HP LaserJet Pro M1217nfw MFP - multifunction  fax / copier / printer / scanner   B/W Logo
A
Anonymous Posted on Jan 08, 2014
Error Message "Used Supply in Use" - HP LaserJet Pro M1217nfw MFP - multifunction fax / copier / printer / scanner B/W
My Lexmark printer when turn on it makes noise and it can not print with a error code 2200
Hello thanks for using Fixya
The 2200 error message indicates a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message.
Step1.
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes:
Continue to step 2.
No:
Attempt a test scan. If the error message does not reappear, the error is resolved.
Step2. Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.Did the error message return?
Yes:
Continue to Contacting Lexmark.
No:
Continue to step 3.
Step3: Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes:
Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No:
Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
Step4: Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes:
Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No:
Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using Fixya
Getting error code 2200 on Lexmark P6250 Photo All-In-One InkJet Printer. Programme asked to refer to user guide. Error code not in user guide. Unplugged printer while on. Restarted PC then replugged...
hi
here is what i have found -- follow to all instructions accordingly
although its for another model, these isntructions apply according t their techsupport i spoke with
.Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
2.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.
3.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
here is where i found the error http://support.lexmark.com/index?page=answers&startover=y&locale=en&userlocale=EN_US&question=2200 error#1
hope this helps -- God's speed
What is error #2200
Printer Reset
1 Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
2 Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: contact Dell.
3 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, contact Dell.
No: Install the color cartridge. If the printer fails, contact Dell. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
2helpful
After about 5 minutes into a wash cycle, the error "E02" is displayed and the wash cycle stops. What does this error message mean? It isn't in the book that came with the washer.
I just had this problem. My water supply (hot ) had been turned off since my husband used it to fill our hot tub. Other causes were-supply hose kinked,strainers in supply hose clogged, water pressure too low. Hope this solves your problem!
2answers
I get the error 2200 message everytime I try to send a fax
Hello there:
this is a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message2.gif.
Printer Reset
NOTE: The embedded links in the table lead to specific troubleshooting documents.
StepAction1
No: Attempt a test scan. If the error message does not reappear, the error is resolved.2
Power off the AIO and remove the power supply from the back of theunit. Open the scanner cover. Check the scanner glass for cracks andthe scanner casing for cracks. Close the scanner lid. Open the topcover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
No: Continue to step 3.3
Power off the AIO and remove the power supply from the back of theunit. Open the top cover of the AIO. Using the carrier belt, move thecartridge carrier to the middle of the unit. Insert the colorcartridge, close the top cover, reinsert the power supply, and power onthe AIO.
Yes: Repeat step 3 with another color cartridge. If the printer2.gif fails again, continue to step 4.
No: Repeat step 3and install the black/photo cartridge. If both cartridges areinstalled, attempt a test scan. If the error message does not reappear,the error is resolved.4
Power off the AIO and remove the power supply from the back of theunit. Open the top cover of the AIO. Using the carrier belt, move thecartridge carrier to the middle of the unit. Remove the color cartridgeand insert the black/photo cartridge. Then close the top cover,reinsert the power supply, and power the AIO on.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark.If the error message does not appear with both cartridges installed,attempt a test scan. If the error message does not reappear, the erroris resolved.
What does error code 2200 mean?
Printer Reset
Step Action 1
No: Attempt a test scan. If the error message does not reappear, the error is resolved. 2
No: Continue to step 3. 3
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved. 4
1helpful
Error 2200
Printer Reset
NOTE: The embedded links in the table lead to specific troubleshooting documents.Step Action
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Error 2200
Step Action
1 Power off the printer and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the printer on.
2 Power off the printer and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the printer. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the printer on.
3 Power off the printer and remove the power supply from the back of the unit. Open the top cover of the printer. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the printer.
4 Power off the printer and remove the power supply from the back of the unit. Open the top cover of the printer. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the printer on.
What does error 2200 mean
Printer Reset
k24674
Grand Canyon Tech
Grand Canyon Tech
