Question about Mitsubishi VS-6055 60" Rear Projection Television
My TV shuts itself down by itself
It is a 2000 Pioneer 60 in big screen, SD-P6081-K, PK304951L
the tv keeps turning itself off, and then the remote does not work to turn it back on you have to push the button on the tv itself. after you push the button on the tv, the remote works again until it shuts itself down again. you have to keep turning the tv back on for about half an hour or so and then it finally will stay on. what do you think the problem is.
  • ranaflanigan May 25, 2009
    Kinda figured it was power, but need a little more information then that. Thanks anyway.
    Novelist:
  • 152 Answers
Agreed, one of the problems is power supply problems, also, overheat protection may also be the cause, make sure the internals are dust free, compressed air works wonders, remove the back cover, blow as much of the dust as you can off of the componants, replace the cover, and see what happens...
NOTE: If you are using a home / shop air compressor, make sure to have a vapor filter to remove any moisture from the air lines. water + electronics = BAD
Posted on May 29, 2009
  • Mitsubishi Master
  • 3,866 Answers
Poer supply is the cause of the shutdown and would need to be replaced. These cost around $150 bucks just in parts the labor you would need to find someone that knows just what there doing or you could wind up into the hundreds, Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 25, 2009
My Pioneer projection TV model SD p6081-k loses
Your lamp is turning off, there is a temperature sensor who will shut down the lamp(s) if they will overheat.
Open the back vacuum all the dust and clean the fan(s)
Sep 26, 2014 | Televison & Video
What does it mean when I have double vision on all channels and dvd on my pioneer sd-533 hd5 big screen floor model?
follow this steps and fix it. God bless you
Configuration Problems
Improperly configuring TV setting can cause problems. Verify the TV settings are set correctly. First, brightness and contrast should not be set to high or to low because this can cause poor picture images. Second, adjust the color on the TV when the picture displays colors poorly. Third, if you are having sound issues then check to make sure the volume is not muted or turn down all the way.
Nov 04, 2013 | Pioneer SD-533HD5 53" Rear Projection HDTV
I was given a pioneer tv sd-p5575 and i dont have
MY PROBLEM IS ANTIVIRUS IX DIRTY AND NEW ANTIVIRUS
Dec 06, 2009 | Pioneer Televison & Video
Pioneer SD-P62A3 62" shuts off - won't stay on
If this TV turns back only when it is cooled down than it has cold solder joints tha have to be resolderd.
Jul 07, 2009 | Mitsubishi VS-6055 60" Rear Projection...
Tv shuts itself down
This is due to bad caps read here what a cap is www.badcaps.net see you tv is getting hot as normal but the caps cannot stand it any more thus shutting the tv down. The bad caps would be more or less in the power supply unit of this TV. So you can buy a new psu or get it repaired by a expert.
May 25, 2009 | Mitsubishi VS-6055 60" Rear Projection...
Pioneer SD-582HD5 - screen went black, no sound, Poor remote feed
The blue tube might be leaking coolant in the high voltage area, that is the cause of the POP. This repair might not be a DIY because of the lethal high voltage surrounding the CRTs tubes.
The slow response from the remote could be because the coolant has affected the main board where the IR signal are going to the remote sensor.
Let me know if you require further assistance.
Dec 20, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer sd-t50w1
My SD P 50A3-K We unplugged it and now wont come back on to stay...we turn it on then the red lite comes on green flashes on then right back off.....Some times tv will come back on then it shuts it self off....please help thank you
Jun 30, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Shuts off
sounds like the high voltage transformer
or could be high voltage off the tubes.
not a good idea to keep this running as it will cause more damage, best to have service tech look at this since it's high voltage.
Be careful. This same problem burned a mark in the Blue crt on my pro730HD. Three months and the Service Tech and Pioneer have been unable to determine the cause (they claim). In the process they have blown two more crt's.
When your tv goes off, try turning it back on using the main power button instead of the remote. The button should be behind a flip-down strip below the screen. When it is working again, look for any faint colored spots in the picture most prominent on light backgrounds. Mine is a yellow Y in the center of the screen.
If there are no spots, I would suggest you don't use the TV until you get it fixed because eventually it will damage your crt ($750). Of course, as I said, they have been unable to fix my problem and I have had no TV for three months.
Nov 21, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-532HD5 Projection Screen TV won't turn back on.
the problem with pioneer projection tvs is that when they made the boards they never used enough solder for the circuits and you get cracks in the runs. thats why heat and cold will effect it. I had the same problem and I took out the board and resoldered every track I could and it works good now but my remote wont work if anyone has any info or prints to this tv please post on here
Jul 26, 2007 | Pioneer SD-532HD5 53" Rear Projection...
Televison & Video Logo
363 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
