Question about Ruud Central System Air Conditioner
THE UNIT OUTSIDE WORKS OKAY HAOWVER THE INSIDE FAN NEEDS A MANUAL PUSH TO REMAIN RUNNING.
I HAVE AN UPKA 031 JAZ UNIT WHICH IS WORKING PROPERLY OUTSIDE HOWEVER THE INSIDE FURNANCE FAN NEED A MANUAL PUSH TO RUN. WHAT COULD BE THE PROBLEM?
  • optkdsport May 25, 2009
    iT'S STILL WORKING SINCE THIS MORNINGS PUSH....MOST ASSURE I'LL HAVE IT SERVICED.
    THANKS
  • 116 Answers
Fan motor capicitor
Posted on May 25, 2009
Sometimes the fan inside comes on but outside unit isn't running
Its likely a computer generated time delay so the refrigerant can equalize pressure. Its a safety working properly.if people are fighting over the temp, and it shuts off and someone turns it down to soon, the result you described is normal, even essential.
Jul 15, 2012 | Coleman York Evcon Furnace Control Circuit...
Does your furnace have an adjustable fan limit switch it has to be adjusted. If it has a timer check if it can be adjusted.
My ruud serial number 5427 M1496 07992 Model UAKA-024 Jaz Is not blowing cold air. I started the unit inside the house then went outside to see if the fan is working on the outside unit and it is...
1) Replace both fuses if there are any out by the unit
*also make sure the breakers are not tripped. there will be two
2) if you get the unit running inspect the outdoor coil under the outside fins to see if the coil is stopped up with dirt,grass, etc.
*if the coil is dirty, disconnect the unit from power, take the 4 screws out on the top of the unit that hold the fan motor assembly in place. Carefully set the entire motor, blade and assembly off to the side and be careful not to pull the motor wires loose. With a water hose and sprayer, carefully wash the condenser coil from the inside out. You will see a lot of debris on the outside fins you will have to wash off. Be careful not to have so much water pressure that you bend the aluminum fins on the coil itself.
** many times if the coil is stopped up this will cause the unit to overheat and trip breakers
Apr 13, 2011 | Ruud UAPA024 Air Conditioner
I have a Rheem Heat Pump unit. This winter, the outside unit fan at times trips off, but the inside unit keeps running continuously. I woke up one morning & it was 62 in the house. The inside unit ran...
Dear Friend!
Due to very low ambient temp, the fan will not run. Once the pressure build up, it's automatically run for some time and again cut off. But if you keep Heat mode and still tem not raised in your room means the reversable valve not working and hence the compressor and out side fan also will not work. Keep "Heat" mode and temp setting +29 to get better heat. Hope is it helpful?
Dec 10, 2010 | Heating & Cooling
My contactor switch will not remain engaged. I
Something,is drawing too many amps,most likely the compressor.
Jul 08, 2010 | Frigidaire FAA065M7A Air Conditioner
Does ruud unit model # UPKA 061 JAZ have a reset button
Yes it is a little red button on the back lower part of the heat pump by the lineset. it will most commnly trip in heating mode if the filter is dirty. or in A/C mode if there is an issue with the outdoor fan motor or dirty coils.
Oct 14, 2009 | Ruud UBHC Air Conditioner
RUDD UPKA-061-JAZ Specs:
Ruud Air Conditioning Division • P.O. Box 17010
Fort Smith, AR 72917-7010 • 479-648-4900
Jun 13, 2009 | Heating & Cooling
RUUD HEAT PUMP COMPRESSOR FAILURES UPKA-061-JAZ
Newer High efficiency A/C's are not compatible with the older systems for many reasons. They use a different refrigerant, have a different oil in the system for lubrication and they operate at higher pressures than the older systems using refrigerant 22 which is being phased out. It is standard procedure to replace the entire system when upgrading.
Mar 31, 2008 | Ruud Central System Air Conditioner
High Pressure Shut Down
Hi, If the outside fan is running when this takes place and the condenser is clean, I believe its the High Pressure Control that is bad. There is a possibility that if the unit was opened and air was allowed to get into the refrigerant part on the system that it could cause this problem but unless the system was worked on just prior to this starting, I don't think this would be the case. The part about draining the freon to check the orifice doesn't sound right, This could be done with a pump down by closing the suction line valve at the condensing unit which leaves the freon in the condensing unit. If they charged you to replace the freon, I would question them about this procedure. Hope I have helped. kstfas
Sep 09, 2007 | Ruud UAMB Air Conditioner
Ruud Central System Air Conditioner Logo
186 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
