Question about Dell 3100cn Laser Printer
Manual for RAM upgrade
Dell 3100cn laser printer: where is the slot for the memory expansion? I want to put in 512 MB Ram. Is there any PDF file that gives me assistance to upgrade the memory? Regards, Fritz (mail at obefritz.de)
  • obefritz May 25, 2009
    Thank you for your answer.
    I just ordered the 512MB some hours before.
    What I want to know is where the socket within the printer is, where i have to put the memory when i have it.
    And especially how far do i have to "open" the printer (with screwdriver or other things) to be able to put the memory in.
    Regards
    Fritz
    oh sorry, you wrote: "as for where it goes that will be in the manual". But i did not find any hint about memory upgrade in the user manual. Neither where would be the socket for the memory.
  • 432 Answers
Memory Upgrade for Dell Color Laser Printer 3100cn Printers, the Dell Color Laser Printer 3100cn Printers takes the PC133 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory. You can upgrade your Dell Color Laser Printer 3100cn Printers to up to a maximum of 576 MB Memory, the system has 1 socket to install Memory, already with 64 MB (non-removable) standard Memory installed.
http://www.memorystock.com/memory/DellColorLaserPrinter3100cn.html
You should be able to get crucial or the likes to send you the correct memory - as for where it goes that will be in the manual
Posted on May 25, 2009
  • 1 more comment
  • Shane Russell
    Shane Russell May 25, 2009
    Dell link to upgrade memory
    web archive version of the manual
    scroll to the bottom to download the file ( not sure if the images are included )
    However if you are facing the printer with the control panel directly in front of you there is a panel on the left hand side half way up near the rear side that you should be able to take off and the memory cards are installed there.
  • Shane Russell
    Shane Russell May 26, 2009
    I gave more specific information - can you alter the rating please.
  • Shane Russell
    Shane Russell May 28, 2009
    Thanks for altering the rating
I put the memory stick in my dell but the computer does not upload the device. so I went to control panel in devices and printers and I can see the devices but when i say add to this computer it's
Memory sticks are not devices such as printers and
Dell XPS 400 PC Desktop
Installing RAM on a desktop computer is of moderate difficulty for most non-technical people. Before beginning any memory upgrade, make sure the proper RAM has been purchased. The Dell XPS 400 requires DDR2 RAM (240-pin DIMM).
Preparing the Computer b> The computer must be unplugged before any work can be completed and the proper precautions must be taken, such as wearing an anti-static wristband. Also, replacing the RAM on a Dell machine could void its warranty. To install the new RAM, the case of the computer needs to be opened. Replacing the RAM b> The motherboard has four RAM slots. Each slot takes one stick of RAM (up to 1 GB per stick). The XPS 400 can utilize up to 4 GB of RAM. If adding RAM, put the new RAM in an empty slot. If replacing the RAM, take out the existing one and then put the new RAM into the machine. Important Notes b> While the Dell XPS 400 has four RAM slots, if only two sticks of RAM are to be used, they must be inserted into slots 1 and 3 or slots 2 and 4 for optimal performance. A single stick of RAM should be inserted into slot 1. Always put the largest ram module closest the CPU central processing unit.
Start your computer Wait for Windows to load. Click on "My Computer" and select "Properties" using right-click in the Explorer window. This will open "Systems Properties." Click on the "General" tab. Here you can view the physical memory installed on your computer. The amount indicated is the total RAM installed on your computer. RAM is usually 32 MB, 64 MB or 128 MB in older PC versions. Newer PCs are usually equipped with 256 MB, 512 MB or even higher RAM.
b>If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system. You should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible.
Mar 01, 2013 | Dell XPS 400 PC Desktop
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
I have a 512 mb 667mhz sdram on D102Ggc2 board.now i decided to up grade memory. Can i upgrade system memory without lose this 512 mb.
Yes you can. but make sure that you buy the exact same type of RAM stick that you have and put it in the other RAM slot so the Dual Channel feature will be active (dual channel makes data transmission/processing faster) and making your systems memory 1GB. However, your motherboard can utilize or handle up to 2GB or RAM so you can put also a 1GB RAM stick which will make your systems memory a total of 1.5GB (that will be the case if you really dont want to lose the 512MB that you currently have,
Hope this helps.
Jul 09, 2010 | Intel D102GGC2 Motherboard
Fitting RAM
Here are some instructions that should work for all 3000 series laptops.
http://support.gateway.com/s/Manuals/Mobile/8512061_Apache_RPL.pdf
Mar 31, 2010 | Computers & Internet
Dell 3100cn laser printer: where is the slot for the memory expansion?How far do i have to open the printer to be able to put the memory in? Is there any manual for these details?
http://www.fixya.com/users/the_fire added a very useful comment to my first question " Manual for RAM upgrade" that solved my problemThany you very much for this service!
Fritz
May 25, 2009 | Dell 3100cn Laser Printer
Ram upgrade
Its support "DDR SDRAM"
Max Supported Ram is "1GB"/"1024 MB".
Ram Speed: 266 Mhz..
Good luck...
regards,
Dec 04, 2008 | Toshiba Satellite A65-S1068 Notebook
RAM memory in my HP9500n
memory slot on formatter so fix tt memory on formatter
Aug 08, 2008 | HP LaserJet 9500n Printer
Where is the expansion slot for the RAM for ASUS Notebook A2400H?
The manual is incorrect. Memory is under keyboard. There is a small hole to the left of the right speaker. insert a paperclip vertically into the hole and apply a slight amount of pressure at the same time sliding the plastic section to the left. It should be obvious at this stage. then fold back keyboard. 2 memory slots are located under the plate near the middle of the unit. Specs say max of 2 x 512MB modules. they are PC2100 DDR266 200 pin SODIMM. If there is someone else reading this maybe they can tell me what the slot is for under the smaller plate to the right of the memory compartment.
Cheers.
Aug 06, 2008 | ASUS A2H (A2HOB) Barebone
Reg ram upgradation
Each memory slot on the C555NR can support a maximum of 1GB of RAM. There are actually 2 slots, but only one is easily accessible to you. By upgrading both the primary and secondary DIMMs, you could achieve a total of 2GB of memory but you would have to remove the 512mb chip that is already installed and replace it with 1GB (+1GB in the expansion slot as well.)
If you don't plan on taking the computer to a professional to be serviced, you will probably only want to upgrade the memory in the secondary slot located under the memory cover on the underside of the computer. It can handle a 1GB SODIMM.
FYI the memory is:
200 Pin DDR2-533 PC2-4200 SODIMM
Apr 21, 2008 | HP Presario C555nr Notebook
Upgrade from 512MB to 1GB
The specs on the memory are correct, so you purchased the correct type of memory for this motherboard. If your getting no video when you power on with the 1gb stick, I would be willing to bet the 1gb stick is bad. Can you return it and try another stick?
Mar 15, 2008 | ASUS P4B266 Motherboard
Dell 3100cn Laser Printer Logo
366 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
