Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Problem with Sears Garage Door Opener
When I try to open or close my garage door, the door stops after moving only a few inches and the light on the opener flashes. The garage door will open or close completely only if I hold down the button on the remote or wall switch until the door is fully opened or closed. I've checked for something in the way of the electric eye, and don't see anything there that could be causing the problem. Any ideas as to what is wrong and what I need to do to fix it? Thanks.
  • 3,866 Answers
The motors is cought on something check the motor if it moves inches it will move a yard the question is the motor is it getting power? if so is it stuck on its own drive chain? Check these things you be glad you did.
Posted on May 25, 2009
Why does garage door opener only move a few inches?
Check the spring above the door, mine would go up a couple of inches and we found that the spring had broke.
May 16, 2014 | Sears Craftsman LiftMaster Chamberlain...
Garage door only raises about two inches then stops.
Check the door springs and also remove the cover from the motor unit and check the drive gear. The door spring could be broken or the drive gear may be stripped.
The sensors only work when the door is closing.
Jun 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
My door closes fine, but when opening, it only
Remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor and may be stripped. If so you will also find what looks like white sawdust inside the motor unit.
May 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
When i try to close garage with transmitter or keypad it moves a few inches and stops or goes back up
If the main light flashes 10 times when the door reverses it is a door sensor problem. Make sure the small light on each sensor is lit and not blinking. The sensors must be pointed at one another to work properly. If you cannot get both lights to come on you have a bad sensor.
Oct 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 1265 garage door opener, tried to
On the side of the motor unit you will find the 'down limit control'. Using a small screwdriver turn this control in the same direction as the arrow printed on the cover. Some tweaking may be necessary to get it just right.
Oct 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Power shuts down when I try to close or open
Your motor may be working too hard anad ripping the reset button on the garage door,
Try increasing the power on the unit ( should be some type of dial.) or the door may be jamming up somewhere, Try disconnecting the opener from the door and see if it goes up easily, the door might need service
Jun 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door does not open all the way stops @12 inches
You most likely have a broken door spring. Release the door from the opener and try lifting it by hand. Look above the door for the springs.
Mar 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
366 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
