Question about HP LaserJet 1500L Printer
Incorrect cart is displayed
Cannot remove cart cause they dont line up with arrows
Pull the carriage until it is aligned.  Takes a hard pull and it sounds like you are stripping gears, but it works.  You will also get a blank white page when the alignment is off.
Posted on May 25, 2009
How to set up restrictions through line restriction filters
It's best if you use the "reply to post" window below the solution box so you can continue the same thread with the same person.
To set up the restriction filters we'll need to get into programming.
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the next key (bottom right arrow).
The display should now LINES.
Press the show key (top right arrow)
The display should now ask for a line number.
Enter line number you want to change the line filter on. ex. 002 = line 2
The display should say Trunk/Line data
Press the next key 2 times (bottom right arrow) .
The display should say Restrictions.
The display should say Restriction Filters
Enter in the restriction filter 25
The display should say No Restrictions and the ADD soft key should appear on the lower right soft key
Press the add soft key and in the restrictions you want on the line.ex. 011any will bolck int'l dialing but not long distance. 0any and 1any will block long distance, operator assisted calls, and int'l dialing
You can also add overrides by pressing the show key (top right arrow) then the next key (bottom right arrow) .The display should say no over rides and the add soft key should appear on the right soft key.
When finished with the filter press the heading key(top left arrow)
Press the next key (bottom right arrow) .
The display should say Line restrictions
The display should say Normal:none
Press the change key and enter 25.
Press the heading key (top left arrow) til the display says Lines.
Press the back key (bottom left arrow)
The display should say Terminals&Sets
Enter in the extension number of the person you want to allow free use of the line.
Press the next key 4 times(bottom right key)
Press the next key 2 times(bottom right arrow)
The display should say Line/Set restrictions
The display should ask for a line number.
Enter in the number of the line that was restricted.
The display should say Normal: none
Change the filter to 00 (no restrictions)
That bypasses this extension from line filter 25
Press the release key when finished
Dec 23, 2009 | NorStar M7310 Phone
I need an extra line to ring on my phone
First, you'll have to know what the line number is in the system for the new line.
To get the line port number, on the set/s that the new line appears on press feature *0 and the the new line.
The display should say for example L025:LINE 05.
The port number of the example is port 025.
write the port number of the new line down for future reference.
Programming2.gif is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear& ring
press next key (lower right arrow)til you see the line port number you wish to program
The display should say line 0xx: appear only
press the Chng key till it says appear & ring
press the release key when finished
Sep 29, 2009 | Nortel Meridian M7208 Corded Phone
Printing
Your print head may be dirty. Remove the ink carts and examine the print heads.
You should also examine the printer for a printer head parking location or cleaning pad (usually off to one side, where the cart sits when not in use or there is a pad on the side to use in cleaning the print head.)
If the print head is dirty, clean it with a soft cloth.
If the landing pad or cleaning pad is dirty from a leak, you may need to remove it or replace it.
Does printing sound normal? It is also possible that worn rollers may cause the page to advance incorrectly.
May 06, 2009 | Lexmark X7350 All-In-One Printer
The tv is blocked by autolock
I faced this same issue......the override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect. Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset. Good Luck
Apr 27, 2009 | Philips Magnavox 27MS343S 27" TV
ERROR: INSTALL TONER
Toner Empty Message If a Toner Empty Message is Still Displayed After a New Print Cartridge Has Been Installed, Enter the Tech Mode and Perform a Manual Reset CAUTION: Make sure to follow this solution carefully as incorrect settings made in the Tech mode can cause the machine to become inoperable. The Tech mode is intended to be used by service and support personnel only.
Before performing this solution, make sure a new Xerox PE220 SmartKit Print Cartridge has been installed into the machine. Other print cartridges are not compatible with the machine and a manual reset should not be attempted.
If necessary, see the Related Items below for additional information on ordering supplies, consumables, and parts.
To enter the Tech mode and perform a manual reset:
  1. Enter the Tech mode:
    1. Press the [Menu] button on the Control Panel.
    2. Press [#], [1], [9], [3], [4] using the numeric keypad. 'Tech' will be displayed on the Display Screen.
  2. Press the [Menu] button until 'Data Setup' is displayed.
  3. Press the [Enter] button on the Control Panel.
  4. Press the [Left] or [Right] arrow button on the Control Panel until 'Clear Counts' is displayed.
  5. Press the [Enter] button.
  6. Press [1], [9], [3], [4] using the numeric keypad.
  7. Press the [Enter] button.
  8. Press the [Left] or [Right] arrow button until 'Used Toner Cnt' is displayed.
  9. Press the [Enter] button.
  10. Power OFF the printer using the power switch on the rear, right side of the printer.
  11. Wait 30 seconds and then power ON the printer
Aug 28, 2008 | Xerox Phaser 3200MFP/N Laser Printer
DCP 117C Brother ink jet printer: Although ink cartridge is filled, is showing black nearly empty error message. No black is getting through on test printing after head cleaning procedure.
two diffrent errors:
1. near empty. I guess your cart is at full level.: Take cart out. unplug dcp from power. leave scanner open. replug to power. machine will come up and demanding cart. insert cart. close cover. answer display if its changed!
2. press menu then start bk-copy then four times arrow up. machine will be in maintenance mode. press by help of arrow-up and set: 7 (set) 6 (set) 3 (set) start bk-copy. machine will do a power purge cleaning. when finished press 9 (set) 9 to leave maintenance mode. run a test print and set date/time again!
Apr 06, 2008 | Brother MFC-5840CN All-In-One InkJet...
Loading Cartridge
Have you removed the protective parts? Ensure carousel is in correct position for loading carts. Ensure tram lines down the sides line up perfectly. Don't be afraid to push the cart home firmly.
Nov 12, 2007 | Epson Aculaser C1100 Printer
Brother MFC-215C
unplug machine from power. remove all carts. close cover. reconnect machine to power. wait until machine demands carts. reinsert cart as demanded by machine and secure them by pressing them into position and fixing the clip above the cart cover. give correct answer as display asks. Set date and time again.
btw: always print until printer stopps printing! Never change cart befor that
because printer logic will be fooled ;-)
Nov 11, 2007 | Office Equipment & Supplies
Printer head cleaning
Sometimes a cart doesnt work well because of mal manufacturing. Put in another brandnew black cart and do the cleaning cycle again. Its an advantage to use genuine brother carts! If you dont have any success try this: press menu then start/mono (b/w) then four times arrow up. maintenance should be displayed and the printer beeps. press arrow up til 7 is displayed. press enter. press arrow up til 6 in display. press enter. Display: Cleaning_All. press arrow up til 3 then enter: power_p all. Press start mono. machine starts power cleaning. After maintenance is displayed press arrow up til 0 (zero) then enter then 9 then enter. machine prints print quality sheet. In case there are only a few blocks in black repeat the above procedure. If you doesnt see neither any blocks in bk nor text after the second try be sure that your printhead is clogged and cant be cleaned anymore. This happens due to thirdparty ink which has pigmented ink instead of dye ink. Use only dye ink for brother printers!!!
Sep 18, 2007 | Brother DCP-110C All-In-One InkJet Printer
HP LaserJet 1500L Printer Logo
43 people viewed this question
Seeker5211
Seeker5211
