven
Kenmore 63792 Microwave Oven Logo
241 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
