Question about OfficeMax United Consumer Electronics International LENOVO UNITED STATES TC M57 SFF C2D/2.66 1GB-160GB MAX COMBO WVB PC Desktop
Shredder won't come on
No lights will come on, no jams anywhere, no nothing. all magnets are clear of debris. this is an office max shredder, model #om99733, would shred 15 papers, cd/dvds and credit cards.
  • 3,866 Answers
The question would be is it getting power!!! if so the motor went bad thus causing this to fail i cannot beleave yuo shred DVD's in this even know it says it can you are still putting alot of strain on the motor.
Posted on May 25, 2009
Shredder jammed and will not back up - how do I unjam it?
Carlo, unplug shredder, patiently use pick, scissors etc to remove stuck paper. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Unjam Paper Shredder
How To Fix Paper Shredder Jam Video
How To Clear Jammed Paper Shredder ABC Office
Best Way to Clear Out Jammed Shredder Ask Ozone
Jun 30, 2016 | Shredder Office Equipment & Supplies
My office max shredder OM99729 light says it's on but it does nothing and it has another light that says attention but nothing! ANY ideas?
it means your "Trigger" for a Jammed piece of paper is stopping it from running, sounds like something is Wedging it from turning, unplug and look into it for jammed up paper or a staple.
Jul 19, 2014 | OfficeMax Office Equipment & Supplies
My office max OM01287 Shredder has no power to it is there a rest button it worked just fine the last time I used it and now there's no power?
Double check the safety that stops the shredder when it is full sometimes that switch gets jammed with cut paper. Also make sure the top of the shredder is level and properly seated back on the base unit. The shredder feed area may also need to be cleared there may be a staple or just paper jammed into this area as well, make sure the unit is unplugged before trying to inspect and clear and part of the shredder
Jan 16, 2013 | Office Equipment & Supplies
My office Max OM01287 Shredder will only run in reverse. There appeared to be a jam in the cutters and with tiny tools and very careful grabbing I seem to have cleared the jam from tiny pieces of paper. ...
There is still a shred of paper jamming the microswitch that sets the shredder into reverse to avoid an even worse jam. Find that microswitch, usual;ly on the left or right side, activated by a plastic flap on the basket side of the shredder. Clear it. As you move the plastic flap up and down you should hear it click. No click, the switch is jammed.
Mar 12, 2011 | OfficeMax Office Equipment & Supplies
My fellowes paper shredder is not operating. we have lifted the shredder head and fitted it back on the basket but nothing happened
Instructions
Step 1 Shut off the shredder. Unplug it and let in cool down for up to one hour. This will work if the shredder has stopped due to excessive use.
Step 2 Check to see if the shredder is jammed. This is the most common cause of shredder problems. Click the power switch to reverse, which should clear a minor jam. If not, set the shredder to auto, and then to reverse again until the jam clears.
Step 3 Clear extremely stubborn paper jams by grabbing the stuck paper and gently pulling it out. If smaller pieces of paper cause the jam, shut off the shredder and unplug it. When it cools down, carefully use a pair of tweezers to remove the paper bits.
Step 4 Determine if the power supply to the shredder is working properly. If the power supply is cold, use an alternative source of electricity for your shredder. If it is warm, there may be a problem with the shredder itself. Call your office machine repair shop or the shredder manufacturer for assistance.
Step 5 Sharpen or oil the blades. Shredder blades need to be oiled on a regular basis to keep your machine in proper working order. Get oil made specifically for shredder blades from an office supply store.
Good Luck!
Jun 19, 2010 | Fellowes P48C Cross Cut Shredder with...
New shredder broke allready, it jamed up, i cleared it, the on light does not go on, nothing works.
The shredder only jams when too much paper is inserted.......
if it won't go, then as this is probably a consumer machine then the pcb inside may have blown...call the manufacturer.
Mar 02, 2010 | Office Equipment & Supplies
I had paper jam in the Ativa Dq60M shredder but now doesn't work
it might be over heated. Just wait until it cools down and try it again
May 03, 2009 | Office Depot Ativa DQ60M Shredder
Office max paper shredder
You need to find out who made the shreddr, Fellows, GBC, etc. parts are available to brand name machines...
Jun 03, 2008 | Office Equipment & Supplies
OfficeMax United Consumer Electronics International LENOVO UNITED STATES TC M57 SFF C2D/2.66 1GB-160GB MAX COMBO WVB  PC Desktop Logo
150 people viewed this question
Top OfficeMax Computers & Internet Experts
David Payne
David Payne
Are you an OfficeMax Computer and Internet Expert? Answer questions, earn points and help others
