Question about HP LaserJet 1100 Printer
Paper jam i need to know what's the problem of paper jam that's one of the problem happened with printer i need to know about it to explain it to my students lease if you don't mind. any laser printer it's just a lesson with regards
  • lestar Dec 15, 2007
    printer is working but can't get print out with used paper why?
  • 4 Answers
On the HP 1100's and the 6's, there is a design flaw that causes the separator to feed more than one sheet of paper. HP has released kits that you can install that fix the problem temporarily. Your best bet is getting rid of the top fed HP laserjets. They sucked and made HP the target of a class action lawsuit.
Posted on Nov 20, 2007
Printer jams up, no matter how much paper is in it. It pulls toward the right side. I haven't used it in quite awhile. I need it to work. What can I do?
Hah, yeah I remember having that too when I first got my printer and I thought my printer was broken but it's actually something really simple. Right next to the slot where the paper goes in there's a little thing that you can move. Try moving it so it just touches the side of the paper. It's basically indended for if you want to use different formats of paper but the standard size isn't set to A4.
I hope I explained that clearly enough, if you don't know what exactly I mean let me know and I'll try explaining it better.
Jul 25, 2011 | Lexmark X1240 All-In-One InkJet Printer
I have a ESP7 all in one printer. The error says Paper Jam, no error number. The problem is there is no paper jam...I believe the problem exsits with the printhead it is not moving to the center, there...
There may be three things that are causing your printer to report a paper jam error when there is no apparent paper jam.
1) The printer is picking up the paper feed as a jam
Remove all the paper from the printer. Turn the printer off at the mains for 30 seconds. Turn it on and try printing with just 1 piece of paper in
2) There may be a bit of paper stuck on one of the sensors inside the printer.
Open the top of the printer and look very carefully around the rollers at the edges and manually turn them to check if there is any small bits of paper
3) There may be dust on one of the sensors.
Open the printer and blow inside it or ideally use a can of compressed air to clean the printer.
Regards,
sjstore2
Dec 18, 2010 | Office Equipment & Supplies
Cannot get at paper jammed in printer. How do I do this
You this manual to clear your paper jam.
Directly go to page No. 91 it explains how to open the door and paper tray to clear the paper jam.
http://static.globalcomputer.com/pdf/Brother-HL-2140-Mono-Laser-Printer-Manual.pdf
Regards
Rudra.
Oct 11, 2010 | Brother HL-2150N Laser Printer
2550Ln will not print
If the supply lights are not lit, then you may have a paper jam. Check the rear cover. Also sometimes paper jam lights come on even though the paper has not jammed, just misfed from the cassette. Please let me know any further details.
May 12, 2009 | HP LaserJet 2550L Printer
Paper is jamming all the time
You will need a tech guy to fix this. Sorry to dissapoint
Apr 27, 2009 | Panasonic KX-MB781 All-In-One Laser...
My printer won't print because it says that there is a paper jam, but there is no paper left jammed in the printer. I don't know how to solve this considering there is no actual paper jammed in the...
HI,
it seem there was still left paper in yur printer
please open again the cover and look very carefully for the paper
even how small it is it will still cause a paper jam.
after that turn off your printer and try to open it again.
any changes happen let me know.
thanks,
Mar 30, 2009 | Dell 948 All-In-One InkJet Printer
Printer Feeder not working well. Paper always gets stuck.
Recurring paper jams can be caused by broken parts, using too much paper in the in-tray, or parts (usually the rear door) not on all the way. This video explains how to fix a paper or carriage jam, but explains along the way the things to watch for. If you go through the steps in this video and you still get paper jammed, you may have a broken printer that needs to be replaced or repaired.
Feb 02, 2009 | HP Photosmart C6180 All-In-One InkJet...
MF5750 All-In-One Laser Printer DOES NOT PRING indicate paper jam I check and there is no paper jamed in the printer. It starts as it will pull the paper to copy document and then indicates in the display...
It starts as it will pull the paper to copy document and then indicates in the display that the paper is jamed.
Can anyone explain what the problem my be?
Please assist me.
Jan 19, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Paper feed/jamming problem
suggest you bring your orinter to the nearest authorised repair center. There might be parts to be replace
Mar 23, 2008 | Brother HL-2040 Laser Printer
HP LaserJet 1100 Printer Logo
73 people viewed this question
Clive
Clive
