Question about Whirlpool Dryers
Need to replace the power cord
How to replace electrical cord on dryer
    Problem Solver:
  • 14 Answers
This is actually one of the easiest repairs to make on most dryers.
Unplug the dryer from the wall of course.
At the point where the dryer cord enters the dryer itself there is usually a plate. One screw should hold this plate in place. Remove the screw and pull the plate out (it should only be held in by a couple of tabs). The cord is attached to the power supply with three (or four) terminals. Back the screws out and slide the cord out. Make careful note as to which color goes to which terminal. Usually the black (or red) color goes to the gold screw and the white goes to the silver screw. The green screw holds the ground wire in place which is also usually a green cord.
Once you have done this step then loosen the screws that hold the cord in place on the plate. This fitting should open as you loosen the screws and the cord should pull out easily. Then thread the new cord through the fitting and reverse the process. Just remember to thread the cord through BEFORE you connect the wires so that you don't have to undo your work!
Hope this helps!
Posted on May 25, 2009
Replacing electrical cord
if you buy a color coded cord and plug then red and black go on thee 2 outer terminals of the power terminal and the white wire goes between these as this is the neutral connection and if it has a green ground wire connect this anywhere to the metal case of the unit, if its a gray cord with no colors then the 2 outer wire on the cord go to the outer terminals on the units power terminal block and the center wire on this cord goes to the center terminal on the unit
Jul 28, 2012 | Roper REX4634KQ Electric Dryer
My dryer won't turn on what can i do?
Check house fuses or circuit breaker.
Ck. power cord and power outlet for signs of arching an replace if needed.
Ck. power cord at dryer side and make sure the ends are not burnt. Unplugged of course.
If all is ok call for service.
Jan 16, 2010 | LG DLE2532W Electric Dryer
LG DLE2514W Power does not stay on. Power cuts
If you move the cord @ the outlet and the dryer shuts off replace outlet if the prongs on the cord are not damaged.
If you wiggle at the dryer side and it shuts off un plug the dryer remove acess cover and inspect end of cord. Ck. and make sure terminal nuts are tight. and not burnt due to a loose connection.
Jan 12, 2010 | LG DLE2514 Electric Dryer
REPLACE POWER CORD WITH FOUR WIRE
black far left
red far right
white middle
green goes to ground
Oct 03, 2009 | Maytag Neptune MDE6700A Electric Dryer
Dryer will not start have replaced the heating element, door switch and on switch
hi, i recommend inspecting the terminal block that the power cord is connect to on the back side of the dryer. this terminal block may be faulty or, the cord could be lose and not connected properly.kindly, inspect this device that is located on the back side of the dryer for lose connections. if the termainakl block is in good conditon and, the power cord is screwed on tight, thsi iwll confirm timer fialuer.
replace the timer in this case.
May 20, 2009 | Kenmore Dryers
Changing power cord from 4 to 3 prong
See this link and read the article carefully - if your dryer already has a 4 wire cord, it should be replaced with same type.
http://en.allexperts.com/q/Electrical-Wiring-Home-1734/replacing-power-cord-dryer.htm
Apr 13, 2009 | Maytag Neptune MDE6700A Electric Dryer
Power Suply Cord
If the cord is the ONLY item you need and NOT the terminal block in the dryer, then Home Depot sells replacement cords with a molded plug attached as well as ring lugs on the opposite end for terminating them on the dryer block. You'll need to know if you are using a 3-prong or 4- prong set up in order to get the correct cord. Hope this helps..
Sep 06, 2008 | Whirlpool LER3624JQ Electric Dryer
Dryers Logo
267 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
