Question about Craftsman 20 hp 42 in. Deck Yard Tractor
Drive belt came off
Craftman 18 hp, 50" zero turn mower , drive belt has come off and I cannot find way to get to it without taking mower apart. is there an easier way?
  • 376 Answers
Go to... http://www.managemyhome.com/mmh/owner_manuals and enter your model #. It should be under your seat. This will give you the owners manual and will explain how to do it.
Posted on May 25, 2009
  • Dwain Pippen May 25, 2009
    I see you left a "Thanks for trying" comment. Was this not what you needed to get your belt back on? The owners manual tells you the proceedure. Did this not give you the information you needed? Dwain
How do I replace the drive belt on a 2008 50" troy bilt zero turn mower
You didn't include a model number so here is a link to Troy Bilt where you can download the user manual.
At top right click on owner center and follow directions.
Mustang 50 XP Zero Turn Riding Lawn Mower
Sep 11, 2014 | Garden
Troy Bilt Mustang XP mower belt diagram
https://www.partstree.com/parts/troy-bilt/mowers-zero-turn-lawn-mower/17wfcacp011-troy-bilt-50-mustang-xp-zero-turn-mower-2013/mower-deck/
Aug 27, 2014 | Troy Garden
What would cause a heavy vibration on my craftman riding mower, not caused from the deck, but by the v-drive belt for the tractor. i replaced it and without even putting the mower deck back on the vi
You did not finish the statement about without the blades but if your saying what I thing you are...Ah Oh Sounds like you may have a bent crank..Did you hit something with the blades...take the belt off and start the motor..and Check for wobble of the V drive there should be NONE if it does it could be bent itself or the crank...good luck
Jun 16, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Drive belt runs off 42 Toro
HI, I have a Cub Cadet 50" cut I had a similar problem and I had to change the spring on the idler pulley it had lost tension and replacing it solved my problem. Not familiar with your mower but if it has the same principles as mine you might want to try that.
Jun 13, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Tractor shuts off when clutch is engaged craftman 22 hp 50" mower
I had the same problem. My problem was something was preventing the blades from spinning, so the 1st thing you can do is check to make sure your blades turn, and test this while the mower is off.
While it is a pain, you can also take the deck out and check to see if this help and you are able to freely turn the blades. If everything is working properly, you should be able to turn the blades by hand.
In my case, I has a stick jammed into the belts and pulley, so when I would engage the blade, it would cause my mower to stall when it tried to engage the belt.
Hope this helps.
Dave
May 29, 2014 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Question on craftman riding mower
with the ground wire off the coil and it turns over, you have a bad coil these engines are notorious for this. GOOD LUCK.....
May 23, 2014 | Kohler 18 Hp OHV V-Twin Command Engine
Z force cub cadet zero turn belt problem
Try this one. It may have what you're looking for. Without your model #, I don't know.... http://www.partstree.com/parts/ Click on Cub Cadet then enter you model # on the left.
May 12, 2009 | Oregon Scientific Oregon Gator Mulcher...
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
212 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
