Question about Kitchen Ranges
I have the Dacor ECD230 SCH standalone twin ovens. The power is on but one of the two ovens is not heating up. I am wondering where should I start checking the problem. I refered to the manual but it is of no help.
  • 2 more comments
  • vbhutada May 25, 2009
    Thanks for your quick response. I have two follow-up questions:
    1. Do you know how can I remove the heating element from this oven and check them out?
    As I have twin ovens, I am thinking if I can interchange the heating elements and check. That way, I can isolate the problem.
    2. I have a multimeter. Can I use this to check if the heating element is working or do I need to have only an 'Ohm Meter'?
    Please let me know.
    Thanks.
    Vikas
  • vbhutada May 27, 2009
    I tried swapping the heating elements but still the top oven does not work.
    Whereas the bottom oven (that received the heating element from the top oven) continues to work.
    This proves that both the heating elements are fine.
    What should be the next step?
    Please let me know.
    Vikas
  • vbhutada May 28, 2009
    I can't trace the fuse. The oven is kind of 'fixed' in a wooden cabinet and I do not know how to get to the back side, from where the wire for the heating element is coming in.
    Now, I also suspect that it could be the fuse problem (as it had happened once in the past and a technician had fixed it). However, in the absence of any info in the manual, I am unable to locate the fuse. Any tips?
  • vbhutada May 30, 2009
    Thank you so much for guiding me step by step in the right direction. Your help with the technical manual helped me solve the problem. It was a simple thing like resetting the heat switch but I would not have been able to locate it if you did not help me. Appreciate the help with the resolution of the problem with my Dacor wall oven. Thanks a lot!
    Vikas Bhutada
  • 230 Answers
It's very likely the oven element is faulty, this can be checked using an ohm meter. If the resistance is infinitely high then the element is no good. If the oven that is not heating is showing a higher temperature on the display than what it is then it's the temperature sensor.
Posted on May 25, 2009
  • 1 more comment
  • Dudeman321 May 25, 2009
    The multimeter will work as an ohmeter you just need tob put it onto the resistance range. This is normaly indicated by the 200, 2000, 20k 200k and 2000k ranges and also the continuity test (little speaker picture). Any one of these ranges would be fine. I'm not sure the exact procedure for this model of oven, but the normal route is to remove the back panel where the fan lives and this will reveal the heating element. Swapping these over would be a smart diagnosis plan. When you swap them over be sure not to let the wires touch each other nor themselves and be double sure the power is off when you are doing any tests/touching anything.
  • Dudeman321 May 27, 2009
    Try and follow the wires to the heating element back to the control board and there should be a fuse there somwhere, see if that is good. (You can use an ohmeter for that) Should measure 0 ohms or there abouts.
  • Dudeman321 May 28, 2009
    There is a high temperature cutout switch that has a reset button, try resetting that and if that does'nt work test it with a multimeter on the resistance x1 position should measure low resistance, you could swap them around from the working side. They are located near the latch assembly. The only other likely problem that could cause this is a bad relay board, the oven would likely have to come out of the cabinet for this, the relay boards are located in the top of the oven behind the front panel. The top needs to be removed for that. Here is a site with diagrams and technical information if it comes in handy: http://dacorservice.com/PartsCatalog/pro...
    hope this info comes in handy.
I ran the upper oven cleaning cycle and now it doesn't heat or broil. I have tried the reset of turing onff the breaker for 30 minutes and that did not work.
CHECK THAT YOU HAVE 220 AT THE PLUG OR POWER CONNECTIONS. TURN OFF POWER AND CHECK THE CONNECTIONS TO THE ELEMENTS MAY HAVE BURNED . IF OK AND NO VOLTAGE THEN CONTROLS.
Mar 11, 2010 | Dacor ECD230 Epicure Electric Double Oven
Top oven works fine bottom oven won't heat
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Dec 10, 2009 | Dacor ECD230 Epicure Electric Double Oven
Dacor ECD230 lower over won't heat up after cleaning
Under the panel between the ovens there is a little square box with a reset button on it.
Feb 01, 2009 | Dacor ECD230 Epicure Electric Double Oven
Dacor ECD230 Sabbath Mode
You don't need to do anything special.
Quoting from Daco.com FAQ
"In our ovens, the cooling and convection fans do not turn off when the oven door opens. The lights also do not turn on. There is no timed shutoff on our ovens, either, meaning that once they are turned on, they will stay on until you manually turn them off. Both of these would be considered violations. Our ovens do not have a special Sabbath button because our ovens already adhere to the laws. When the oven door is opened, there are no changes to the control panel, which would also be a violation. It is best to wait for the small "On" light with the circle around it to go on before opening the oven door, though. This light indicates that the element has gone on, as the oven cycles on and off to maintain the selected temperature. Opening the oven door without this light going on may trigger the element to go on, which can be a violation."
Mar 25, 2008 | Dacor ECD230 Epicure Stainless Steel...
My Dacor ECD230 stopped heating???
The high limit switch has tripped on this unit. Remove the vent panel behind the door and there will be a button in there behind the wires. Press this button with the circuit breaker turned off and that will rectify the problem. You still might need a servicer out to take a look at the unit though
Nov 21, 2007 | Dacor ECD230 Epicure Electric Double Oven
Kitchen Ranges Logo
50 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
