Question about Durabrand DU1301 TV
I have picture and sound when I watch a dvd/video but not through cable.
The tv receives the signal and show the channel and what is supposed to be on but after that goes away the screen is blue.  If I put in a dvd or video everything is fine.  My remote has long been lost and the remote for the directv box won't program for this tv.  The tv menu is showing everything in spanish but I don't know how to change this.  I'm lost.  Thanks for any help.  Any suggestions?
  • Aerospaced Nov 08, 2007
    Idioma=language in your menu options. Change this from espanol to englis. Then go to TV/Antena. Make sure you have it set to Cable.
    Please discribe all the conection details and video sources.
  • Durabrand Master
  • 520 Answers
Try turning off the dvd/vcr and put your tv on the output channel of your DirectTv receiver. If this doesn't work it may not be hooked up correctly.
Posted on Jun 26, 2008
HI, you can do these troubleshooting steps and get back to me..
Check the video connection of any devices plugged into the LCD television. If you can hear sound but are seeing no picture while trying to use something like a DVD player or cable box, the problem is probably that a wire is loose somewhere. Check the yellow video cables running from the DVD player to the TV and make sure everything is plugged in firmly and where it should be. Also check the coaxial cable running from the cable box (or cable outlet) to the television and make sure that wire is also screwed in securely.
Check the image settings on your television and make sure everything is set properly. Certain settings like "Picture" or "Brightness," if set to one extreme, can make the picture appear completely black. This could cause you to simply hear television shows but not be able to see them. Reset all picture settings on the TV to their original factory default settings to see if that fixes the problem.
Try another channel. If you're watching TV and not getting a picture, the first thing you should do is check a variety of random channels to make sure it is a problem with your TV and not with your television signal. If it is a problem with the television signal it is the fault of the TV station or cable service provider and there isn't anything you can do yourself to fix it.
Try the DVD on another DVD player. If you're trying to play a DVD and can't see any images, make sure the disc isn't defective. Try it on another DVD player or a computer DVD drive and make sure the disc works in the first place.
Hope it helped ..
Jun 17, 2011 | Televison & Video
Humming sound when watching tv,but not when watching dvd's
It wounds like you are getting interference from you tv to the receiver. You can try a few different things here.
1. Connect the tv output into another input on you receiver to see if it isnt the channel on the receiver.
2. Try a different set of cables between the tv and receiver. Faulty cables can give you problems.
3. Connect the cable from you tv to a different device. (another dvd vcr blue ray etc.) This will tell you if its the receivers or the tv.
Sep 13, 2009 | Yamaha HTR-6030 Receiver
Won't Show DVD Picture or Hear From Surround Sound Speakers
The lack of video in the DVD can be isolated to the DVD players output mode, if you are using the component video out on the dvd player then be sure to follow the componet out of Receiver to the tv component inputs, if you are using the HDMI from a DVD HDMI into RECEIVER HDMI then go to TV HDMI, you cannot mix component and HDMI on this model of AVR receiver and acheive results, in other words keep the COMPONENT to Component and HDMI to HDMI signal path, the results will be similiar quality audio and video UNLESS you are doing a blu-ray source which will result 1080P quality, all other video, HD results to 1080i, about the audio, if all 5.1 test tones are satifactory to speakers but on playback modes for DVD or HD tv signals all you are receiving is LR which is basically 2 channel (stereo) you need to enable a MULTI-CHANNEL capability input, this must be a option on the DVD Player Audio MENU output, be sure it is set for DOLBY DIGITAl 5.1 or DTS outputs, be sure to have the receivers digital input enabled if you are running optical cable or coaxial digital for the audio, you will be sending a multi-channel input to the receiver when the Receivers Faceplace LCD displays 5-6 speakers. If it shows only LR or two speakers it is not locking into a 5.1 audio input.
Feb 21, 2009 | Yamaha HTR-6130 Receiver
No Signals
You may have to access the initial setup menu to force the set to look at the cable input. Although that is typically the default today, it may be looking for signals from an antenna. Broadcast and cable use different frequency ranges so the set has to be able to see the range you are trying to watch.
Dec 06, 2008 | Philips 20PT6441 20" TV
Suddenly no sound & no picture overnight: is my TV dead?
If you have static siugnal, sure TV is not dead.
Check the aerial cable, ensure it is well plugged in and getting signal.
If you are using a receiver box, check cables to TV and receiver (freeview, sat, cable etc.), try setting channels on receiver again, if it does not work but you get static, then either the cables or receiver are defective.
Test the TV on standalone , connecting it to an external antenna.
Tune again the channels, and save the preset.
If still no signal then the antenna socket on the TV may be defective.
Try using the TV with a DVD.
If you can watch DVDs, and TV is not keeping channels preset, and you tried all the above, at this point htere may be a fault in the tuner card inside tv.
Call the phone number listed on tv user manual to get support, and eventually repair it.
Oct 03, 2008 | Panasonic CT-36HL43 36" TV
I have a 30 year old tv w/cable. I want to install a dvd/vcr combo player. What kind do I need? I've tried one and it didn't have the right connection.
If the original TV doesn't have audio/video inputs, you'll need a DVD/VCR player that has a built-in RF modulator. A RF modulator takes the audio & video and modulates a RF carrier to one of the channels that your TV can receive. In the U.S., this is usually channel 3 or 4. If the DVD/VCR player has a built-in tuner, connect your cable to the RF input of the DVD/VCR player and the RF Output of the DVD/VCR player to the cable input of the TV. This way, you can receive your cable channels through the DVD/VCR player and watch movies as well. If your DVD/VCR player does not have a built-in tuner, you can put a RF switch inline that will allow your TV to either receive the cable signal or signal from the DVD/VCR player.
- Jim
Jul 03, 2008 | Televison & Video
No sound or tv signal
Probably need the TUNER either fixed or replaced.
Apr 27, 2008 | Toshiba CZ27V51 27" TV
Unable to record one tv channel while watching another tv channel
You CAN record one channel and watch another with satellite service, but it would require two separate DBS receivers. The issue is that all satellite broadcasting is encrypted until it hits the receiver, which decodes it and transmits it outward toward your other AV devices. If it weren't for the receiver, connecting the coax cable to your other devices and trying to tune channels with them would yield no signal and possibly much frustration. You would need to split the signal into each receiver and have one connected to the television via one input and the other to the recorder then to the TV via another input.
With cable, you can split the signal without having to have two boxes - this way the QAM tuner in the cable box is still capable of tuning channels while the recorder can tuner basic cable channels for recording separately. You can also have the cable box connected to the recorder via composite so that you can record premium stations on a DVD recorder input mode anytime you like - but you would have to be watching that channel at the same time unless the DVD recorder had a pass-through RF signal (rather than a composite clone) - meaning you could also use coaxial to your television from the recorder and tune channels separately on your television while the recorder is recording one channel.
A lot of what-ifs there, but it is all quite possible.
Mar 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Multiple video inputs
Unfortunately, you cannot use the connectors at the same time. The S-Video connector overrides the standard video connector. This is why they share common audio left/right inputs. If you could use them separately, they would each have their own set of audio inputs. (S-Video does not carry audio signals on the cable.) I'm assuming that you are connecting your Satellite as an input to your VCR, and then your VCR to the TV via a video connection. The VCR passes the satellite signal through unless you are watching a tape, then it overrides the dish signal. You have a few choices here: 1. You can connect the coaxial (RF) output from the VCR to the TV, and watch the satellite and VCR on channel 3 (or 4). You can then connect the DVD via S-Video, and watch it on "video". This is the simplest solution, and provides the best picture quality for the DVD (with this TV), but lower quality for the dish and VCR. 2. You can connect the DVD player via RF (if it supports that), watch the DVD on channel 3, and connect the VCR via video. This will make the DVD picture quality terrible. 3. You can replace the VCR with a combo DVD/VCR unit. You can then connect the S-Video out from the combo unit to the TV. This is a more expensive solution. 4. You can replace the TV with a model that includes more inputs. This is the most expensive solution, but will allow you to watch your DVD over component cables (very high quality) and VCR and dish over S-Video. Ironically, the obvious choice, connecting the DVD as an input to the VCR (as a pass-through) simply WON'T WORK. The signal put out by the DVD player is "copy protected" (using a system called MacroVision) which the VCR will refuse to play, even as a pass-though. Best of luck with this. Given that you are trying to make this all work without replacing equipment, I recommend option #1, until you decide to break down and buy a shiny new HDTV. They are coming down in price every week, but only you can decide when the time is right.
Mar 22, 2007 | Sony KV-32S26 32" TV
Durabrand DU1301 TV Logo
83 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
