Question about Kenmore Slider/Casement Air Conditioner
Every time the compressor comes on something starts to rattle loudly in the housing. I can stop the rattle by pressing down on the sleeve but this is not a practical solution. Any suggestions?
Every time the compressor comes on, something starts rattling loudly in the housing. I can stop the rattle by pressing down on the top of the sleeve but I don't want to stand there holding my air conditioner all day. Any suggestions?
    Novelist:
  • 166 Answers
Something is obviously loose. It may be the fan. See this diagnostic article on this topic:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Making_Rattling_Sound.htm
Hope this helps.
Brad
Posted on May 25, 2009
A/C making a rattling noise
I'm assuming that your '89 Chevy has the C6 compressor, which utilizes teflon sleeves for the internal pistons. The teflon sleeves wear out, and the small pistons slap inside their chambers, making a sound like marbles in a can. Eventually, the compressor will seize.
They're fairly expensive compressors, so brace yourself!
May 14, 2014 | 1989 Chevrolet C1500
Compressor rattles, runs hot, and runs longer than normal
This is the first sign of the compressor starting to fail.The more wear a compressor experiences, or the closer it is to failing, the longer the system will need to run to cool the refrigerator down to the proper level. This long running time will lead to higher electricity bills than usual, which is one of the first signs that something may be wrong with your compressor.
Apr 25, 2012 | Refrigerators
After I drive around in my mini van i hear a loud rattling noise. It seems that it is coming from the a/c each time it comes on. Once i turn the a/c off the noise stops. Any thoughts?
HI, this sounds like you have a normal Chrysler A/C compressor starting to fail. The electric clutch on the front of the compressors fall apart and cause this rattling noise.
YOu can get a good idea if this is the problem by standing on the passenger side and watching the A/C compressor and belt as someone turns the A/C on and off. Good luck
Aug 26, 2010 | Dodge Grand Caravan Cars & Trucks
It Rattles so loud that you can't even hear the person across the table from you it started a year ago with the compressor popping loudly upon turning off, now the whole thing rattles. What gives?
Check the fan underneath by the compressor... the fan blades are bent or coming apart...you can easily replace that condenser fan and blades...that will quiet things down for you...
heatman101
Apr 22, 2010 | KitchenAid KBFA25ER Bottom Freezer French...
Constant loud noise when frig turns on/comes from bottom
when the compressor is running unplug the ref. and if you hear the noise coming from the compressor then
a ballance spring may be broken inside the compressor.
The compressor will run normally with a broken spring it will just be annoying when it shuts down.
Jan 16, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Loud rattle noise when compressor cycles on
if this noise is coming from the compressor, it will eventually fail. If you just purchased it, i would ask for a replacement fridg and let the manufacturer deal with the repairs that it needs
Jan 07, 2010 | Refrigerators
There is a loud rattling sound coming from our fridges? freezer at the back near the fan. If I push on the cover over the fan, it stops but then starts rattling again after 1 minute or so. Any thoughts or...
This is something you need to have a look at soon. You need to know why the fan is hitting anything. It may be worn or have something like what we call shaft play. So I advise you to unplug and remove the rear panel in the back of the freezer just to see what is going on back there. May save you some down time if you see why it's hitting the cover housing or anything, Thanks, Sea Breeze
Sep 18, 2009 | Whirlpool GD2SHGX Refrigerator
My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
Frig makes a very loud booming noise/ratteling what is the cause?
The noise is coming from the compressor and is a result of a broken support spring inside the compressor. When the unit shuts down, the inner casing rattles against the outer casing because the spring is not there to keep them apart. The only fix is to replace the compressor but otherwise it is just bothersome.
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore Refrigerators
Amana Bottom Freezer
  I have found tubing rattling against plastic tray on right side in back.  Also found this tray rattling against frame.  You can take back off unit and llisten for noise.   Watch out for spinning condensor fan blade.  Very sharp,  believe me!!  Try pressing on tubing.
Oct 14, 2007 | Refrigerators
Heating & Cooling Logo
517 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
