Th edevice is 1.5 years old and has worked ok up until now.
SOURCE: PANASONIC DMR E85H
Yes you can.
You can get the instruction manual here:
http://service.us.panasonic.com/OPERMANPDF/DMRE85H.PDF
SOURCE: I have a Panasonic DMR-EZ47V
For an unknown reason the problem was solved by turning off the DVD recorder for a minute or 2 and this reset the the entire recorder. This was done because apart the means of resetting the tuning within the recorder's menu wasn't solving the problem.
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
SOURCE: panasonic dmr-e55 won't work, just says "hold" on display
HOLD or X HOLD? If the latter - which is most likely - then the Child Lock has been activated! Press and hold ENTER and RETURN simultaneously until HOLD disappears!
SOURCE: Panasonic DMR ES15 remote stopped working with dvd/recorder...
Try holding enter button and 1 together on the r/c for at least 3 secs
