Question about Danby DPAC12030 Air Conditioner
Water dosn't drain properly ( into lg. tank ) and eventually lea
The small tank that attaches to the main unit broke off. I can still fit the tank so it rests on the unit. When I firs start to use the AC the tank either dosn't fill or partialy fills. After a few weeks of this the machine leaks and I must place pans under it to catch the water which must be emptied hourly on humid days.
From the beginning the machine vibrated quite a bit. I had to call for service who brought it back in the same condition. As I had waited for some time to get the unit and waited 20 days for them to return it unfixed I kept it-BIG MISTAKE
3 Suggested Answers
  • 958 Answers
SOURCE: water tank is suddenly filling up
look closely how the water flows from the evaporator to the tank. does it goes first to the condenser ?..or is there a heating pipe that is touching the tank in order to heat the water for it to evaporate?
here's the set up, your ac would cool and absorb moisture in the air and becomes water in the evaporator. these water is sometimes used to cool the compressor or the condenser to help it run cooler and at the same time evaporates the un-needed water . but incase the water is so much then you have the tank to keep the water from spilling. sometimes they still put some hot pipes to further heat the water to evaporate.
check those pointers that i have mention.
in some case, the air in your place just got humid and wet that is why it has too many water condensation..
Posted on Aug 08, 2008
  • 9 Answers
SOURCE: When I turn on the ac, it beeps many times the red light says on
why did it fill up? because the drain is plugged there should be a safety switch that is keeping the comp off. find and clean the drain system.
Posted on Aug 30, 2009
Were do i get the manuel for model number ph3 12r03 is the model number were or how do I drain the water and can you send me a manual
Here is the link to the manual:
http://s3.amazonaws.com/szmanuals/b0348062b23e23cd40550b61e1dc5f43
Here are those particular instructions:
Compressor Indicator
The " " icon will light up on the control panel display when the compressor turns on. The " " icon will turn off when the compressor shuts off.
Emergency Condensate Holding Tank
When the room temperature is low and the indoor humidity is high, the air conditioner may not be able to evaporate some of the moisture fast enough. When this happens, the water will accumulate in an emergency condensate tank inside the unit. Once the emergency condensate tank is full, the unit will automatically shut off and the " " will appear on the control panel display. To empty the condensate tank, unscrew the screw plug at the bottom back of the unit. You will need a small pan, approximately 1" high to catch the water coming out of the condensate tank. Once the condensate tank is drained, the unit will begin working within a few minutes. The emergency condensate tank holds approximate
ly 1.5 Liters of water.
Another option is to purchase a small hose from a hardware store that can fit around the 5/8" drain plug on the back of the unit and drain the unit into a gravity drain or larger pan for continuous drainage.
To resume operation quickly, empty the water container according to the following steps:
1. Turn the unit off. Do not move the unit when the water container is full.
2. Place the drain pan accessory under the drainage port at the back of the unit.
3. Remove the screw plug from the drain hole. The condensate water will drain out automatically. When the drain pan is full, screw the screw plug back onto the drainage hole to stop the water flow. Empty the drain pan. Repeat until all the water is emptied.
Once the water container has been emptied, screw the plug back onto the drain hole. Do not allow the
water to drip continuously into the drain pan, as it might easily overflow.
Jul 13, 2014 | Soleus KY-34 Portable Air Conditioner
Remove Water Tank
  • require you empty the unit by hand (usually less expensive units). These have either a removable water tank which must be emptied, or have an internal tank and a drain, where you have to empty the water into your own pan. Sometimes the drain is on the bottom of the unit, making it hard to find a pan that will fit under the unit to drain it.
  • discharge most of the water through the exhaust hose (usually more expensive units). This is called "Auto-evaporation" or "Self-evaporating" feature.
Most units are made so that they can be drained with a gravity hose that flows to a drain inside or outside your house. But the water must drain down. If the drain is higher than the unit, you may need a condensation pump to move the water upward. A few units do include a pump to send the water a short distance through the drain pipe.
do no forget to rate the solution as fixya if it helps you.
thanks.
Jul 02, 2008 | Danby DPAC10031 Air Conditioner
Water in salt tank looked bad so i drained it should i put a couple of gallons of water in the salt tank after draining it to get circulation back again ?
The main problem in water softening units is that people continually use pool salt because it is cheaper. Most find eventually that it is not as it blocks the medium in the tank with sediment and rubbish. You may have to replace the medium in the system and restart the regeneration process Best policy is to use only kiln dried water softener salt It IS different.
Feb 10, 2013 | Tools & Hardware - Others
Culligan n8 black hose fell off and water was flowing out until i turned off the valve how and where do i re attach thx
If the "black hose" is about 1/2" in diameter it attaches to the drain elbow on the left side of the valve. Use a hose clamp, cut some of the drain line back (about 2") slide it back on the drain elbow and clamp it on the elbow.
If the black hose is 3/8" it attaches to the fitting on the salt tank, which attaches to the float.
If it broke because it is brittle I would go to any water treatment dealer and get a new piece of "brine line" to replace it.
RJ
Oct 10, 2011 | Culligan Under Sink Water Filter
I have a Richmond model 8MV50-2B. I'm having issues draining the tank to check the electrodes. Normally, on a water heater there is a shutoff down near where you attach the garden hose to drain the...
Problem is not clear.
Is water heater clogged and not draining?
What kind of shut off is normally located down near drain valve on electric water heater?
If you have gas heater, you can normally just rotate knob to pilot to shut off burner.
If you are draining electric water heater, normally you turn off circuit breaker, attach garden hose to drain valve, open drain valve by turning counterclockwise, open TP valve or open bathtub faucet, and then water drains out.
Open following links for illustrations.
http://waterheatertimer.org/Water-heater-will-not-drain.html
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Aug 13, 2011 | Water Heaters
The water drains from the water container into the bottom of the unit. The water container does not leak, I have tested this by filling the container up and leaving it the sink. I have adjusted the...
Hi heeg_mark,
Leaks problem most often occurs when the water tank is not seated properly allowing water to drain out of the tank and into the base. There are alignment pins on the tank that fit into holes in the coffee machine. Make sure this alignment holes are clear of any debris. Coffee beans have been known to make their way into these openings. Please use a flashlight and a small mirror to see down into the alignment holes. You can easily fix this by following the steps below.
1. Please remove the water tank.
2. There is an access opening like a round hole in the base beneath were the tank fits into the machine.
3. Using an absorbent cloth material dry the water through this opening. Please be patient, it can take sometime.
4. Once the water is gone the machine will operate normally again.
Hope it helps.
Thank you for using FixYa.
Jan 09, 2011 | Miele CVA615 Espresso Machine
Is it possible to contaminate the membrane and filters by placing drain under pressure in order to clear and forcing water out the overflow on the side of the faucet of the whre 25 Reverse osmosis system
OK, now I understand. First, on the Reverse Osmosis Membrane Housing Outlet Ports there is only a Check Valve attached to the Permeate (Pure Water) Port, not the Concentrate Port (Drain Water). The Permeate line is what fills the storage tank, so you don't want back pressure from the tank reversing into the membrane filter which could severely damage it. So, there is a high Risk for Sewer Water to Back-flow into the Membrane Filter and Contaminate it as it is discharging water to the sewer drain if there is any noticeable pressure restriction in the drain distribution manifold. Second, this is why "Air-Gap" Faucets are supposed to be used when installing Reverse Osmosis Systems. With an Air-Gap Faucet, there are three (3) attachments for tubing at the base of the faucet, and a small hole drilled out underneath the lever or handle of the faucet. The 1/4" pressurized drain line tube from the RO System attaches to the 1/4" barbed fitting under the faucet base, then a 3/8" drain line tube attaches to the 3/8" barbed fitting. So when the drain water is pumped up to the faucet under pressure, it returns to the sewer line under Gravity, or No Back Pressure. Then, if the plumbing becomes restricted in any way that the RO Unit can't drain into the sewer under gravity feed, the hole drilled in the base of the faucet allows the back pressure to be escaped to the atmosphere, and if necessary drain water out of the hole until the plumbing pressure restriction can be resolved. This eliminates the possibility of a reverse flow pressure situation from occurring. Hope this helps, and you can always visit us online at www.puresafe.com We have filter cartridges for all makes and models of RO Systems, and 1/2 micron filters that no one else in the trade is using at this time. Thanks, Victor
Aug 05, 2009 | Whirlpool WED6400S Electric Dryer
Red light is on???
You need to empty the water in the tanks, there are two one is external the other is internal if you do not have the external tank attached do so and with the unit of, then turn the unit on and put it in cool mode and watch for the water to drain if this does not work emty the water from the scre holes with the unit unplugged and drain it outside you will need leverage as it will need a slight tilt to do so. Hope that helps..
Jul 31, 2009 | Danby DPAC120068 Air Conditioner
Kenmore washer drains too fast
Unfortunately the only way to restrict the flow directly would almost certainly cause the machine to malfunction, as the drain pump and valve system is not designed to deal with significant downstream pressure. The only way I can think of would be to install a small tank (a jerrycan or similar may be ideal) that will take a full load's worth of waste water. Connect the tank to the washer, and ensure there is an air-hole/breather at the top. Fit a pipe low down in the tank through a normal (ball-valve type ideally) tap, and open that tap just enough for the new tank to drain slowly into your drain system. (some camping shop type water cans may already be fitted with a tap that may be suitable). The height of the tank would be the only thing you would have to be careful with, as the bottom drain would have to be above the outlet drain pipe, and the top inlet from the washer would have to be below the maximum level permissible (usually described in the leaflet with the washer, normally only a few inches/centimetres above the top of the washer is the maximum recommended, sometimes just below the top of the washer). Get a plumber to check for blockage in the drain line, as the amount of waste water from one of these machines should rarely be too much for a properly functioning drain unless the pipe from the machine to the main drain is too small or blocked, or the main drain is at least partially blocked. If you wish to go with my first idea, then I am more than happy to supply rough drawings of what would be needed, and I would not expect parts to cost too much - only issue would be if you had the space to put a small tank, and that you would have to ensure the tank was empty each time before starting a new load. An alternative solution would be to lead the waste from your washer into a garden water storage tank, checking first if the detergents you use are harmful to plants or the environment generally (many are not and plants sometimes thrive on this sort of water) - you can then water your plants for free and solve the drain issue. Obviously having some sort of garden is a pre-requisite for this, but it could be a good solution if this is the case. Please check local environmental regulations before discharging anything about which you are unsure, as fines can be quite steep. I believe a plumber should be your first port of call to check the drains.
Feb 12, 2007 | Kenmore 80754 Top Load Stacked Washer /...
Danby DPAC12030 Air Conditioner Logo
83 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
