My Fischer Paykel double drawer dishwasher top drawer did not drain and was flooded so I manually emptied the drawer and now it keeps blowing the fuse in the plug. What can I do please
This means there is water collected on the base of the dishwasher cabinet under the bottom drawer. You will need to disconnect the dishwasher mains plug and take the bottom drawer out to dry the base out. Follow instructions in this manual (page 7 step 2) to remove the drawer.
Fisher Paykel DishDrawer Installation Instructions ManualsOnline com
SOURCE: fisher and paykel DD-603 dish drawer
Hi there, If you have had an F1 you need to dry out the product in order to reset the flood switch. This is a simple process as follows: 1. Ensure product is disconnect from wall so that it has no power. 2. Open the bottom drawer and put your hand in through the gap where the bottom of the bottom drawer comes out and feel the base of the cabinet that houses the drawers for water. 3. If there is water present dry it out as much as you can with paper towels or old rags. This machine is designed to drain all water to the front of the base of the cabinet away from the flood switch that sits at the back left corner of the cabinet base that the drawers are fitted into. 4. When you have base of the cabinet dry you need to ensure that the switch has not moisture on it in order for it to reset and allow you to start using the product. This can be done 2 ways: 1. leave bottom drawer open for 24-48 hours to allow natural air circulation to dry out the connection. or 2. position a hair dryer to blow air into the back left corner of the base of the cabinet and dry it out quicker. This still make take up to 6 hours as the flood switch had a protective cover over it to try to prevent F1's for small spills. 5. When the product had been dried out, important that you make sure it has, when you switch on the machine the F1 should be gone and ready to use. Please run each drawer seperately on a rinse cycle to confirm to yourself that it flooding was possibly caused by something blocking the sprayarm, or something stacked too high or something got stuck in the pump temporarily stopping it from draining effectively or the product suddsing too much from spilt rinse aide in one of the drawers. If each drawer runs successfully you should be in the all clear to start using it again. Please note though: if something blocks the spray arm that is directly linked to the pump your drawer will flood as a result. If you have something stuck in the pump peventing it from draining effectively ie a toothpick or piece of broken crockery this will cause your product to flood, but you will hear an louder than normal sound when the pump is running. And finally if you spill rinse aide in your drawer when filling it clean all spilt rinse aide to prevent unit from over sudsing when running. Regards KAR-Ltd
SOURCE: F4 error on fisher and
No increase in water
temperature during
wash cycle. --->
Faulty element.
Electronics controller
faulty.
Faulty temperature
sensor.
Check the heater thermistor and the wires to both...
SOURCE: I have a Fisher Paykel dishwasher with water in top drawer
You need a Air gap kit designed by Fisher and Paykel to address this problem. It is pricey but it is worthy. I used this and very happy with it since no back flow problem from one while other running. Here is a link to order it.http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
SOURCE: Change Fuse on Fisher Paykel Dishdrawer
I have a single drawer F&P dishwasher. This morning a safety switch trigged. This afternoon when I went to use the dishwasher found that it had no power. There are no lights and there was a smell of something burning. The power outlet has power. Can you help?
I have done that and it does appear to be dry underneath but still keeps blowing the fuse.
