After the spin cycle runs the clothes are still soaking wet
Washing the clothes seem fine but after the cycle are all done the clothe are still soaking wet. I have tried setting the water level on the lowest setting and that does not work. I usually have to turn the knob to another rinse/spin cycle at least 2-3 times for the clothes to be rinsed enough to move to the dryer to dry
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 91 Answers
I had that problem at one time with my old washer and what it ended up being was the Washer Dog Agitators were broken and causing the it to slip and not spin correctly. I would try checking the Dog Agitators.
Here's A picture of a typical top-load washer breakdown to show you where they are located --->Here<---
I hope this helps. If that is the problem I bought mine at Sears for about $8, normally in stock item.
after the spin cycle runs the clothes are still so - moz-screenshot-2.jpgLet me know if there is anything else I can do.
after the spin cycle runs the clothes are still so - moz-screenshot-1.jpgclass=moz-screenshot-1.jpg
Posted on May 25, 2009
  • Alan Timperley
    Alan Timperley May 25, 2009
Soaking wet clothes after spin cycle
Check and choose a longer spin cycle and see if the fault changes. If so the SPIN cycle is too less or there is less action or speed in the cycle, check the motor speed, check the capacitor to the motor, the spindle friction - if so reset the spindle and drive.
Jan 17, 2013 | Washing Machines
Washer spins out when it feels like it!
I think you have something caught inside the pump. ie, a button, paperclip, small screw, etc.
Jun 23, 2010 | Washing Machines
Clothes soaking wet after washer is done
There is either a problem with the drain or spin cycle. Before the spin cycly starts, ensure that the water drains fully. If it does, then it may either be the belt slipping or the timer malfunctioning. If there is water in the tub when it starts spinning, then you have a blockage in the drain line.
Feb 11, 2010 | Whirlpool Washing Machines
Clothes are soaking wet after done
You may need a belt or a pump. Call sears they will help more.
Oct 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Spins fine, but clothes still soaking wet
Clogged water pump. Not draing fast enough. If this is helpful, please post as such.
Feb 21, 2009 | Maytag Performa PAV2200
Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Jan 17, 2009 | LG WM1814CW Front Load Washer
Clothes are soaking wet after the entire wash cycle.
The motor controller is likely bad - not getting to the HIGH spin.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 07, 2009 | Washing Machines
Soaking wet clothes
Burly Bob,
Is this the same model as listed by the previous poster? If so, does the washer ATTEMPT to go into the spin cycle? That is, does the timer advance to spin cycle properly, and can you hear the transmission or drive motor engage?
May 31, 2008 | Kenmore 22422 Top Load Washer
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
Mar 08, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
597 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
