Question about Craftsman Garden
Need a replacement impeller for Craftsman blower
All I need is a source for a replacement impeller: it's a plastic part ~4½" in diameter that threads onto a 5/16"-18 shaft. According to Sears, it's been discontinued. The model of the blower in question is Craftsman blower model 257.796351.
  • 7 Answers
Toro impellar is the same thing...even same part#(1009068)
Posted on Nov 14, 2011
Lay-Z-Spa pump impeller replacement
In order to find the proper replacement you will need to provide someone with the following information.
  • amps
  • voltage
  • discharge size pipe
  • suction size pipe
Rod
US Parts Center
Jun 01, 2013 | Home
Hotpoint ctd80p dryer. Noisy from rear. Took off heater cover and discovered what i think is the cooling impeller which has worn out plastic splines which fit on the shaft that comes from motor. Is all i...
Hi and welcome to FixYa, I am Kelly.
The fan should just be a slide on the motor shaft snug fit with a metal clamp. The Blower wheel (fan) when they fail usually crack the center hub and no longer fit will on the motor shaft sungly so it contacts the blower housing as it rotates. That is why you hear all the noise. If the blower wheel / impeller as you referred to it does not fit tightly on the motor chaft then you will have to replace it. It should rotate in a true non-oscillation pattern like a circular saw blade. Any side to side movement during rotation is cause for replacement.
Here are 2 sources for a spare part:
http://www.spares4appliances.co.uk/s4ag1253-whirlpool-tumble-dryer-blower-wheel.html
(^- best price)
http://www.tdspares.co.uk/proddetail.asp?prod=mfn1024&cat=210
Thanks for choosing FixYa,
Kelly
Aug 18, 2011 | Dryers
The Impeller is gone, Craftsman has no more of them. They are worth about $2 IMO. Its like 4.5" & plastic. I see many folks have the same problem, anywhere you can point me? Blower has been used...
auction ends in about 30 minutes, Hope this helped Tim:
http://cgi.ebay.com/25cc-craftsman-gas-leaf-blower-parts-model-358-794941-/150600458042?pt=LH_DefaultDomain_0&hash=item23107c9f3a
May 10, 2011 | Garden
I have a 3 yr old 26" snow blower. I ran the machine up against hard packed snow/ice and now the auger spins freely and all shear pins are still in place. The secondary impellor functions fine. I...
I am going to assume the belt is good if the impeller it running. You can check the belt by removing the plastic cover in the center of the snow blower.
With the unit safely turned off reach in and turn the blower by hand while putting a little resistance with your other hand on the impeller. Does the shaft from the impeller to the gear box turn?
Does the shaft that the augers are attached to turn? If the impeller shaft turns but the auger shaft doesn't, the gearbox in the front is bad and will have to be replaced.
I the auger shaft turns, check your shear pins again. Sometimes they will break but still stay stuck in the holes. Actually take one out and check it.
If it is a Craftsman you can get a manual from managemyhome.com and parts from searspartsdirect.com. You will need the model number of the snowblower. The number looks like 247.123456.
Any other questions please ask. Do't forget to rate this answer!
Jan 16, 2011 | Craftsman Garden
My blower is running extra high and hard. so high that it shakes the cap off. how can i tame it down. model 51587
Remove the bottom of the blower or vac and see if any blades are broken on the plastic fan blade, known as an impeller. If a blade is sheared off, this could be the source of your noise and shaking. This part will need to be replaced. I've just ordered one and will be replacing mine when it comes in.
Jan 06, 2011 | Toro "Toro" Super Blower/Vac
Don't know how to attach the vacume
The discharge tube and collector bag will replace the blower nozel ( where the air comes out when blowing). The large diameter tube ( pick up tube) will attatch to the impeller side. There is a plastic gaurd on a spring loaded hinge. Open the gaurd and attatch the large tube.
Nov 28, 2009 | Poulan & Vacuum Kit Attachment
Can't figure out how to attach the vacuumm to the blower of our Craftsman Gas Blower/Vac #7179474
I know people buy this equipment to blow and vacuum. The main problem is if you vacuum up something that hits the impeller and breaks off one of the fins; you will have to take it somewhere to get the impeller replaced.
I would stick with it using it as a blower and get the rake out to get around the bushes.
Good Day.
Oct 25, 2009 | Craftsman 4 Cycle Blower/Vac
Is an impeller available for the CRaftsman 257.796351 Blower
i check on your unit the part is 3983-0-15 its N/A. sorry but no its no available any more
Oct 17, 2009 | Craftsman Garden
Is there a collection bag that will work with a Craftsman electric blower/vac. A bag that fits over a trash can with an 8' hose similar to the Black and Decker bv-006
I have not heard of one for that unit. Plus I would not use it for vacuuming any way. All you need is for an acorn or piece of wood to hit the impeller.
It would break a couple of fins off the impeller. This would make the blower vibrate like crazy and you will not want to hold on to it. Plus the cost of repairs would exceed the cost of a new one.
Good Day.
Oct 12, 2009 | Craftsman 4 Cycle Blower/Vac
I have craftsman snow blower 5 hp 24inch model #
does the impeller spin and not the augers.if so check sheer bolts.if neither impeller or auger spins check auger belt.
Feb 22, 2009 | Craftsman 16" High Garden Tractor Snow and...
Garden Logo
1,081 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
