The occurred a day after it was last ran and the clean light had been on for at least 1/2 a day. the washer will not run now.
Not sure which particular model you have got. If turning off the mains power off and on is not helping then you will need to reset the controller. "press your "Normal" button then your "Heated Dry" button alternatively several times (quickly). This should reset the control panel and allow you to resume normal functioning."
Read more: http://forum.appliancepartspros.com/dishwasher-repair/11043-control-panel-lights-blinking.html#ixzz2psYY7aFn
SOURCE: clean light flashes
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all
the lights will turn on briefly and the machine will start a diagnostic
cycle. You can press cancel or let the diagnostic cyle finish (1-2
minutes).
You should now be able to run the dishwasher as normal.
SOURCE: Dishwasher: Green light flashes and will not turn on
Hi
Please press the following sequence to reset the washer "Heated dry" "Normal" Heated Dry" "Normal". This will reset the machine. Also try and locate the tech sheet in lower kickplate.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
SOURCE: The clean light in my Kenmore dishwasher keeps
It has to do with the water temperture, either the water entering the dishwasher is too cold and the heater can't get it up to temp, or the heater unit has problems... Push the Air dry ,then the sani wash buttons a few times and all the lights will light, it resets the computer .
SOURCE: **My dishwasher normal light keeps blinking**
I have the same problem. I have tried turning off the breaker and the door seems to be locking, but still won't work. Any other suggestions?
SOURCE: whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
