Question about Dell Inspiron 1525 Notebook
AC adapter not recognized--battery will not charge.
When checking on battery performance, my Dell Inspiron 1525 reads "4% available (plugged in, not charging)" I have two identical chargers, and the laptop RUNS fine with either--but the battery will not charge. System setup reports the battery as healthy, but says that the adapter is unrecognized. I have tried uninstalling/reinstalling both the battery and the adapter drivers. I've read that a Bios update may be what I need, however I can't do this because my battery level is under 10%. I have reseated the battery about 5 times, and rebooted the computer. Left the computer off a while, same thing. It absolutely will not charge the battery, not even temporarily. Any help is very appreciated!
  • nicolemurphy May 25, 2009
    Yes, both adapters have the center pin in place and intact.
  • Frank Zhang
    Frank Zhang May 11, 2010
    could you see your every ACadapter DC out plug a round hole, is there a samll short centre pin inside?
  • 44 Answers
There's only 2 possible issue with this problem and 2 solution.
Solution 1 update the BIOS.
(for DELL system's it will require that the battery still has at least 10% charge meaning that this solution is not going to be possible unless you have another battery that is currently charged. if so go here ) the BIOS version there is A16, if you have a different version you can update it.
Solution 2 replace the motherboard
if the problem still persist after going thru solution 1 there's only one step you need to take, you'll have to replace the motherboard for this type of problem. I hope you still have warranty for this computer, you can either have it shipped at the DEPOT or have an onsite come out to replace it.
hope that helps.
hit me back on the results.
Posted on May 25, 2009
  • 191 Answers
Your laptop charging problem cause:
1) charger centre pin does not work so that the laptop can not recognize the charger, you need change another one test it.
2) if the charge is not original product that could not be recognized by you laptop( fake charger)
3) if AC adapter ok, and change other same battery tested still not fixed,
that means your centre pin detect circiut on the motherboard fail,
need to check and to fix.
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
  • Frank Zhang
    Frank Zhang May 30, 2009
    please take a rating if the solution helped you thanks! keep in touch your comment.
Inspiron 1525 charging problem
Try the following steps to solve it:
it of googling on the web and finally found the solution here.1 Turn off laptop.2 Unplug AC power.3 Remove battery.4 Replace AC power.5 Turn on laptop, allow OS to boot.6 Once logged in to the machine, perform a normal shut down.7 Unplug AC power.8 Replace battery.9 Replace AC power.10 Turn on laptop, allow OS to boot. The battery should once again be charging as normal.If it can't still resolve this problem, try a new laptop charger or repair your laptop dc jack.
If you plan to be on a budget for your dell 1525, you may try the following third party charger:
Replacement Dell Inspiron 1525 AC Adapter 65Watt 19.5V 3.34A
Oct 20, 2012 | Dell Inspiron 1525 Laptop Midnight Blue
I have a Dell Inspirion 1525. I have a fairly new after market replacement battery which I have only had now for 4 months. I am using Vista. As soon as I unplug, computer shuts down. I go to power settings...
The adapter is working correctly. The battery is either slow to charge or in need of replacement.
It's possible your battery isn't charging at all so to test this boot into bios -> battery status and watch it run overnight.
Sep 09, 2010 | Dell Inspiron 1525 Notebook
My Dell Inspiron 1525 is now around 4 years old and recently it has not been able to charge and only works when it is plugged in. Also when i start the laptop, it displays a message saying i need to...
As you say the system is 4 years old update the bios
your download link is here!
IMP. Be sure to plug in the battery and it should be charges above 10 % and the system should be connected to the mains power supply also ensure there will not be a power outage during the update process
this will resolve the issue 100 %
Dont forget to say thanks!
Aug 11, 2010 | Dell Inspiron 1525 Notebook
Problem of charging the battery
Check battery indicator. If OK, update BIOS. If no change, check battery bios info, if AC Adapter is incorrect, replaces it. Please comment if the information provided has been helpful for the improvement of my support assistance. Thank you and regards.
Jul 12, 2010 | Dell Inspiron 1525 Notebook
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Mar 14, 2010 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 battery doesnot charge
1. remove all external peripherals 2. try to use ac adapter alone check if laptop will power on. 3. put back batt in with ac adapter. 4. check bios (power on laptop keep tap on F2) 5. check for the bios version, battery info and battery health. 6. check if batt is 0% or 10% charge 7. check battery health and info if the ac adapter is determine or not. also check if batt is performing normally. 8. if batt has 10% charge then download the latest bios for your system. download it from support.dell.com
Nov 12, 2009 | Dell Inspiron 1525 Notebook
Does it mean that my battery on the Dell Inspiron 1525 is out if it won't charge anymore. It also won't work when the battery is removed and the AC adapter is plugged in
It's not the battery than. If you ask me - two possible problems:
1) The AC adapter is shot to hell and you need to replace it
2) The motherboard input plug is damaged and you need to service it.
Further diagnosis:
Test the AC adapters output plug with a voltage meter (if there is nothing than that's the problem, if you get a positive reading - its fault nr 2)
You can also try to borrow a AC adapter of a friend (only if it's the same model) and plug it in.
Best of luck.
Nov 12, 2009 | Dell Inspiron 1525 Laptop
Dell inspiron 1525 will not charge the battery
CHECK IN YOUR BIOS AND MAKE SURE ANY SETTINGS FOR POWER ARE ALL CORRECT ...SO THAT WOULD BE A F2 FUNCTION IF THE ABOVE IS CORRECT ...SEE IF THAT SOLVES THE ISSUE .
Jun 02, 2009 | Dell Inspiron 1525 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron will not work on Battery.
At the very minimum its your battery. The other side is that it could be your power utility inside your laptop. Lets try getting a new battery first.
Note: Try a different AC outlet first.
Mar 12, 2009 | Dell Inspiron 1525 Notebook
Dell Inspiron 1525 Notebook Logo
4,467 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
