Question about Dell Dimension 8250 PC Desktop
Possibility of using Dimension 8250 memory in a Dimension 8200
Can I take 256mb (dual) memory from my Dimension 8250 and use it in my 8200. The 8200 uses 40ns and I think is 800mhz, whereas memory for 8250 says 1066. Thanks, Chris
  • csimone May 25, 2009
    Will I damage my 8200 if I put the 8250 memory in?
    I'm confused? Was that same answer intentional? I checked that link but am not sure if I have a 533 or 400 mhz because the it's a 1.8 ghz (400 ghz on pny), but according to some memory upgrade sites, should be 533 mhz. Thanks
  • 111 Answers
Probably not, but to confirm go to this link. When you're there plug in the info for both machines and compare the memory configurations.
Posted on May 25, 2009
  • Michael Rodriques May 25, 2009
Need compatible sound card replacement for Dimension 8250 running Windows 7
Take your pick, USB or check what type of slot you have available. Dont forget to disable the sound chip/feature in your BIOS.
http://www.tigerdirect.ca/applications/category/category_tlc.asp?CatId=107&srkey=sound%20card
Apr 10, 2014 | Dell Dimension 8250 PC Desktop
Hello i got integreted network card on me dell dimension 8250 i was trying to get drivers from dell site but me pc still doeasnt see me network card please help me as quick its possible
On a computer that DOES have Internet access,
access the manufacturer's web-site: http://support.dell.com
and select "Dimension" and "8250".
Select the device-driver for the NIC.
Download it.
Copy the download to a CD-recordable disk, or to a USB memory-stick.
Move the copy of the file to your Dell.
Run the software to install the device-driver for the NIC.
May 22, 2011 | Dell Ethernet Card Network Adapter
Dimension 8250 PC Desktop: Dell Inspiron 8250. I've re-installed Windows, bu...
Once Windows is reinstalled on dell computers you have to use resource cd that came with it and reinstall network and sometimes couple other drivers like video or sound. If you dont have the resource cd you will have to get some how to dell.com maybe from your friends pc or if you have another one and just download it from there. Go to dell.com,click on support then on drivers and software and choose your system and you will find all drivers right there. Hope this helps.
May 07, 2010 | Dell Dimension 8250 PC Desktop
My Dell Dimension 8250 needs a battery -- what size lithium coin-cell battery does it need.
Hello there
The CMOS cell for the Dimension 8250 is a CR2032. hope this veryhelpful
Best regards mike
Nov 20, 2009 | Dell Dimension 8250 PC Desktop
Dives on Dimension 8250 will not read without first using "eject"
First thing I would try is to go into windows device manager and uninstall both drives. Now turn off the PC and reboot it. Let Windows plug and play find and reinstall the drives. If it cannot find drivers, and you don't have the driver disks, tell it to look in c:\windows\system or c:\windows\system32, your current driver sould be in those folders. Gordon, if this doesn't do the trick, let me know and we'll move on to other possibles; but this should fix this problem about 80% on the time.
Oct 15, 2009 | Dell Dimension 8250 PC Desktop
Dimension 8250 will not turn on but on button
open cpu cabinet
Refix RAM memory then check.
Pull cmos cell for 10 minutes frommotherbord so all settings defaults.
Also clean dust from all circuit.
Reconnect ATX connector from smps supply to motherbord.
Refix processor fan and processor.
Let me know if you need more assistanse.
Thanks.
Aug 31, 2009 | Dell Dimension 8250 PC Desktop
I have a dell Dimension 8250 and replaced the memory cards with a higher memory. I got a memory error beep code so I replaced the original. I'm still getting the beep code. Any ideas? I was careful...
Please check the following link for complete information on Dimension 8250
http://support.dell.com/support/edocs/systems/dim8250/
Check the technical specification section to see if u bought the correct memory type for this computer to upgrade..if yes then proceed to the adding and replacing parts section to check for the instructions on adding memory.
Jun 27, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Full system restore without disk for dell dimension 8250
The Dimension 8250 was not equipped by Dell with an automated re-image process. If you want a clean installation of Windows, it will require a manual installation from the Dell Windows Media, followed by installing the drivers from either the resource CD or internat download. Once completed, then reinstall all applications.
Apr 12, 2009 | Dell Dimension 8250 PC Desktop
Dell Dimension 8250 Memory Question
Computer Memory Information Upgrade Questions Troubleshooting Memory Diagram Upgrade Help Buying Tips · Memory definitions. MEMORY ABCs. Memory, which is commonly referred to as RAM
Installing PC computer memory Additional information and help with isntalling PC computer memory. ... Installing a PC computer memory. Question:. Installing PC computer memory.
Determining type of hardware within computer Reference, Issue / Question. Memory, Information and help with computer memory. CH000149, How to determine system resources / RAM available?
Buying tips on computer memory. How much memory should I get? This question really depends on the type of computer user you're and what type of programs you plan on running on the computer
Determining what type of memory to use in a memory upgrade. Determining what type of memory to use in a memory upgrade? Question:. Determining what type of memory to use in a memory upgrade.
E-mail CHID: 5683
Good Luck read and follow instructions will find your answer.
Good Luck, Please dont for get to Vote/Thank You.
Dec 20, 2007 | Dell Dimension 8250 PC Desktop
Dell Dimension 8250 PC Desktop Logo
173 people viewed this question
Alun Cox
