Question about Kenmore Dishwashers
Kenmore portable dishwasher 665.17822 can't remove filter
I have taken out the eight screw and cannot seem to remove the filter. My dishes are dirty, especially on the top rack - please help
  • 161 Answers
SOURCE: upper rack dishes dirty
Is it filling with enough water. Look or if you don't know how much water is supposed to be there , Just add a gallon of hot water to the machine after it fills. If this solves the problem check the filter in the fill valve or replace the valve.
Posted on Jul 05, 2008
  • 338 Answers
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Posted on Nov 25, 2008
larryyb
  • 291 Answers
replace the top spray arm and it should work ok again
Posted on Nov 27, 2008
  • 1214 Answers
SOURCE: Dishes not clean. Lower spray arm possibly not moving.
Remove the lower basket so you can access the lower arm.
Does it spin freely? If not, remove and clean the rotating point. Make sure the spray nozzles are not clogged and there as no chunks of stuff inside the spray arm.
Posted on Jan 24, 2009
  • 77 Answers
SOURCE: Dish racks for Kenmore Ultra Wash Model #665
www.Repairclinic.com is a great place to look. But from past experienc, dishwasher racks are very expensive and almost 1/2 the cost of a new one. Good luck.
Posted on Apr 21, 2009
Dishes don't always get clean, particularly on the top shelf. I suspect that the built in garbage disposal may be clogged. How do I take off the bottom water sprayer arm to get to the garbage disposal?
Greetings,
first off, let me say this..its not intended to be used as a garbage disposal.. it has a strainer(screen) and a blade that grinds up food , but not like you would use in your sink disposal. its for small amounts of foodstuffs that failed to come off after you have rinsed off your dishes.
the lower spray arm by un-screwing the center cap clockwise (yes this is the opposite of normal threading direction, the plug will go down and out the back of the spinner).
5) Both the fine filter (round 8") and the water conduit leading back and up to the top will need to be removed.
6) The water conduit has to be removed. It might be possible to take it apart, but the more direct approach is to release the back (here) clip, and the top clip.
7) A similar clip must be released at the top:
8) With the water conduit released from the clips, the whole assemble must be rotated thirty degrees clockwise about the central pump outlet. This will release this plastic item from its bayonet mount there so it can be removed.
9) Remove this thing.
10) Remove first of three torqx screws to release the filter. The screws are at ten o'clock, eight o'clock and 4'clock. This is the eight o'clock screw.
11) Remove the second of three torqx screws to release the filter. This is the ten o'clock screw.
12) Remove the third of three torqx screws to release the filter. This is the four o'clock screw.
13) Remove the filter and base.
Jan 09, 2011 | KitchenAid Architect® KUDT03FT 24 in...
I have a model#110774191 portable dishwasher(kenmore) it is not cleaning anything properly on the top rack. The water pressure seems good I have tried running vinegar through it I also use jet dry, I have...
the upper arm is blocked?and needs taken out and cleaned its very easy to do just pull out the top drawer and the arm will litterly pull off give it a good clean and it should be ok,also make sure the filter at the bottom is clean.adrian,,,,,,,,,,
Aug 17, 2010 | Kenmore 17248 Silver Steel Free-Standing...
Dishes are cloudy and seem to have a powerdy texture. Dishwasher looks coroded. Anything I can do?
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Dec 05, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
I want to take off the bottom screen to clean debris. I have taken screws out, how do I remove the screen?
You may to remove more screws from around the complete bottom part of your dishwasher. Have you tried to add Dishwasher Magic to clean the grit and grime out first? Or perhaps if you can't find Dishwasher Magic, we started using Tang Orange Juice powder before the days of the modern prodcuts. The citrus in the powder eats all the tiny food particles away.
In either case, empty all the dishes from the inside, add a cup of Tand or follow the instruction on the box of DW Magic. Run your d/w through a complete cycle.
This should clean your dishwasher out.
Hope this solves your problem.
You may contact us at;
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
with any questions or comments. Thanks, Ella
Nov 13, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwasher not cleaning - want to clean drain
We have a Kenmore 665.17702k600 Portable dishwasher with a similar problem. What we did was pop off the drain cover (turns out the one screw wasn't doing anything and just pushed down into the unit when screwdriver was applied). We popped it off by shimmying a screwdriver under the panel, and applying torque on the long end. It just popped right off. Then there was this nasty stale water, and not much obvious debri. We used a wet vac to slurp all that up. So that's the solution we took -- haven't tried it yet, so not sure if it will actually fix the problem...
Nov 02, 2009 | Kenmore Dishwashers
Kenmore Dishwasher 17369 not thoroughly cleaning
The first is to look for filters and drains to clean. Also check out the jets, as sometimes these can be clogged farther back than you can see with a quick inspections. You can likely remove them and take a good look. Secondly, you may want to switch detergents. Perhaps the quality of the water you are using has changed, hard water build up or you have changed detergents. You have to find the right detergent for the kind of water you are using, especially if you don't have a water softener. where the filter in the bottom of the dishwasher needed cleaning out. Just take the screws out, pull the plastic filter out and clean. Hope this helps. Report
Apr 19, 2009 | Kenmore 24 in. 17362 / 17364 / 17369...
Where is the filter on a Kenmore Quiet Guard 2 dishwasher?
I have a Quiet Guard 4. Same problem so will describe my solution.
1. Remove bottom basket. Remove top basket.
2. Remove bottom washing arm. Unscrew (Gently but firmly) the centre post. Lift arm assembly up and out.
3. Remove overhead conduit. One screw at back, one at top (Philips #2 bit). Rotate whole assembly 45 deg right (Clockwise) and lift off of centre post.
4. Remove centre post (Pull straight up). Remove 4 screws (Star T-20 bit). Lift whole assembly out. Pop off screen and clean.
5. Remove cap over cutter/chopper. There is a single screw at front left (under assembly removed in 4). Remove screw (Star T-15 bit) and cap (Needs some wiggling to free it up). Remove cutter and filter. It is on a spring loaded pin. Pull the cutter blade foreward and then the filter disc straight up. Clean thoroughly as it may be the cause of your problems.
Reassimble. Good luck!
Dec 09, 2008 | Dishwashers
Dishwasher not cleaning dishes good
ok in the dishwasher you will see you lower spray arm. take it off. now going up the back is the supply tube. you need to pop it off of thed top then the back and turn it clockwise to get it off the motor. after you do that you will see 4 torx screws. take all 4 out and you will be able to remove the fine filter. thats the normally grey piece with all the slots. after you remove the filter you will see two more torx screws. remove them they are for 2 seperate pieces one is the foreigh food seperator and the other is the chopper cover. remove both of them and clean the whole thing out. as yiou are puytting it back together. let me know if you get stuck
Dec 01, 2008 | Dishwashers
Kenmore dishwasher leave white stain in dishes
probably detergent. try cleaning the sump out. here is how
Nov 30, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwashers Logo
208 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
