Question about Craftsman 14.4 volt Cordless Drill/Driver with Work Light
Chuck is locked in open position
Craftsman cordless drill. The chuck is open completely and I am unable to release it so I can tighten a bit. Yesterday, I was opening it completely up and then it got jammed in that position.
  • 2,176 Answers
What you can try is some WD 40 spray into the chuck and then find a GOOD pair of gloves or a rag and hold the collar of the chuck either by hand or use the rag and a pair of channel locks to protect it and then use the tool motor slowly and see if that doesn't release it
Posted on May 25, 2009
  • MrWizzer Apr 18, 2011
    put the chuck in your mouth, and think about Jesus. This should loosen it up.
How to release a bit stuck on the 18 volt cordless hammer drill???
Put the clockwise - anticlockwise button to the middle 'lock' position. That is the button above the trigger that is orange. Then viewing the drill from the drill bit, turn the chuck anticlockwise.
Dec 12, 2017 | Hammer Drills
How do I remove the drill bit from a Makita6223D?
If your drill has the original keyless chuck on it, there are two plastic rings on the chuck. The outer ring should tighten and loosen by hand enough to hold the bit(s). The inner ring is to hold on to if the chuck gets overtightened. Chucks do wear and get corroded over time and can get locked in position. If you can't get it loose by hand, channel lock pliers can help. If the chuck is that bad you may need to replace it.
Mar 03, 2013 | Makita 9.6v Cordless Impact Driver 6903VD
I'm new to home improvement, and just bought my first cordless drill (Ryobi P204, 18-volt, 1/2"). How the heck do I insert the bit? The drill comes with two batteries, and a charger. There is an opening...
Like many drills these days, the P 204 has keyless chuck. In order to secure a bit, locate the forward/reverse switch (right above the trigger). Set it to the center of the three positions. This will lock the drill so that it cannot turn. Now turn the black portion at the front of the drill's nose (looking at the drill from the front, clockwise rotation will tighten the chuck and counterclockwise will loosen it) Adjust the chuck jaws so the bit you have chosen will fit without too much slop and then tighten the chuck until it holds the bit snugly and straight. Unlock the forward/reverse switch (push to the right to drill or insert screws) and you should be ready to go!
Oct 24, 2010 | Ryobi 18v One+ Circular Saw P501 18 Volt V...
I have a new DeWalt DC725 cordless compact 1/2" drill/driver/hammerdrill. The only problem so far has been that the keyless single sleeve chuck will now not open to release a 1/2" drill bit. I have twisted...
place the bit in a bench-vice and take a little benchhammer and with a plastic hammer .
hold the hammer with chisel tip on the claws of the chuck and tap with the plastic hammer on the other side of the bench hammer and beat gently on the three claws tighten the chuck three-step around gently around so the bit slowly from the drill bit comes slowly loose.
if the bit is out you can turn the chuck free, if this problem repeats go to the dealer for warranty .
Aug 17, 2010 | Dewalt Garden
Keyless drill has locked in a closed position with the drill bit
I just put mine in reverse and grasp the chuck with a pair of channel locks. Pull the trigger and hold the channel locks tightly. The chuck will release the bit.
Jun 04, 2010 | Craftsman 3/8" Corded Drill
We were using a makita cordless power drill. Somehow the clutch got stuck and it won't spin or open where you put the drill bit in. The motor seems to be spinning, think the problem is just in the...
keyless chuck. grab the ring immediately behind the chuck and the tampered chuck piece with a padded channel lock plier. turn the chuck part clockwise to release.
Oct 26, 2009 | Makita Drills
Locked drill chuck
i have the same tool and have had the same problem
i use 2 large prs of channel locks(water pump pliers) to break the bond
Jul 05, 2009 | Craftsman C3 19.2 volt Combo Kit,...
Craftsman 14.4 volt Cordless Drill/Driver with Work Light Logo
676 people viewed this question
Top Craftsman Drills Experts
Tim Venetis
Tom Chichester
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
