Question about Philips 32PF7320A 32 in. LCD Television
Philips lcd won't autoprogram channels
I have a 32inch philips lcd tv that I bought 2 years ago! The first time I set it up I had no problem doing the autoprogram for my cable channels. But after I moved, it wouldn't find any digital/cable channels..not even antenna channels! I thought it was just my cable hookup! But I just recently moved again and still have the same issues! It only found a fuzzy abc channel and still cant program any other channels! help! I think it could be the tuner from the research I have done so far!
SOURCE: philips 19pfl5402d/27 tuner problem?
I cant Install gadmei tv tuner s/w in vista
Posted on Jan 15, 2008
SOURCE: I have green and red "speckles" that are very distracting within the dark/black areas of the picture. I upgraded software with Philips. No help. Nearest Philips repair is almost an hour away. TV i
Hi Mikshanks,
I had the same problem with my TV. It was a horizontal problem with different shades of color, and black spots. I replaced my Upper & Lower Y-buffer boards. Your Y-sus board should be okay since it still powers on the screen. You should replace the Y-buffers Upper & Lower, and it should work. I hope this helps.
best regards,
Tyler
Posted on May 16, 2009
tonyw514
  • 66 Answers
SOURCE: Channel Scan on my Philips 26" TV only finds the local channels.
Hi.
you should go into your tv's setup menu and go to the tuner settings and make sure it is set to CATV (cable tv) and not Antenna/Air also splitting a cable to many times can cause the signal to weaken and gain a lot of noise/distortion that could be an issue that can only be solved by having the company come to the house and do a test ALSO when your in the tuner menu in under your tv's setup menu try adding a non local channel manualy and then see if the tv will tune to it, if so then you might have to add them manually at the worst... my guess is that it is not set to CATV/cable tv hope this helps and if not i hope someone else can.
Posted on May 24, 2009
  • 27 Answers
SOURCE: can autoprogram channels and tv is fine. when i
memory batery has gone
Posted on Jul 09, 2009
  • 188 Answers
SOURCE: philips lcd locked on digital channel
press TV/DTV button on the remote.
Posted on Jul 24, 2009
Suddenly without any problems for almost 2 years my remote control stopped working. I replaced the batteries, and still would not work. I went to Radio Shack and bought a universal remote, but I have tried...
I have very good luck with the Philips universal remote. The model number of the remote is SRP1003/27. I would suggest you find one the next time you are a a large discount store. The model number is near the upc code. Thanks for asking and show all hands of support!
Jun 01, 2011 | Philips 32PFL7332D 32 in. LCD HDTV
No sound on channel 69 on my philips tv LCD
use youe remote and make sure sound setting are in Stereo mode Not SAP
Nov 02, 2009 | Philips 42PFL5332D 42 in. LCD Television
Channel setup
You will have to run the Autoprogram menu function from the menu. Here are the steps
Press the MENU button on the remote control.
Use the cursor down to select Installation in the Settings menu.
Use the cursor right to enter the Installation menu.
Select Autoprogram in the Installation menu.
Use the cursor right to enter the Autoprogram menu.
Press the OK button.
Select Cable or Antenna in the Installation mode.
When Antenna is selected, the TV will detect antenna signals and will search for antenna TV (NTSC and ATSC) channels available in your local area.
When Cable is selected, the TV will detect cable company supplied signals and will search for cable TV (NTSC,ATSC, QAM modulated) channels available in your area.
Make sure that registration with your cable TV provider and connection of equipment are completed.
Press the green button “Next” on the remote control.
Press the green button “Start” to start autoprogramming.
The menu screen disappears and the progress of autoprogramming is displayed.The progress bar indicates the number of analog and digital TV channels found. (Also digital channels via CableCARD are being programmed.
When Autoprogramming is complete, a message appears confirming the completion and the TV switches to the first installed TV channel.
Mar 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 26pfl3512 LCD TV loud power supply discharge
The "certified servicers" should have been able to identify a power supply that is breaking down at random. At random failures only occur when the TV is in your home, never in the shop. :-}. Eventually the power supply will fail completely and will have to be replaced.
Apr 26, 2017 | Philips 27PT643R 27" TV
HI MY PHILIPS 25INCH TUBE T.V ONLY GOES FROM CHANNELS 2 TO 42
Either press menu on the Philips remote and go to autoprogram, or (if you have lost the remote), press volume - and channel - at the same time. When menu appears, use channel - to select autoprogram and volume - to select it.
-Tha Mp3 Doctor
Dec 31, 2008 | Philips TS2546C 25" TV
Lost manual...need to program new tv...
The manual shows it is one of these codes for Philips TVs: Philips.................................................................................................................003, 004, 006, 008, 062, 068, 069, 074, 075, 086, 087, 089, .......................................................................................................................................................163, 183, 184, 205, 206, 207, 208, 212, 213
Sep 03, 2007 | RCA 9-Component Remote Control with LCD...
Magnovax tl712 c107 model #
Get a universal remote or go online and order a replacement original remote for your model. Then use the remote to enter the menu, unlock any child locks, make sure the set is in standard cable mode and do an autoprogram.
Aug 21, 2007 | Philips Magnavox 27MS343S 27" TV
Philips TV set PC7225-PC121
JUST GO THE MENU AND PRESS INSTALLATION. SELECT AUTOPROGRAM. AUTOMATICALLY SYSTEM GOES TO DEFAULT MODE.
Aug 04, 2007 | Philips 25PS40S 25" TV
Philips 32PF7320A 32 in. LCD Television Logo
180 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
